    [Plugin] Selection Toys
    594 Posts 121 Posters 565.5k Views 121 Watching
      wow another old request of mine you've made a reality, so it converts all "similar" groups into instances of a component?!!! i wonder if i would be the only one to make use of this script when i made this request i got a lot of technique suggestions 😒
      Didn't know it was requested. heh 😄
      It will only convert the groups that are copies of each other. If you where to even just open up one of the group copies SU breaks the link and makes it unique. Even though you've not actually after anything. In fact, SU will even make the group unique if you select the group, minimize SU then restore the window. Go figure...
      I suppose it would be possible to compare the content of each group and calculate which ones are 'similar' even though SU claims they are unique. But, I think that'd have to be for when I'm getting more warmed up with this Ruby thing.
      • free agentF
        free agent
        yup the thread was called [Req] Similar groups to Components, i bumped it for your viewing pleaure.
        http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          Ah, wonder how I missed such a recent thread on this. Oh well.
          So did you also want to make a selection of instances into individual group?
          • free agentF
            free agent
            ? no just similar groups to components... 👍
            • bagateloB
              bagatelo
              Very good, I like the script very much.
              Maybe you can improve the script by make loop selection also in horizontal, not only vertical.
                @bagatelo said:
                It has not concept of horizontal or vertical. Effectively if you have a cube, select an horizontal line to get a vertical selection, select a vertical line to get a horizontal selection.
                It simply starts with the faces on either side of the edge you select and keeps on selecting the opposite faces and edges.
                • bagateloB
                  bagatelo
                  I'm sorry to not explain corret to you, before.
                  http://i37.tinypic.com/29yfwqq.jpg.gif
                    Ah, yes. I understand now. I will be looking into more looping variations. But no guaranties. This first type was very easy to do.
                    btw, what application did you use to create the animation?
                    • FletchF
                      Fletch
                      Thanks Thomas!
                      please only update original post with new plugin release... now I'm confused which is latest version of the ruby I should d/l thanks.
                      re: converting similar groups to components - I seconded the request! and I will use it!
                      re: loop selection... I have desired this many times... we will see how well it works in practice 😄
                      Fletch
                        @earthmover said:
                        Right on Thomas! Thanks for your efforts! Now if I can only get that damn loop selection tool. 😄
                        Here's a beta of version 1.1.1b.
                        (beta removed. obsolete)
                        Highlight one edge and click 'Select Loop'.
                        I've only tried this is faces of four sides. The script currently make this assumption as well, so I don't know how it behaves if you throw in less or more edges.
                        Here's my test model:
                        loop selection test.skp
                          Sorry for the confusion. The one I posted further down in this thread was a beta. Experimental. After some more testing making sure it did what it should do I updated the one in the original post. To avoid further confusion I've removed the other versions now.
                          Yea, I've not tried it out on very irregular cases. Not sure how it will handle really weird geometry. In order to improve the edge/face selection tool I need to study more the SU API on how to deal with edges, faces and determining their direction and relationships. If anyone with some experience would like to jump in and add some more tools I'd be most happy.
                          • U
                            urs0815
                            thank you for this useful tool!
                            • G
                              GUNAWAN W
                              thank's a milion Thomas.
                              • bigstickB
                                bigstick
                                Nice one Thomas! This should improve my productivity no end! 👍
                                • K
                                  Kyprus
                                  Hello:
                                  New to the forum. Had to join when I found this tool.
                                  Saves me a ton of time. Thanks for the plug-in. 😃
                                  I was however wondering if there is a plug-in that
                                  once you have selected a bunch of polygon's that you
                                  could evenly subtract or add to your selection by using
                                  the "plus" and "minus" keys. I'll try to elaborate a bit.
                                  Say you have a a rectangle evenly divided into five
                                  sections you select the end polygon and you can then press
                                  the "plus" key and it will select the polygon's next to it.
                                  Then you can press the "minus" key to subtract. this would
                                  work the same as if you used the "select/connection faces"
                                  in the right click menu, but sadly there is no subtracting.
                                  The reason for this request is = if you have allot of
                                  polygons selected, and you move the selection and you want
                                  to subtract a row of polygon, you have to unselect all,
                                  reselect one row less and make change and repeat each time.
                                  Unless I'm missing something that pre-exists in SU
                                  already, this would be great.
                                  • jim smithJ
                                    jim smith
                                    Thanks Thomas, I will find being able to turn a number of groups into components very usefull. 😄
                                    "Out of clutter find simplicity,
                                    from discord find harmony,
                                    In the middle of difficulty lies opportunity"
                                    Albert Einstein
                                      Updated with some more selection tools.
                                        @kyprus said:
                                        Hello:
                                        This is one of the things I'd like to add. I have a few more ideas for selection tools that are a bit more interactive allowing the user to play around with the selection.
                                        • K
                                          kwistenbiebel
                                          @Kyprus and ThomTom:
                                          Actually that is how you do it in the Maxwell Studio.
                                          I don't find it the best way though.
                                          The way Cinema4D does it, is much handier:
                                          You just hover above the geometry while holding the left mouse button.
                                          Every polygon your hovering mouse touches will get selected. Holding shift adds to the selection and Holding CTRL will substract from the selection.
                                          It's a perfect tool which is called 'Soft selection Tool' in modelers lingo.
                                          You can use it to select polygons, lines or points.(before you do the soft selection you click polygon mode, edges mode or vertices mode).
                                          Works like a charm...
                                          It is quite strange that no one thought of making a ruby like this for Sketchup.
                                          Especially when you know that Fredo6 uses parts of that principle in his Surface Tools plugin.
                                          By the way: @ThomTom: Very nice Plugin you made there 👍
                                          Thanks for that.
                                            To me soft selection is a different matter. I used 3DS Max previously and if you do a soft selection it's like you select with a soft feathered brush. vertexes at the far edge of the selection is affected less when you do modification such as move or rotate on the selection.
                                            I'd very much like to hear different ideas of doing selections.
                                            One of the things I'd like to make is that after you have make your 'master selection' you can use modifier keys to toggle between edges, faces.
                                            I think what would be useful is a set of selection tools which when you activate them you can choose if they add to or subtract from your existing selection.
                                            • 29
                                            • 30
                                            • 1 / 30
