    Testers Arise - RpEdits - new free add-on for SketchUp
    28 Posts 8 Posters 4.7k Views 8 Watching
    • Al HartA
      Al Hart
      If you want to remove it temporarily, remove RpEdits_loader.rb from your SketchUp\plugins folder or use the install script to uninstall it.
      RpEdits shares some files in c:\program Files\Render Plus Systems\RpTools.
      If you are completely done with both RpEdits and RpTools, you can remove that folder as well.
      If you ever want either of them back, you can just reinstall the one desired.
      Al Hart
      IRender nXt from Render Plus
      • Al HartA
        Al Hart
        Here is what I see during the mirror operations
        Ken
        Edited
        Well I guess I am going to have to figure out how to add a AVI file
        Do let me know if it fails with a new drawing with a single face in it.
        I need to know whether it fails all the time, or just sometimes.
        Also, open the SketchUp Ruby Console before loading or running RpEdits. It may give us a clue as to what is going wrong.
        Thanks,
        Al
        Al Hart
        • Al HartA
          Al Hart
          @jean-franco said:
          Al, thanks for your clear explanations.
          I continue to use your tool and I'll see if the problems I mentioned appear again.
          RpEdits is really a nice collection of tools.
          What I appreciate the +++ is the stretch tool.
          Thanks again and Merry Christmas !
          Thanks,
          I hope you noticed that when the move, stretch, or rotate wizard has focus (just click on the title), then you can use the arrow keys (and shift up/down for Z) to nudge the item to the location or size desired.
          We can also map the arrow keys when SketchUp has focus to do the same. But we weren't sure if it was worth it - since it works well if you give the Edit Wizard focus - and because some people may already have the arrow keys mapped to something else in SketchUp.
          readers - What do you think?
          (added later: Oops! When I read the +++ in your message, I thought you meant hitting the arrows repeatedly to perform the operations more than once. But I see now you meant "the most". Still, it is good to let readers know that they can use the keyboard arrows and small increments to "nudge" items as desired.)
          Al Hart
          • Jean-FrancoJ
            Jean-Franco
            Effectively I meant "the most" sorry for that 😳
            Jean-Franco
            • Jean-FrancoJ
              Jean-Franco
              Al, thanks for your clear explanation.
              I continue to use your tool and I'll see if the problems I mentionned appear again.
              Jean-Franco
              • Jean-FrancoJ
                Jean-Franco
                Al, is it possible to have the UnDo command in the Stretch Selection Tool as in some others ?
                Jean-Franco
                • Al HartA
                  Al Hart
                  I'll give it a shot. That would be good for the tab which stretches to specific sizes because it could re-read and re-display the dimensions after the undo of any size change.
                  Al Hart
                  • Al HartA
                    Al Hart
                    Thanks for RpEdits, it's a great tool. Have a nice holiday season.
                    You too - Al
                    Great work Al! This is a nice add on even for experienced users. You continue to be an amazing contributor to the community and I would just like to say thanks.
                    Have a great holiday!
                    You too - Al
                    Al Hart
                    • Jean-FrancoJ
                      Jean-Franco
                      That's exactly the main reason why I ask for.
                      Would be great if you can.
                      Jean-Franco
                      • kenK
                        ken
                        Thanks,
                        Al
                        Mr. Hart
                        Well I found the problem. I had an old out of date Rp_Tools installed. When I remove this script the Rp_edit script worked great.
                        Note I PM you a couple of video files showing how the program worked before I discovered what the problem was. So please disregard these video files.
                        Thanks for the great script.
                        Ken
                        • DamaTheCatD
                          DamaTheCat
                          Al,
                          We purchased a Mac to get started on Mac versions - but we still have a lot to learn, and a long, long, way to go.
                          Hey, I was "PC" from the mid 80's until last year....... If I can make the switch anyone can...... By-the-way,,, I LOVE THE MAC!!!! One of the best things I've done...
                          Please keep going on the RpEdits......
                          Thanks for the reply....
                          Mike
                          Every Day I Try To Be The Person My Dog Thinks I am.......
                          • B
                            bellwells
                            Thank you very much, Al. I haven't had a chance to use it yet, but I look forward to doing so.
                            Ron
                            • david_hD
                              david_h
                              This is a great tool. Seems to work fine for me. I clicked on "Load RPEdits when Starting. . . " etc but it doesnt load on startup. What am I doing wrong?
                              D
                              • Al HartA
                                Al Hart
                                I don't remember if I implemented that feature or not. I'll take a look.
                                Al Hart
                                • david_hD
                                  david_h
                                  Here's another question . .. On the mirror tool, how does one mirror and object about a specific point, say the mid point of some line, a la the mirror.rb?
                                  Thanks,
                                  David
                                  • Al HartA
                                    Al Hart
                                    I have "load rpedits when starting Sketchup" checked, (in rpedits start window), but I still have to load it every time I open Sketchup. It's just a bit annoying, please help.
                                    I just fixed this and will try to upload a new version today.
                                    Apparently this function is useful to you. Can you offer any suggestions for improvements?
                                    Al Hart
                                    • Al HartA
                                      Al Hart
                                      Thanks,
                                      David
                                      The mirror tool was designed to mirror placements of workstations - for instance converting left handed desks to right handed desks.
                                      In order to do a mirror through a point, you would have to mirror x,y and then z, and then move the new item to the desired location.
                                      Al Hart
                                      • Al HartA
                                        Al Hart
                                        We released a new version of RpEdits. - IA23t
                                        The main fix is that the "Load RpEdits when starting SketchUp" checkbox works.
                                        Al Hart
                                        • david_hD
                                          david_h
                                          Startup works now for me. Thanks! Great tool.
