    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 82.3k Views 36 Watching
    • CadFatherC Offline
      CadFather
      ..i need more info - are you using a mac?
        me3mar
        i am using pc windows xp pro - Sp 3 -
        ram 4 g.
        quad core 2,4 GH.
        sketchup 7
        thank you again
        me3mar
          CadFather
          if the system is good it should work - if you have multiple copies of the same plugins as the ones included in the powertoolbar (protrude etc) you can get into problems
          start from this, making sure these are the only contents in the plugins folder (back up the old one)
          if it works reintroduce the others by elimination
          301 Moved Permanently
          (www.sketchucation.com)
            me3mar
            i had to move all the rubys manualy and cleanup a little, and it works fantastic!!
            thanks CadFather for your help
            me3mar
            • FletchF Offline
              Fletch
              Great work on those tus Cadfather! 👍
              I realized I'm working with the 'old' protrude... didn't realize it had such great improvements - gotta go get it now 😎
              Fletch
              • N Offline
                numerobis
                WOW!!! very cool! thank you! 😄
                • EdsonE Offline
                  Edson
                  max,
                  in order to install this toolbar i removed all my plugins and started moving them back carefully in order no to have double copies. in doing so i realized that another toolbar you made (ARCHILAND toolbar) has a folder called CD_ICONS, the same name of the icons folder for the powertoolbar. my question: is it ok to have both folders with the same name? will not there be some confusion between them? what should i do?
                  http://www.mahfuz.arq.br
                  • EdsonE Offline
                    Edson
                    after all i did not manage to install it. the same error message as BTM reported appears to me.
                    oddly enough, why does the ARCHLAND toolbar installs without any problems and the POWERTOOLBAR does not?
                    individually, all the scrips run on my mac.
                      bellwells
                      @edson said:
                      max,
                      Edson, there will be a problem with 2 folders the same name as you'll be asked if you want to replace the old with the new, which you do NOT want to do! What I did was simply place the contents of the PowerToolbar CD_ICONS into the other CD_ICONS folder (or vice versa) by copy all and paste.
                      Max, thanks for another great addition to SU!!!!
                      Ron
                        CadFather
                        hi Edson, the two plugins have different subfolders inside CD_ICONS (architect and power). you should have 1 cd_icons folder and inside it, the 2 subfolders.
                        i think the parsing errors reported can be easily fixed but i do not have a mac to check/fix - some kind master with a mac could look into it perhaps?
                        the quick other option is to disable the plugins which cause the error - if you can report the full text of the ruby console i will try later..
                          chango70
                          OMG, Cadfather, why can't Google hire you!? I am always amazed by how professionally thought out your tools (interface at least) are! Thank you. 😍
                            CadFather
                            thanks Chango, though without the masters we would only have a 'nice' interface... 😉
                            (..there's more cooking in the oven..) 😉
                            • X Offline
                              xrok1
                              i think it would be great (not that its not great already, but greater yet) if we could have just one SCF Toolbar & then pick and choose which ruby's we want in it, like a visual plugin bar that could be customized with any of the tools from your series of toolbars (mix and match).
                              any chance of this? 😉
                                Amazing and cool design! 😎
                                A list here of Plugs used will be useful 😉
                                • Chris FullmerC Offline
                                  Tiffs don't work on the forum John. Use a file format more common to the web like jpg, or png works great.
                                    BTM
                                    tiff works on the forum
                                    ...but maybe only on macs... 😉
                                    Anyways, I had the same problem too. I no longer have the SCF powertoolbar.
                                      That is very interesting. I never knew that. They do not show up on PC's. Good to know,
                                      I've never liked the tiff format and I don't know why.
                                        BTM
                                        I don't like it much either. Same, I don't know why. I like PNG the most 👍
                                          driven
                                          has any one got this fully running on a mac??
                                          i get this error, functionality of some of the tools
                                          PowerBarErrormessage.tiff
                                          ++jpeg
                                            Sir
                                            the link to your website is broken btw
                                            • 3 / 4
