    Testers Arise - RpEdits - new free add-on for SketchUp
    28 Posts 8 Posters 5.0k Views 8 Watching
    • Al HartA
      Al Hart
      @jean-franco said:
      Al, thanks for your clear explanations.
      I continue to use your tool and I'll see if the problems I mentioned appear again.
      RpEdits is really a nice collection of tools.
      What I appreciate the +++ is the stretch tool.
      Thanks again and Merry Christmas !
      Thanks,
      I hope you noticed that when the move, stretch, or rotate wizard has focus (just click on the title), then you can use the arrow keys (and shift up/down for Z) to nudge the item to the location or size desired.
      We can also map the arrow keys when SketchUp has focus to do the same. But we weren't sure if it was worth it - since it works well if you give the Edit Wizard focus - and because some people may already have the arrow keys mapped to something else in SketchUp.
      readers - What do you think?
      (added later: Oops! When I read the +++ in your message, I thought you meant hitting the arrows repeatedly to perform the operations more than once. But I see now you meant "the most". Still, it is good to let readers know that they can use the keyboard arrows and small increments to "nudge" items as desired.)
      Al Hart
      IRender nXt from Render Plus
      • Jean-FrancoJ
        Jean-Franco
        Effectively I meant "the most" sorry for that 😳
        Jean-Franco
        • Jean-FrancoJ
          Jean-Franco
          Al, thanks for your clear explanation.
          I continue to use your tool and I'll see if the problems I mentionned appear again.
          Jean-Franco
          • Jean-FrancoJ
            Jean-Franco
            Al, is it possible to have the UnDo command in the Stretch Selection Tool as in some others ?
            Jean-Franco
            • Al HartA
              Al Hart
              I'll give it a shot. That would be good for the tab which stretches to specific sizes because it could re-read and re-display the dimensions after the undo of any size change.
              Al Hart
              • Al HartA
                Al Hart
                Thanks for RpEdits, it's a great tool. Have a nice holiday season.
                You too - Al
                Great work Al! This is a nice add on even for experienced users. You continue to be an amazing contributor to the community and I would just like to say thanks.
                Have a great holiday!
                You too - Al
                Al Hart
                • Jean-FrancoJ
                  Jean-Franco
                  That's exactly the main reason why I ask for.
                  Would be great if you can.
                  Jean-Franco
                  • kenK
                    ken
                    Do let me know if it fails with a new drawing with a single face in it.
                    I need to know whether it fails all the time, or just sometimes.
                    Also, open the SketchUp Ruby Console before loading or running RpEdits. It may give us a clue as to what is going wrong.
                    Thanks,
                    Al
                    Mr. Hart
                    Well I found the problem. I had an old out of date Rp_Tools installed. When I remove this script the Rp_edit script worked great.
                    Note I PM you a couple of video files showing how the program worked before I discovered what the problem was. So please disregard these video files.
                    Thanks for the great script.
                    Ken
                    • DamaTheCatD
                      DamaTheCat
                      Al,
                      We purchased a Mac to get started on Mac versions - but we still have a lot to learn, and a long, long, way to go.
                      Hey, I was "PC" from the mid 80's until last year....... If I can make the switch anyone can...... By-the-way,,, I LOVE THE MAC!!!! One of the best things I've done...
                      Please keep going on the RpEdits......
                      Thanks for the reply....
                      Mike
                      Every Day I Try To Be The Person My Dog Thinks I am.......
                      • B
                        bellwells
                        Thank you very much, Al. I haven't had a chance to use it yet, but I look forward to doing so.
                        Ron
                        • david_hD
                          david_h
                          This is a great tool. Seems to work fine for me. I clicked on "Load RPEdits when Starting. . . " etc but it doesnt load on startup. What am I doing wrong?
                          D
                          • Al HartA
                            Al Hart
                            I don't remember if I implemented that feature or not. I'll take a look.
                            Al Hart
                            • david_hD
                              david_h
                              Here's another question . .. On the mirror tool, how does one mirror and object about a specific point, say the mid point of some line, a la the mirror.rb?
                              Thanks,
                              David
                              • Al HartA
                                Al Hart
                                I have "load rpedits when starting Sketchup" checked, (in rpedits start window), but I still have to load it every time I open Sketchup. It's just a bit annoying, please help.
                                I just fixed this and will try to upload a new version today.
                                Apparently this function is useful to you. Can you offer any suggestions for improvements?
                                Al Hart
                                • Al HartA
                                  Al Hart
                                  Thanks,
                                  David
                                  The mirror tool was designed to mirror placements of workstations - for instance converting left handed desks to right handed desks.
                                  In order to do a mirror through a point, you would have to mirror x,y and then z, and then move the new item to the desired location.
                                  Al Hart
                                  • Al HartA
                                    Al Hart
                                    We released a new version of RpEdits. - IA23t
                                    The main fix is that the "Load RpEdits when starting SketchUp" checkbox works.
                                    Al Hart
                                    • david_hD
                                      david_h
                                      Startup works now for me. Thanks! Great tool.
                                      With your input, this post could be even better šŸ’—
                                      • 2 / 2
