    [Plugin] Selection Toys
    594 Posts 121 Posters 552.5k Views 121 Watching
      HM.. that's odd. I'm not actually sure you you mean either when you say "right click selection tools grey out".
      You get no right-click menu?
        By the way Kyprus: if you have the Ruby Console open and that thing happen, do you get messages then?
        • K
          Kyprus
          I get a right click menu but most of it greys out when
          I know they should be there.
          Yes, I have a ruby console. Not sure why. I haven't had
          the time nor patience to figure it all out. I'll place
          the plug-in back in the proper directory and see if there
          is anything in the console.
          I did have to use the plug-in. so, I placed it back
          into the plugins directory, I forgot about it and it
          happened again. but once I deleted it out of the directory
          re-started SU all was fine. This doesn't happen right away.
          it takes time for it to arise. but, it has happen twice
          but solved when I delete the .rb . (this was earlier today/
          last night).
          But I will see if anything is in the console next time. ๐Ÿ˜‰
            Please let me know if you get any messages in the console. I've not yet seen that behaviour. As you say, it could be conflicting with another plugin which I might not have installed.
            Also, could you take a screenshot when it happens?
              I just experience this myself now. That'll make it easier for me to track down what's going on.
                I believe I might have sorted out the disabled menu problem.
                Would you mind testing the plugin for me to see if it's sorted for sure? Send me a PM with your email.
                • K
                  Kyprus
                  thomthom: Apologies for not getting that screenshot to you.
                  I just haven't had the time. ๐Ÿ˜ž
                  I downloaded the the new version I'll put it in today
                  and give it a run. Thank you. ๐Ÿ˜‰
                  My email is kyprusplacid [at] g.mail dot com . I have gtalk.
                  so, once you send me an email you will be on my IM.
                  we can talk then, if you have gtalk.
                    email sent
                    • K
                      Kyprus
                      This is the screenshot of the app., with the grey-out
                      on the right-click tools.
                      http://picasa***.google.com/kyprusplacid/SU?authkey=yW_XtO3TIMw&feat=directlink
                      There was nothing in the Ruby console.
                      Not sure if I'm suppose to type something
                      in there or not to get feedback. Nore
                      would I know what to type.
                      Guess this isn't much help.
                      this is with the new update by the way.
                        No worries. I saw it myself when I used the plugin quite a bit. I did some changes and after that it appeared to be gone. That's what I'll be sending you tomorrow.
                          Updated with some important bug fixes to prevent bugsplats.
                          A couple of extra select variations added.
                            By request http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16665, added filters for entities with Default material.
                            • dazzaD
                              dazza
                              Cool, thanks Thomas!
                              All people have the right to stupidity but some abuse the privilege.
                                jmmad
                                Thxs Thomas this plugin is a must ๐Ÿ˜„
                                Get Upa !
                                  Added selection methods for Dynamic Components. Same as regular components, except it allows you to select by DC family.
                                    Fixed an issue where the DC menu would not appear if there was only one instance of the DC variant.
                                    • cmeedC
                                      cmeed
                                      Does your selection tools, or is it possible in general, to select an adjacent edge after selecting a single edge in an exploded curve? then the next and so on by clicking (with your 'tool' selected) arbitrarily rather than finding little edges, zooming in clicking, paning clicking etc - finally the curve is completely selected or as much of it as you want, you can use weld.
                                      this would help with complex models and tight spaces.
                                      c
                                        c
                                        Not currently. But it's something I have on my todo list.
                                        • cmeedC
                                          cmeed
                                          it would make a nice accompaniment to the weld tool.
                                          • simon le bonS
                                            simon le bon
                                            Hey Thomas ๐Ÿ˜Ž ,
                                            Native Selection tool of SketchUp is at the same time so powerfull and so poor. Your "Toys" increase incredibly its possibilities. I have had not to use those, concerning selection with components or groups for now but,
                                            The idea of your "Select Loop" is really amazing (and time saver)! I like it a lot ๐Ÿ‘
                                            But more and moreover what seems especially important to me is your "Selection Modifier" : which makes possible to make a new selection into an existing selection. Since the beginning i'm using SU, i think it's something which definitively misses as a native option !!!!
                                            Here with this work, I discover you as a masterclass rubymaker ๐Ÿ˜ฎ ๐Ÿ‘ ๐Ÿ‘
                                            ,simon
                                            • 29
                                            • 30
                                            • 2 / 30
