    SketchUp game exporter (Source)
    extensions
    120 Posts 32 Posters 56.4k Views 32 Watching
    • jujuJ Offline
      juju
      I guess this means I'll have to buy both Crysis and Crysis Warhead now. Awesome excuse!
      • Z Offline
        zapwizard
        Just a reminder: If you want to try this out without buying, the Crysis demo comes with the full editor. (But not as many 3D assets as the full game)
        The editor is not updated for Crysis warhead, although it is apparently coming sometime.
        However you can import most of the Crysis warhead assets into the current editor.
        The biggest thing I am going to be using SketchUp for is buildings and props, which is a huge part of any game.
        • jujuJ Offline
          juju
          Now to get whatever one may have compiled in Sandbox2 back out and into SU. I suppose that poses as many issues as using the Sandbox2 tool with (or without) custom built models for commercial purposes.
          • PixeroP Offline
            Pixero
            Just some basic question.
            I tried exporting a house and all I got was a yellow ball.
            What am I doing wrong? ๐Ÿ˜•
            Do I need to explode every thing or turn it into a components or...
            • Z Offline
              zapwizard
              I have exported items with multiple components with no issue. Some more complex models I exploded and then cleaned up. Make sure and purge any unused items before export.
              A messy model that uses lots of intersecting hidden lines may not work well.
              Ideally a game ready model should be a solid model with no hidden lines, no lines that pass through faces. Basically the same tips that Google shows in their "How to model for Google Earth" tutorials. All texture dimensions need to be a multiple of 64 along their dimensions (128x128, 256x512, etc...)
              Crysis uses .DDS (direct draw) textures, so I convert all the textures using Paint.net.
              When you first import the object it won't have any textures.
              In SandBox2 open the Material Editor, select "get current material"
              You will see a list of material id's, inside there will be a texture path.
              The texture path will end up looking like "file://..images/texture0.jpg"
              Change that to the correct path for the .dds replacement.
              For portability to other people's computers, you should keep your textures and model files under either "crysis\game\levels\YOU LEVEL\objects" or in a similar \Mod directory.
              I suggest you try exporting the spitfire linked in my thread first to get the hang of it.
                sella
                Is it possible to export SU model to Far Cry 2 sandbox? Or am I too greedy?
                • PixeroP Offline
                  Pixero
                  Another silly question. Where in Sandbox do I import the object?
                  The only place where I can see it is under vegetation which surely isnt right, eh?
                  Under Brushes or entities I cant see it.
                  I've placed it under Game/Levels/mylevel/models and also tried placing it under editor/Objects.
                    remus
                    No you cant currently import SU models in to far cry 2, maybe one day ๐Ÿ˜‰
                    • PixeroP Offline
                      Pixero
                      No I meant Ive converted it to a cgf file but still dont know where and how to do to import it in Sandbox.
                        remus
                        I dont think you can...
                        Not officially anyway.
                        • Z Offline
                          zapwizard
                          Something I was working on today
                          http://farm4.static.flickr.com/3072/3063073832_4f63b816c4.jpg
                          Wall-E is hours of work getting a good model that would be optimized in for a game. He is still far from finished though.
                          I used parts from a few different Wall-E's in the 3D warehouse.
                          sella, FarCry2 does not have a sandbox editor (It was not made by Crytek)
                          FarCry2 only has a very basic sim-cities style map editor.
                          SandBox2 from Crytek is more of a whole game editor.
                          Pixero, once you have your CGF in the \Game\wherever folder, place a "brush" entity.
                          Then change the model of that brush to the CGF you created.
                          Though my work today I discovered that components don't export, but groups do.
                          Wall-E up there is made of 22 separate components exported and converted.
                            cadmunkey
                            Did anyone else on these forums manage to produce anything with the Crysis engine from sketchup models?
                              StarWarsKnower
                              Sorry I just wanted to say, thanks for sharing this plugin! It's great! I've got a small job making props for a mod called 'Aperture-M', a multiplayer portal.
                              Mike
                              • Chris FullmerC Offline
                                I never ended up trying because Crysis runs so slow on my comp. I should try it though, just to get it working.
                                  ryansumei
                                  Yea I have, But only very basic models. And I haven't worked out textures. Also once inside the building the walls disappear, weird.
                                  But having much more fun doing the topographical height maps at the moment and using standard models.
                                  ยฎyan
                                  • N Offline
                                    Nintari
                                    Check out the latest alpha of PlayUp. You can export to SB2 directly from SU now, although collision isn't in yet.
                                    • RichardR Offline
                                      Richard
                                      Sorry mate what is "PlayUp" and "SB2"?
                                      BUILTBRAND.COM.AU
                                        remus
                                        Im guessing this is what is being referred to: http://playuptools.com/
                                        • RichardR Offline
                                          Richard
                                          Yeah just worked it out! Dumb is me!
                                          BUILTBRAND.COM.AU
                                          • O Offline
                                            oalexis
                                            thanks so much zapwizard! ๐Ÿ˜„ i'm going to put this to use for sure. Just imported a little pagoda into the sandbox ๐Ÿ˜„
                                            • 3 / 6
