    Vray animation render?? EMERGENCY!! PLEASE HELP!!
    renderpluginsextensions
    13 Posts 8 Posters 6.6k Views 8 Watching
      alpro
      Make sure that you also have batch render checked in global switches
      Mike
      • B
        brokenstaral
        yes i have already checked the batch render
        can you please help me spot where i do wrong
          ddaiber
          403 Forbidden
          (asgvis.com)
          you will find there the basics, I just learned from it yesterday.
          good luck!
          • B
            brad.curnow
            For future reference, the quick answer is the "scene delay" in the animation properties of the model.
            If this is set to say, 2 seconds, then the first scene will show for 2 seconds before moving on... Which means that at 30fps Vray will render 60 images that are exactly the same before it starts moving.
            • B
              brokenstaral
              no kidding = =
              that's what went wrong...
              but i have just finished my crit today so...XD it is a bit late
              but thnx anyway!!
              it is very helpful, at least i know what went wrong
              so what is usually the normal time setting for [scene delay] and [frames per second]????
              • B
                brad.curnow
                The scene delay should be 0 (almost always, unless you WANT there to be a pause between scenes)
                The rest is trickier. 30 frames per second will give you nice, smooth animation, so generally leave it at 30 if you can.
                To get an idea of how many frames Vray will have to render, multiply the number of scenes by the scene transition - i.e. if you have 12 scenes and the transition time is 3s, then the length of the animation will be 3x12=36s long.
                The number of frames then is 36x30=1080.
                Obviously you can tailor the length of your animation to suit, (1 minute / 12 scenes: 60/12=5 - scene delay should be 5 seconds). You can then adjust the frames per second in Vray to suit your needs whether it's a draft, nice and smooth, or in a hurry for a crit 😄
                The higher the FPS the nicer the animation, but the longer the render time. Human eyes cant really notice anything higher than 30fps.
                Hope that helps, sorry for late reply! I have some time now so will hang out here a bit more frequently 😄
                  juanjo06
                  after the finished pictures... what is the other software do i use for make the transition or the animation makes effects?
                  how could i put the images??
                    Jackson
                    I use VirtualDub 1.8.1 for making and processing films from single frames and Wax 2.0 for editing the result, adding transitional effects etc. Both are freeware, powerful and very well designed.
                    http://www.virtualdub.org/
                    Error 404 (Not Found)!!1
                    (www.debugmode.com)
                    Jackson
                      juanjo06
                      thanks... trying.... 👍
                        rbochner
                        hi,
                        I would like to know what to optimum hardware is to have short render times, in order to create movies such as described above.
                        thanks
                          Jackson
                          @rbochner said:
                          hi,
                          thanks
                          The fastest, most-multi-cored CPU (V-Ray uses all of them) with the most RAM you can afford or rent a render farm.
                          Jackson
                            Also, at work, I've grabbed hold of all the old computers which has been replaced by newer models. Instead of throwing them away I've hooked them up to a renderfarm. It's only five old P4 2.6GHZ-3.2GHZ comps, but they sure help when deadline is looming.
