    Vray site down?
    renderpluginsextensions
    21 Posts 4 Posters 5.0k Views 4 Watching
      ScottPara
      OK thanks. I know I can not log in using Firefox. I mean I can log in but once I go to the forum it logs me out again. Vicious circle. I reported it and they were aware though.
      Scott
      Love the fact that some HATE my avatar.....
      • C
        Click Draw
        Hi people,
        Have a look at this site. Are they distributors for asgvis.com? Not sure where I should buy it...
        Jeff
        403 Forbidden
        (www.vray.com)
        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
          Hmm... not sure. But it's interesting that they are cheaper than what you find on AsgVis site; $799.
            back online. for the time being...
            • C
              Click Draw
              ....and they're down again.. 😠
              • C
                Click Draw
                OK, here's the purchase options for me:
                Modo
                -modeling
                -animation
                -sculpting
                -rendering
                745.00
                VRay
                -awesome rendering
                -already bought SU7 Pro(495.00)
                699.00 + SU7Pro = 1194.00
                See my problem?
                What would YOU do???
                Jeff
                  I think I would have used Modo. Would still use SU, but as a base and then import to Modo for refinement.
                  At work I don't have the luxury to use anything but SU as the others at the office needs to edit the models. But if you can fir Modo into the workflow I'd go for that. (Or any other modeller. rhino is very nice for instance.)
                  • C
                    Click Draw
                    Ya Rhino is nice. Haven't done much with it tho. Basically I'm after a good rendering program that either works inside SU or one I can import a SU model into, then render it.
                    • C
                      Click Draw
                      I haven't heard of Modo until Earthmover on the forum here brought it up and posted his renders. Always a bit slow to jump onto a new program.
                      • StinkieS
                        Stinkie
                        If that is the case, then choose Vray. Scott Para disagrees with me, but I cannot shed the distinct feeling modo's output isn't as good as Vray's. Also, I find making mats with modo a lot harder than making Vray mats. (Though I must add modo's a great modeling app!)
                        In any case, if you do decide to go with modo, these might come in handy:
                        http://www.luxology.com/store/15_architectural_interiors/
                        Bad Request
                        (vandigital.com)
                        Also check out the other tutorials Luxology's got. I got most of them, and I must say, they're good. I especially enjoyed the one on architectural modeling.
                        Oh ... while I'm at it, some fun free stuff:
                        http://homepage.mac.com/janoverust/FileSharing24.html
                        • C
                          Click Draw
                          Thanks Stinkie,
                          I guess I could always get both πŸ˜„ . I'll check out the links and thanks again. I've been e-mailing back and forth with VRay and Modo. They are both pretty hungry!
                          Cheers, Jeff
                          • C
                            Click Draw
                            So Stinkie,
                            You have both full versions then, Modo and Vray for SU?
                            • StinkieS
                              Stinkie
                              Yes. And I'm quite happy with both apps, I must say. I'm hoping there'll be a Vray plugin for modo some day, though I'd settle for a Maxwell one, if necessary.
                              I've been trying out a Sketchup to modo workflow lately, and that seems to work quite well. SketchUp for quick yet accurate initial modeling, modo for mesh refinement. The best of both worlds, eh? πŸ˜„
                              What I need now, is Max and Vray for Max. The combined price of both apps is somewhat steep, though. 😲 ❗
                              • C
                                Click Draw
                                Hey Stinkie,
                                Ever checked out Cinema 4D? Could you post some examples of you SU to Modo renders? That would be great.
                                Thanks again,
                                Jeff
                                • StinkieS
                                  Stinkie
                                  No, I've never used C4D. I had a demo of it installed at one point, but I never got around to putting it to good use.
                                  I don't have any modo renders to show, as I do not use modo for rendering. I had quite a bit of test renders which I did while I was watching Van Digital's tutorial, but I didn't keep 'em.
                                  Look, the best way to decide which app to choose, is by having a long, unbiased look at their respective outputs. For me, Vray's output looks better. modo renders have this velvety quality to them that I dislike, and somehow I don't quite believe modo's mats. Those always look like plastic to me.
                                  One can push modo's render engine to produce near-Vray quality, but from what I've read in various threads over at the Luxology forum, and from what I've learned by watching Van Digital's and Yazan Malkosh's tutorials, I can conclude that'll be something of a lengthy task, both setup and rendering wise.
                                  • C
                                    Click Draw
                                    Well I have decided to get both. VRay will be the first purchase and Modo probably next month. I still have to eat....or I could eat macaroni and cheese for a month I guess. I do have my priorities!
                                    Jeff
                                    • StinkieS
                                      Stinkie
                                      lol. I know the problem. I don't even want to know how much I've spent on software, hardware, models, textures etc so far. I'm done for a while, I think. I'd like to keep some of my savings! πŸ˜„
                                      Well ... enjoy Vray and modo!
                                        Jeff
                                        Macaroni and cheese for a month isn't too bad. Students live for year on that stuff.
                                        • C
                                          Click Draw
                                          Thom Thom,
                                          Do you get Kraft Dinner where you live? The stuff is awesome. There must be a cook book out.....101 Ways to cook Kraft Dinner. 😎
