    INDIGO STUDY INDOOR SCENE
    74 Posts 30 Posters 15.0k Views 30 Watching
    • K
      kwistenbiebel
      @pibuz said:
      Maybe overexposing something isn't such a bad affair, as I tend to think.. And a lighter atmosphere won't harm either..
      I think the most important thing is that your image has a wide range going from full white 255,255,255 to full black 0,0,0.
      That doesn't always mean the image would be overexposed (unless it is the effect you are after).
      Overexposed would be having too much areas in the image going full 255,255,255 white.
      I tried to reproduce what I mean:
      The following image isn't overexposed but it does contain full black ( shadow part of chair/shelves) and full white (a small strip of white in the picture frame).
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/view3-2.jpg
      Another example:
      Although the next image has a soft and warm mood, there is still enough contrast between light and dark.(light range going from full black (small shadow parts on the chair) to full white (small parts of the reflections on the bowls and chrome).
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/view4-1.jpg
      The best tool to control the light range in Photoshop is the 'levels' tool , but I know you know that ๐Ÿ˜„
      I don't think there is anything wrong with your image when it concerns light by the way.
      Unbiased render engines do seem to have trouble to control the midtone contrast. Using Reinhard tonemapping helps a bit (clamping the overexposed/underexposed areas), but somehow Reinhard does seem to reduce the realism a little by flattening the midtones a little too much).
      The linear (and exponential tonemapping) presets provide a great sense of realism but your images are easily overexposed or underexposed and with a too steep lighting 'curve' ,meaning that there is not much of a gradient between the lightest and darkest colors.
      The 'curves' tool in Photoshop can fix this.
      Another thing: When your RAW render output is heavily overexposed or underexposed, you might not be able to correct it in Photoshop as the image misses information as too much areas went full white or black.
      So you're better of with a raw image that lacks some contrast which is much easier to fix in Photoshop.
      • C
        crc
        Thanks for that Kwisten, very informative.
        I was wondering if you would post your scene with out post-pro. It would help in seeing the difference and, for me, in interpreting what you mean. For some reason (I don;t really know why) I almost never use PS for my Indigo renders.๐Ÿ˜’
        I'm going to take some and use what you said.
        and thanks for the scene Pibuz!(crojack from the Indigo forum)
        http://www.motoclip.net
        • C
          chango70
          Why are there patterns on wall?
          • P
            princedragoncok
            Hey, here's the scene setup:
            http://i346.photobucket.com/albums/p420/princedragoncok/scenastudiolegno.jpg
            • P
              princedragoncok
              Nice test scene Pibuz, thanks! v.nice renders too Kwistenbiebel.
              Here are my attempts with Hypershot, around 20mins each, two cores. Thing with Hypershot is that you can't use the native su sun, so I had to get as close as possible with a hdri.
              http://i346.photobucket.com/albums/p420/princedragoncok/mood2.jpg
              http://i346.photobucket.com/albums/p420/princedragoncok/envi2.jpg
              http://i346.photobucket.com/albums/p420/princedragoncok/enviro.jpg
              http://i346.photobucket.com/albums/p420/princedragoncok/enviro1.jpg
              http://i346.photobucket.com/albums/p420/princedragoncok/mood.jpg
              Who likes what best and why?
                rcossoli
                I encourage my
                This image was made with kerkyhea, 2000x1200 image original size.
                rendering in method number 11 with 2 nucleos, an athlon 64x2 4800 and 2 GB of RAM.
                Approximate time 40 minutes.
                THREEDIMENSIONSWEB dot COM
                • stefanqS
                  stefanq
                  Nice stuff here, guys!
                  Kwisten, top class renders, I try it myself, but your renders are just perfect!
                  • P
                    pibuz
                    I'm going on modifying the things i'm not satisfied with; next step: replace the plant!!!
                    This is a small update: done a fantasyless postpro work with PS, and testing a whatsoever "definitive" layout...
                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    • H
                      huyvuvn
                      let relax with your scence ๐Ÿ˜„
                      http://img398.imageshack.us/img398/6584/ren1yd3.jpg
                      http://img259.imageshack.us/img259/1539/ren2ud2.jpg
                      happiness on the way, not in the destination.
                        rcossoli
                        another image made kerkythea, IES without lights and with some minor changes in materials and post production of the image.
                        • K
                          kwistenbiebel
                          I like the second set up a lot.
                          Almost there. Try to use the 'rule of thirds' to make the composition even more perfect.
                          As a note, did you expect that much people giving it a go themselves? (...at the risk of a serious hijack though).
                          It is a nice scene and we all can learn from it.
                          Would be a cool that once and a while someone posts a working scene we all can try out.
                          Thanks for sharing!
                            rcossoli
                            exelente examples ๐Ÿ‘ unwittingly was raised a little comparison of different programs ๐Ÿ˜„
                            • P
                              pibuz
                              Thanks for sharing!
                              I think this is the essence of learning, concerning GI, and I've always thought so!
                              I tried to drop the idea somewhere(here on sketchy forum or on kerky's or on Vray's); result: a lot of agreements, but not a scene shared.. ๐Ÿ˜’
                              I really think that sketchUp can help a lot, with its structure and way of managing files.
                              And comparisons between render engines using the same base scene isn't hijacking at all, for me: so I invite you all guys to keep on rendering the poor scene I posted, and to share one among your best ones so that anybody can try!
                              • FrederikF
                                Frederik
                                A quick test I just did... ๐Ÿ˜‰
                                In this scene I used the same materials as in the original, but I will try some others and also - inspired by Kwistenbiebel - some different camera posisions... ๐Ÿ˜„
                                Cheers
                                Kim Frederik
                                • H
                                  huyvuvn
                                  I used vray 1.50sp1. โ˜€
                                  http://img217.imageshack.us/img217/7095/79208194wi4.jpg
                                  • P
                                    pibuz
                                    "SCENE STUDIO LEGNO"
                                    thank you for the italian translation ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                                    • F
                                      FoXar
                                      Hello there,
                                      Here's my render test, I'm not that top notch in rendering but meh..
                                      It's my best render so far and I've learned a lot of it! So thanks anyway :]
                                      Btw, Before I forget... Rendered in KerkyThea with Photonmapping Fine + AA
                                      • soloS
                                        I have not used Podium in a while so I thought I'd use this model to play with the new Podium, I must say it's very fast as this rendered in 5 m 36s using default preset and on a quad. I added soft focus for mood.
                                        http://img206.imageshack.us/img206/7643/roomtestlw9.jpg
                                          sepo
                                          Looking good King. ๐Ÿ˜„
                                          • P
                                            pibuz
                                            Hi guys! I feel like this is not a floor test scene anymore..
                                            I'm kind of affectionated to this scene!
                                            So, I'm still planning a few changes: the spot light on the right is a little annoying and doesn't even seem to be turned on, the right picture is too big, the cart is empty..
                                            Next challenge is the fruit vase: i'm gonna try to fill it with oranges, let's see what comes out! ๐Ÿ˜„
                                            Then I'll add a piece of furniture on the far right, under the table againsta the wall, and perhaps some objects over the high plasterboard shelf.
                                            5 hours of calculation on a Q6600, 4GB RAM, WinXP
                                            No post process, apart from a very subtle sharpening.
                                            As always, any suggestion would be much appreciated!
                                            • 2 / 4
