    [Plugin] Selection Toys
    594 Posts 121 Posters 528.2k Views 121 Watching
      Kyprus
      kwistenbiebel: Not sure I'm to keen on that type of selection.
      Primarily due to the fact that there is allot of screen-play
      to get to some of the polygon that are not in view. I still
      believe that just hitting the "plus" or "minus" keys would
      quicken the procedure.
      I'm not really new to this idea, I can't even take credit. The
      conceptual idea I got it from was Wings3D. "In my opinion", Wings3D
      is the most easiest 3D software ever made. I used it for years.
      but unfortunately it doesn't have one thing I do like, the means
      to use metric or feet. It's based on a numerical choice = if 2.0
      is two inches or if 20.0 is two inches, so be it. Then no matter
      what you have decided taking it into another software, (such as
      SU), you still have to re-size. So, I use SU to do most, if not all
      of my Mesh work now.
      As for some of the selection ideas:
      I think I may have a list to assist. Yet, I warn you that
      I would be compiling this list from what I have used in
      Wings3D for it's simplicity.
      Edge Loop: Selecting only the vertices's in a loop.
      Similar: Selecting only the polygon with the same dimensions.
      Edge Loop Region: Selecting the vertices's and highlighting the
      polygon(s) that are on one end from this loop selection.
      Invert Selection: (Speaks for itself but I will elaborate).
      Say, you have a square with only one polygon selected, but
      you want the others selected instead.
      There are many others I could list, (but) I don't want to over
      do it. Sadly, I could only direct you to view Wings3D for
      additional tools, (Its free) >lol<
      Thank you for your responce. And again, thank you very
      much for the additional tool/plugin.
        Haven't tried Wings3D. But I'm always up to try new tools.
        I've had some play around with the trial of Modo and I like some of the selection tools present there.
          Kyprus
          Yeah Modo looks sweet, kinda' reminded me of Blender,
          you know the one you have to be a micro physicist.
          I will/can say, Wings3D doesn't do all that. It's just
          a simple modeler/mesh manipulator.
          I presently use Strata for rendering. Although, I
          haven't had to do much rendering of late.
          SU has definitely made things easier for me, I thought
          I was going to be stuck with Wings, until I stumbled
          across SU.
            Kyprus
            ThomThom: I downloaded the update on your "selection toys".
            After a while my right click selection tools grey out and
            I cannot select anything. Never had this problem so I took out
            the plug-in and things worked fine.
            This might be a conflicting with another plug-in I have
            but the version I had before didn't cause this problem.
            Not sure which version it was. might be simple to add the
            version # to the .rb when you update.
            Not sure if anyone else is having this issue.
            Thought you would like to know.
              HM.. that's odd. I'm not actually sure you you mean either when you say "right click selection tools grey out".
              You get no right-click menu?
                By the way Kyprus: if you have the Ruby Console open and that thing happen, do you get messages then?
                  Kyprus
                  I get a right click menu but most of it greys out when
                  I know they should be there.
                  Yes, I have a ruby console. Not sure why. I haven't had
                  the time nor patience to figure it all out. I'll place
                  the plug-in back in the proper directory and see if there
                  is anything in the console.
                  I did have to use the plug-in. so, I placed it back
                  into the plugins directory, I forgot about it and it
                  happened again. but once I deleted it out of the directory
                  re-started SU all was fine. This doesn't happen right away.
                  it takes time for it to arise. but, it has happen twice
                  but solved when I delete the .rb . (this was earlier today/
                  last night).
                  But I will see if anything is in the console next time. πŸ˜‰
                    Please let me know if you get any messages in the console. I've not yet seen that behaviour. As you say, it could be conflicting with another plugin which I might not have installed.
                    Also, could you take a screenshot when it happens?
                      I just experience this myself now. That'll make it easier for me to track down what's going on.
                        I believe I might have sorted out the disabled menu problem.
                        Would you mind testing the plugin for me to see if it's sorted for sure? Send me a PM with your email.
                          Kyprus
                          thomthom: Apologies for not getting that screenshot to you.
                          I just haven't had the time. 😞
                          I downloaded the the new version I'll put it in today
                          and give it a run. Thank you. πŸ˜‰
                          My email is kyprusplacid [at] g.mail dot com . I have gtalk.
                          so, once you send me an email you will be on my IM.
                          we can talk then, if you have gtalk.
                            email sent
                              Kyprus
                              This is the screenshot of the app., with the grey-out
                              on the right-click tools.
                              http://picasa***.google.com/kyprusplacid/SU?authkey=yW_XtO3TIMw&feat=directlink
                              There was nothing in the Ruby console.
                              Not sure if I'm suppose to type something
                              in there or not to get feedback. Nore
                              would I know what to type.
                              Guess this isn't much help.
                              this is with the new update by the way.
                                No worries. I saw it myself when I used the plugin quite a bit. I did some changes and after that it appeared to be gone. That's what I'll be sending you tomorrow.
                                  Updated with some important bug fixes to prevent bugsplats.
                                  A couple of extra select variations added.
                                    By request http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16665, added filters for entities with Default material.
                                    • dazzaD Offline
                                      dazza
                                      Cool, thanks Thomas!
                                      All people have the right to stupidity but some abuse the privilege.
                                        jmmad
                                        Thxs Thomas this plugin is a must πŸ˜„
                                        Get Upa !
                                          Added selection methods for Dynamic Components. Same as regular components, except it allows you to select by DC family.
                                            Fixed an issue where the DC menu would not appear if there was only one instance of the DC variant.
                                            • 29
                                            • 30
                                            • 2 / 30
