    SU or ...? for hard surface modeling
    33 Posts 16 Posters 4.7k Views 16 Watching
    • Gus RG Offline
      Gus R
      Here's the KT render. You should be able to see the fillet at the junction of the bump out and the basin.
      Gus
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        Nice one, Gus! πŸ‘
        • Gus RG Offline
          Gus R
          Thank you Gaieus. Guess my insomnia serves a purpose.
          πŸ˜„
          • daleD Offline
            dale
            Yes great work folks, I knew this would be a fun one to watch. πŸ‘
              RustyShack
              Gus ....you nailed it!! cheers to you!!
              I agree--that looks spectacular and relatively easy to model. When I tried using subdivide and smooth initially, I could not figure out how to control the subdivision. I was trying to draw elaborate grids etc etc and nothing seemed to work. Never occurred to me that a few well-placed control lines like the ones in your model would do the job.
              I will give this a go later today and see how it goes.
              • soloS Offline
                Oh yeah, Gus got it pretty right! πŸ‘
                Remember me saying it looks like a Kohler Botticelli?, well out of curiousity I went to the Kohler site and there it was, I attach a link below, scroll down and click on the 'for installers and designers' tab and a .dwg becomes available for download, it's the actual model which can be opened up in SU for you to use.
                Enjoy.
                http://www.us.kohler.com/onlinecatalog/detail.jsp?item=8038302&section=2&category=16
                OMG!!! see the price 😲
                • Gus RG Offline
                  Gus R
                  Thanks guys. Pete, thanks for the link. I might try doing one to scale later since this one was eyeballed.
                  Modelhead, for another $500 you can also get one (1) towel bar. Throw in a tooth brush/cup holder for another $500 and you can have all three for $6,000!
                  πŸ˜†
                  • StinkieS Offline
                    Stinkie
                    "$3,286.00 and up" Fruitcakes. πŸ˜†
                    Gus, Pete: cool tuts. Thanks.
                    • Gus RG Offline
                      Gus R
                      Stinkie, thanks.
                      Pete, great work by the way as usual. So, how did you make the water?
                      Gus
                      • soloS Offline
                        I hope I am not hijacking this thread, I believe the issue of the basin is solved so here is how I do splashes:
                        I have made these before and posted someplace on this forum. Anyway I use SDS and FFD to create the shape (nothing fancy there) however SDS can increase the poly count to something unusable in SU so be careful.
                        I normally make it in SU then export to Vue and texture it there and save it as an object for later use.
                        Here is a snap of a very simple one I created today as an example, I deleted the .skp of the one used on the first page as I saved it as a .vob (Vue object) so there was no need to keep the SU one which was very high poly anyway.
                        And if you want i attached the .skp too.
                        http://img58.imageshack.us/img58/389/solosplashno3.jpg
                        splash.skp
                        • EarthMoverE Offline
                          EarthMover
                          Thanks Pete. This is helpful. I was working on creating a splashfoot for a waterfall right before I came across this thread. Funny how life works.
                          Content Creator at Skapeup
                          • FrederikF Offline
                            Frederik
                            Yeah... Thanks a lot, Pete..!! πŸ‘
                            Much appreciated..!! πŸ˜‰
                            Cheers
                            Kim Frederik
                            • Gus RG Offline
                              Gus R
                              Pete,
                              Thanks, looks great.
                              Ever do one using a milk material?
                              Gus
                              • 2 / 2
