    INDIGO STUDY INDOOR SCENE
    74 Posts 30 Posters 15.0k Views 30 Watching
    • stefanqS
      stefanq
      Nice stuff here, guys!
      Kwisten, top class renders, I try it myself, but your renders are just perfect!
      • P
        pibuz
        I'm going on modifying the things i'm not satisfied with; next step: replace the plant!!!
        This is a small update: done a fantasyless postpro work with PS, and testing a whatsoever "definitive" layout...
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        • H
          huyvuvn
          let relax with your scence πŸ˜„
          http://img398.imageshack.us/img398/6584/ren1yd3.jpg
          http://img259.imageshack.us/img259/1539/ren2ud2.jpg
          happiness on the way, not in the destination.
            rcossoli
            another image made kerkythea, IES without lights and with some minor changes in materials and post production of the image.
            THREEDIMENSIONSWEB dot COM
            • K
              kwistenbiebel
              I like the second set up a lot.
              Almost there. Try to use the 'rule of thirds' to make the composition even more perfect.
              As a note, did you expect that much people giving it a go themselves? (...at the risk of a serious hijack though).
              It is a nice scene and we all can learn from it.
              Would be a cool that once and a while someone posts a working scene we all can try out.
              Thanks for sharing!
                rcossoli
                exelente examples πŸ‘ unwittingly was raised a little comparison of different programs πŸ˜„
                • P
                  pibuz
                  Thanks for sharing!
                  I think this is the essence of learning, concerning GI, and I've always thought so!
                  I tried to drop the idea somewhere(here on sketchy forum or on kerky's or on Vray's); result: a lot of agreements, but not a scene shared.. πŸ˜’
                  I really think that sketchUp can help a lot, with its structure and way of managing files.
                  And comparisons between render engines using the same base scene isn't hijacking at all, for me: so I invite you all guys to keep on rendering the poor scene I posted, and to share one among your best ones so that anybody can try!
                  • FrederikF
                    Frederik
                    A quick test I just did... πŸ˜‰
                    In this scene I used the same materials as in the original, but I will try some others and also - inspired by Kwistenbiebel - some different camera posisions... πŸ˜„
                    Cheers
                    Kim Frederik
                    • H
                      huyvuvn
                      I used vray 1.50sp1. β˜€
                      http://img217.imageshack.us/img217/7095/79208194wi4.jpg
                      • P
                        pibuz
                        "SCENE STUDIO LEGNO"
                        thank you for the italian translation πŸ˜„ πŸ˜„ πŸ˜„
                        • F
                          FoXar
                          Hello there,
                          Here's my render test, I'm not that top notch in rendering but meh..
                          It's my best render so far and I've learned a lot of it! So thanks anyway :]
                          Btw, Before I forget... Rendered in KerkyThea with Photonmapping Fine + AA
                          • soloS
                            I have not used Podium in a while so I thought I'd use this model to play with the new Podium, I must say it's very fast as this rendered in 5 m 36s using default preset and on a quad. I added soft focus for mood.
                            http://img206.imageshack.us/img206/7643/roomtestlw9.jpg
                              sepo
                              Looking good King. πŸ˜„
                              • P
                                pibuz
                                Hi guys! I feel like this is not a floor test scene anymore..
                                I'm kind of affectionated to this scene!
                                So, I'm still planning a few changes: the spot light on the right is a little annoying and doesn't even seem to be turned on, the right picture is too big, the cart is empty..
                                Next challenge is the fruit vase: i'm gonna try to fill it with oranges, let's see what comes out! πŸ˜„
                                Then I'll add a piece of furniture on the far right, under the table againsta the wall, and perhaps some objects over the high plasterboard shelf.
                                5 hours of calculation on a Q6600, 4GB RAM, WinXP
                                No post process, apart from a very subtle sharpening.
                                As always, any suggestion would be much appreciated!
                                • K
                                  kwistenbiebel
                                  I like where that scene is going Pibuz!
                                  Maybe some cupboards above that upper shelve on the back wall?
                                  • soloS
                                    I also gave it a try with Vue 7, I used a spectral atmosphere with a spot of radiosity using only sunlight.
                                    http://img172.imageshack.us/img172/797/testscenexl8.jpg
                                      remus
                                      This is a rather cool scene...i just wish indigo wasnt so damm slow!
                                      • P
                                        pibuz
                                        Remus: truly slow, indeed.. But sometimes it DOES worth the wait!
                                        Solo: Hi man! Very interesting POV! I'll give it a try myself when this whole project is over!
                                        Kwisten: All right! Something on the shelf! I was thinking about a couple of decoration vases i found on the warehouse indeed, but they don't seem to fill the shelf too much, so it keeps on looking a little empty and useless... Still thinking...
                                        Earthmover: Very nice feeling! It feels so warm, mine is a little cold.... πŸ˜’
                                        Thank you all guys for your feedbacks!
                                        • FrederikF
                                          Frederik
                                          Just trying another image, another ies-light and with a HDRI background...
                                          Added a touch bloom in post pro...
                                          Render time: app. 9 minutes... πŸ˜‰
                                          Cheers
                                          Kim Frederik
                                          • EarthMoverE
                                            EarthMover
                                            What a fun little project....it's great to see all the different results. Perhaps we should all go back and edit our posts to make sure they reflect machine size and render times, for comparison purposes. I think today I'll give the scene a go using Modo.
                                            It would be nice try a similar thing with a shared exterior scene. Anyone got one?
                                            • Awesome video Kwist!
                                            Content Creator at Skapeup
                                            • 2 / 4
