    Apples ( play whit UV ruby
    34 Posts 14 Posters 5.7k Views 14 Watching
    • N Offline
      nomeradona
      good one majid....
        archkiranjith
        great renders majid!!!
          bahjon12
          great looking renders......
          could you post the link for uv ruby ??.....
          would really appreciate it......
            remus
            404 Not Found
            (www.sketchucation.com)
            Good apples btw, i dont suppose you could post these in the components forum? I think theyd liven many a fruit bowl.
              Jackson
              Fantastic UV work Majid, did you create the textures yourself? Is each apple all one texture? I'm intrigued how you textured the concave part of the apple around the stalk as I didn't think the UV ruby would help with that?
              Jackson
                @majid said:
                hi all ,i did a try whit uv ruby to texture these apples ,what a usefull ruby , hope to be improved soon . cheers...
                What do you want to improve on these fantastic apples, my friend?
                You, as a Muslim, should precisely know that only the Almighty is perfect and these apples are already pushing those boundaries dangerously! ๐Ÿ‘
                • majidM Offline
                  majid
                  hi all friend ,and so aorry for late answer ,
                  i did some more renders , and think one of them is better ....
                  http://i44.tinypic.com/153qryg.jpg
                  http://i43.tinypic.com/25gx7k1.jpg
                  and also here is the skp ( including small tut on texture editing and preparing in PS )(a have zipped it).
                  cheers majid
                  miz2.zip
                    Jackson
                    Thanks Majid, excellent renders and very generous of you to share the textured model and tutorial. ๐Ÿ˜„
                    Jackson
                    • majidM Offline
                      majid
                      thank u all for your kind words , ... also i used other maps for shinness and bump map in kt , and sorry for not to sharing them .... but I hope the tutorial can help u to make your own textures...
                      majid
                        Teezer
                        I love the first one. The out-of-focus foreground gives it a seriously close-up feel, and the lighting on the dented apple in the back is perfect. ๐Ÿ‘
                        This image belongs on one of those "you won't believe it's not a photograph" postings that pop up on DIGG every now and then... ๐Ÿ’š
                        Real life is just another website, albeit a rather boring one.
                        • MALAISEM Offline
                          MALAISE
                          Thank you Majid for sharing your know-how. Very close to reality theses apples. How long did you work on such a drawing ? It's near perfect ๐Ÿ‘ ๐Ÿ‘
                          MALAISE
                          La Connaissance n'a de valeur que partagรฉe
                          • majidM Offline
                            majid
                            MALAISE
                            sorry for so late answer ... First i take a foto using my cellphone and about 2 days later i started the modeling and texturing .. it tooke me about half day , and 2 or 3 hours for rendering ( to finde a true material setting + lights - also i made a HDRI file as background_).
                            cheerss majid
                            • romboutR Offline
                              rombout
                              http://i34.tinypic.com/2rnhmz7.jpg
                              http://i37.tinypic.com/9zqbk3.jpg
                              http://i33.tinypic.com/xel6vc.jpg
                              cheers majid
                              wow this is great. i also understand the mapping in photoshop.... but how did you map it correct in SU, im missing that part
                              • Z Offline
                                zumo
                                well done these are the most realistic thing I have seen on sketch up to date!
                                • FrederikF Offline
                                  Frederik
                                  You should take a closer look at the [Plugin] UVTools v0.1 thread... ๐Ÿ˜‰
                                  Cheers
                                  Kim Frederik
                                  • romboutR Offline
                                    rombout
                                    oke... but how do you apply it to a mesh. cause the top and the side of the apple is at a different place. how do you place it on your mesh
                                    • romboutR Offline
                                      rombout
                                      i understand the wrapping but how does the "top" of the apple wrap at the the top of the mesh. If you open the map in PS you'll see a image skin in width and the top of the apple somewhere at the left
                                      • majidM Offline
                                        majid
                                        It is all about good texturing . I've made a mini tutorial and shared it at previos page . it's name is "MIZ2" . please take a closer look at it. i guess it'd help you
                                        • romboutR Offline
                                          rombout
                                          oke oke oke...
                                          you dont get it.... atleast i dont get it... i understand everytihing about making a map and so... but if you have your mesh and you apply your map. How do you get the top of the apple at the correct place and the side at the side. You need to apply a map to the mesh unwrap this with a different application and than put your mapping to that unwrapped image. but this is not written in the tut
                                          • majidM Offline
                                            majid
                                            UVTool v1.0 is very simlpe . it doesnt unwrap , but simply it adds 2 new commands to your right-click menu that lets you to have "spherical" or "cilinderical" mapping to your mesh, it desn't undersyand which mesh you have selected, but remaps it as a sphere or a cilinder. it desnt separate mesh parts
