    SketchUp game exporter (Source)
    extensions
    120 Posts 32 Posters 46.4k Views 32 Watching
      linea
      My former colleague has experimented with using the Crisis Sandbox and importing skp. He was inspired by the digital urban blog demonstration too. I don't know how much time he spent on it but he was underwhelmed with the results. I can't remember many details but I think there are certain on-screen windows and buttons (part of the game) that he could not figure out how to hide.
      If you search on Digtal urban for Oblivion (another game) the potential for utilising that looks better.
      • RichardR Offline
        Richard
        Wow I downloaded the Cry2 trailer!!! Man if that is the realtime render environment that can be expected viewing a SU scene who needs a renderer!
        So has anyone been playing with walk throughs with the cry sandbox editor. BTW can the camera motion be set and how does one produce an animation? Via screen capture?
        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
          kwistenbiebel
          I bought Crysis 4 months ago with the purpose to use the sandbox editor and try some Archviz with it. (the XSI mod tool as in between app).
          To be honest, the workflow was way too tedious and I soon gave it up.
          It would have been a different story if one could export straight from SU to the sandbox editor with all mats in place.
          Oh, and another thing: you can't use the output you get from Crytek engine commercially without license, meaning you need to keep your archviz in house or just provide it as free documentation to a client.
          A license costs tens of thousands of dollars/euros 😄.
          • RichardR Offline
            Richard
            Wow thats a disappointment! really!
            I had high hopes that this would be a fast animation opportunity! Would be interesting though to read the license. It could be more in reference to charging for play??
            Yes the direct export from SU would be welcomed! Though unless you can use it for commercial purposes then little to be gained!!!
            • Z Offline
              zapwizard
              Update for you guys: There is now a much easier and faster way to import SketchUp models into SandBox2 (Crysis engine)
              The program is a basically a Calloda to CryEngine2 converter.
              See my thread here:
              http://www.crymod.com/thread.php?postid=394096#post394096
              Source model:
              http://tinyurl.com/5gjd42
              http://farm4.static.flickr.com/3288/3057474115_32c0134bdf.jpg
                remus
                Thats pretty sweet. I might have to rope my friend in to testing a few models out for me.
                Cheers for developing this 👍
                • jujuJ Offline
                  juju
                  I guess this means I'll have to buy both Crysis and Crysis Warhead now. Awesome excuse!
                  • Z Offline
                    zapwizard
                    Just a reminder: If you want to try this out without buying, the Crysis demo comes with the full editor. (But not as many 3D assets as the full game)
                    The editor is not updated for Crysis warhead, although it is apparently coming sometime.
                    However you can import most of the Crysis warhead assets into the current editor.
                    The biggest thing I am going to be using SketchUp for is buildings and props, which is a huge part of any game.
                    • jujuJ Offline
                      juju
                      Now to get whatever one may have compiled in Sandbox2 back out and into SU. I suppose that poses as many issues as using the Sandbox2 tool with (or without) custom built models for commercial purposes.
                      • PixeroP Offline
                        Pixero
                        Just some basic question.
                        I tried exporting a house and all I got was a yellow ball.
                        What am I doing wrong? 😕
                        Do I need to explode every thing or turn it into a components or...
                        • Z Offline
                          zapwizard
                          I have exported items with multiple components with no issue. Some more complex models I exploded and then cleaned up. Make sure and purge any unused items before export.
                          A messy model that uses lots of intersecting hidden lines may not work well.
                          Ideally a game ready model should be a solid model with no hidden lines, no lines that pass through faces. Basically the same tips that Google shows in their "How to model for Google Earth" tutorials. All texture dimensions need to be a multiple of 64 along their dimensions (128x128, 256x512, etc...)
                          Crysis uses .DDS (direct draw) textures, so I convert all the textures using Paint.net.
                          When you first import the object it won't have any textures.
                          In SandBox2 open the Material Editor, select "get current material"
                          You will see a list of material id's, inside there will be a texture path.
                          The texture path will end up looking like "file://..images/texture0.jpg"
                          Change that to the correct path for the .dds replacement.
                          For portability to other people's computers, you should keep your textures and model files under either "crysis\game\levels\YOU LEVEL\objects" or in a similar \Mod directory.
                          I suggest you try exporting the spitfire linked in my thread first to get the hang of it.
                            sella
                            Is it possible to export SU model to Far Cry 2 sandbox? Or am I too greedy?
                            • PixeroP Offline
                              Pixero
                              Another silly question. Where in Sandbox do I import the object?
                              The only place where I can see it is under vegetation which surely isnt right, eh?
                              Under Brushes or entities I cant see it.
                              I've placed it under Game/Levels/mylevel/models and also tried placing it under editor/Objects.
                                remus
                                No you cant currently import SU models in to far cry 2, maybe one day 😉
                                • PixeroP Offline
                                  Pixero
                                  No I meant Ive converted it to a cgf file but still dont know where and how to do to import it in Sandbox.
                                    remus
                                    I dont think you can...
                                    Not officially anyway.
                                    • Z Offline
                                      zapwizard
                                      Something I was working on today
                                      http://farm4.static.flickr.com/3072/3063073832_4f63b816c4.jpg
                                      Wall-E is hours of work getting a good model that would be optimized in for a game. He is still far from finished though.
                                      I used parts from a few different Wall-E's in the 3D warehouse.
                                      sella, FarCry2 does not have a sandbox editor (It was not made by Crytek)
                                      FarCry2 only has a very basic sim-cities style map editor.
                                      SandBox2 from Crytek is more of a whole game editor.
                                      Pixero, once you have your CGF in the \Game\wherever folder, place a "brush" entity.
                                      Then change the model of that brush to the CGF you created.
                                      Though my work today I discovered that components don't export, but groups do.
                                      Wall-E up there is made of 22 separate components exported and converted.
                                        cadmunkey
                                        Did anyone else on these forums manage to produce anything with the Crysis engine from sketchup models?
                                          StarWarsKnower
                                          Sorry I just wanted to say, thanks for sharing this plugin! It's great! I've got a small job making props for a mod called 'Aperture-M', a multiplayer portal.
                                          Mike
                                          • Chris FullmerC Offline
                                            I never ended up trying because Crysis runs so slow on my comp. I should try it though, just to get it working.
                                            • 6 / 6
