    [Plugin] Import STL files
    40 Posts 18 Posters 50.5k Views 18 Watching
    • W Offline
      watkins
      Dear Didier,
      Many thanks for all your hard work. Any chance of a STEP (*.stp, .step), or an IGES (.igs, *.iges) exporter, or is this not an appropriate export file format for Sketchup? It would be nice to be able to export a 'surface' model from Sketchup, and then import it as a surface model into a 3D CAD application (Inventor, Pro/E etc) for further modelling.
      Regards,
      Bob
      • Didier BurD Offline
        Didier Bur
        Wow ! IGES and STP are muuuuuccccchhhh more complex than STL...
        DB
        • W Offline
          watkins
          Dear Didier,
          I imagine so or someone would have done it by now. It was just something to put on the wish list.
          Regards,
          Bob
          • E Offline
            Eric_J
            Hello Didier
            This file does not seem to work for me, and I have some questions?
            1. The file appears to be in binary format. Do I need to have it in ASCII format to use it on a Mac?
            2. On a Mac, exactly which "plugins" folder should the file be placed? I can find at least two. (Library/Application Support/Google SketchUp 6/SketchUp/plugins and Applications/SketchUp.app/Contents/Plugins)
            3. The file has an ".rb" extension. Double clicking the binary file attempts to open the application RealBasic, for which I do not have a license. Do I need to purchase a license for RealBasic or would that be resolved by having the file in ASCII format?
            Many thanks in advance for any assistance.
              remus
              1. and 3) a .rb is really jsut a text file. You should be able to open it in any plain test editor, like notepad on windows (not sure what the mac equivalent is)
              2)Not sure about this one, im sure a more mac savy person will come along and tell you where to put it.
              • E Offline
                Eric_J
                OK, it seems to work when put into Library/Application Support.../plugins, and it seems to export properly!
                Thanks again!
                • H Offline
                  Howard leslie
                  Didier,
                  If possible, could you adjust your script so it mines down into all groups and components and converts all data in a model to *.stl ??? (or a *.sat file ???)
                  Additionally, all stl objects are to retain the sketchup group and component names.
                  I know TIG has produced several very useful scripts with this mining ability that dig down into all groups and components.
                  Some of his code could possibly help ???
                  This would make your script so much more useful
                  Anything you can do, hugely appreciated.
                  Regards
                  Howard L'
                    Didier Bur
                    I'll see what I can do. Code exists also in su2pov for instance so it is just a question of time (which is hard to find these days for me...)
                    Regards,
                    DB
                      casey344
                      First, thank you for posting the utility - getting this to work will save us so much time.
                      My STL file is not importing properly. I get the prompt to specify scale then a jumbled version of what I am importing. See image below.
                      I am using Sketchup 7.0. Any ideas what I am doing wrong?
                      Thank you.
                        Didier Bur
                        Not at all. It can be aproblem with SU7, or a problem with the STL file. Post it here so I can check it.
                        Regards,
                        DB
                          casey344
                          Thanks for offering to help.
                          You should be able to pick it up here ...
                          Link to file:
                          https://download.yousendit.com/bVlCSXR3Mm1wTVYzZUE9PQ
                            Didier Bur
                            AAARGGHHHH 71 Mb !
                            Downloading it now, but I guess the file is too big for SU...
                            DB
                              casey344
                              Sorry, not my doing. πŸ˜•
                              Manufacturer sent it that way.
                                jwelin
                                Thanks for the work on this plugin. I have a three questions:
                                Is there a limit to the level of nested groups/components it exports?
                                The exported STL seems to be incompatible with some applications. Rhino sees the geometry, for instance, while Magics does not. Also an SU2stl generated stl, opened in Rhino and resaved as an STL is much smaller in file size. Would you like to see examples?
                                Is there a way to call this plugin from another? I have a need to batch export.
                                John Welin
                                architectural model maker
                                Chicago, USA
                                  Didier Bur
                                  There are several STL formats which slightly differ in their syntax. The one I have choosen to export is the most standard one, as defined here for instance:
                                  http://www.gom.com/CONTAINER/files/sp_stl_en.pdf
                                  or here:
                                  http://mech.fsv.cvut.cz/~dr/papers/Lisbon04/node2.html
                                  Maybe some applications do not support every kind of STL ?
                                  I don't have Rhino, but I suppose that it saves an STL in the binary format, while my script saves it in ASCII (text), which is 8 times bigger (average). You can see the same differences between an ascii dxf and a binary dxf (dxb) for instance.
                                  No. Not tested here but as a recursive method is involved, there should be no limits.
                                  Components are NOT supported, groups are.
                                  Unfortunately no.
                                  Regards,
                                  DB
                                    I found that recursive methods might cause SU to bugsplat. http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15585&p=120726 I had a method that looped over entities to find connected entities which used a recursive method. Had to change it to an iterative method.
                                      Didier Bur
                                      Bad news 😞
                                      DB
                                        Mind you, it happens when you do many recursions. When crawling geometry you quickly end up with hundreds iterations. So if the script never goes that deep you're ok. But it's something to be aware of.
                                        • N Offline
                                          NewOne
                                          When exporting STL from SolidWorks, here is an option to put all geometry in same file or to create separate file for each part. Mr. Didier Bur, could this script to be modified in a manner that allows multiple file selection and each geometry to be made group (or component if there are more identical parts) ? Or to specify a folder where stl part files are located?
                                          Thank you.
                                            Didier Bur
                                            Dropped into the to-do list πŸ˜‰
                                            DB
