    Photo Match for Professional Architectural Photomontages
    27 Posts 14 Posters 9.1k Views 14 Watching
      Hi Harch,
      Check this topic out:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=13477
      Pretty convincing IMO.
        @harch84 said:
        Hi all,
        I would really love to use Sketchup for this photomontaging but am a bit concerned as to its accuracy as it doesnt require camera location, focal lenght etc.
        It does, but it's determined by the way you set up the vanishing points. I've used it many times to set up accurate matches. But I don't like the Photomatch tool because I find it very awkward to match existing models to photos. It's preferred that you got a right angled corner with the photo taken about 45 degrees onto the corner. And that just doesn't work most of the times. More often than not I don't have perfect 90 degree corners and 45 degrees into the corner is not the position from where we want to present it. And that makes the matching more difficult. I much rather have 3DS max's method of placing matching points on the model, then their equal position on the photo and have the application work out the camera position from that. (Made a feature request of this.)
        So yes, it's possible. But awkward.
          We hardly have any "box" like buildings here so I don't really use it either (just tried out a couple of times to make sure I could if I wanted).
          • dcauldwellD Offline
            dcauldwell
            I am an architect involved with small domestic extensions and I am using it all the time. As thomthom says once you have created a model it is a bit tricky to then match it to a photo, but it is only a matter of technique. It is easier if you start with the photograph - but I nearly always forget to do that!
            Here is an example
            (the modelled and vray rendered part is the rear single storey extension)
            http://img146.imageshack.us/img146/4769/5108002crop2mh3.jpg
            David
            Sketchup 2017
            (vray 2.00)
              That's a nice one!
              In my work I only tried to use it once (I cannot attach it now) when from the remaining walls of a 16th century Ottoman mosque I had to do a reconstruction. It was merely to show how it would look related to its environment because we are hoping to rebuild it in reality (although later I decided to model all the surrounding buildings instead).
              • E Offline
                ehaflett
                I've found that using the photo as a watermark in the background can be helpful in finding the angle at which to output your model graphic. It's not as accurate as Photomatch may be but it's helpful when combining your graphics in PS or Corel.
                  As plot says the photo-match tool is not very efficient. Don't get me wrong SU itself is fantastic for photomantage.
                  The method above can actually be duplicated with SU and Corel and probably PS as well.
                  When I have very difficult mapping to do I take a shot of the piece within SU. I bring it into Corel set it down as a layer. I then creat my material layer over top and cut the material to match the SU image below. I import the texture and apply it....it fits like a glove and if not you can adjust it further by repositioning using the texture positioning tool.
                  I don't use Photomatch to map textures, but to match the camera so I can render the model in V-Ray and merge the images in Photoshop.
                    linea
                    As dcauldwell said I think photomatch is really good for smaller buildings. I don't think that 3d Studio or AutoCad are significantly more accurate though when it comes to complex geometry. I tend to just go out with the camera and photograph every elevation I need and then apply them all as textures to an estimated or measured model. it takes longer but it is much more accurate
                      Now I am confused?
                      Are we talking about using photomatch just to extract textures, or photomatch to display a model in actual context? I thought the OP was talking about the latter.
                        linea
                        Yes, sorry, drifted away from the thread a bit there
                          dcauldwell
                          Personally I wouldn't hesitate to use it for small or large buildings.
                          Although it doesnt require camera location, focal length etc, the technique it uses is equally as good - matching persective.
                          It gets easier to set up if the photo you are matching is taken at approx 45deg on plan, but clearly this is often not possible - so you make do.
                          As photographs are often flawed in some way (barrel or pincushion distortion) it still comes down to making final adjustments by eye.
                          For the record, the process I use is:-
                          a) on site take several photos, guessing at where you will prefer your viewpoint for the finished montage
                          b) create the model and match it to the photo in SU
                          c) render the model (I use vray)
                          d) export the render (I use png files)
                          e) Using photoshop (or equiv) paste into a new layer over the photo - sometimes you need to create further layers and copy foreground info so it displays in front of the rendered model.
                          Its dead easy once you've done a couple of times!!
                          David
                          Sketchup 2017
                          (vray 2.00)
                          • plot-parisP Offline
                            plot-paris
                            dcauldwell, amazing image. it took me quite a while to understand which part is not real 👍
                            • I Offline
                              idraft
                              I found and saved these a while ago, very good show on how to set up perspectives (as tought in the old school days). 👍
                              Cheers Jeff
                              2pt overview
                              2pt matching
                              3pt overview
                              3pt construction
                              3pt matching
                                Cool tuts! 😎
                                Will be a classic! 😎
                                • I Offline
                                  idraft
                                  A quick sample of my photo matching, this was done in SU6 in about 1 hr straight from an origonal photo, can give clients a very good ex. of what there addition looks like.
                                  I had to model the letterbox, fence and tree in foreground then locate in photomatched model. The picture probably needs fixing up in photoshop / gimp or similar to take some edges of.
                                  cheers Jeff
                                  photo match 0
                                  photo match 7
                                  • MALAISEM Offline
                                    MALAISE
                                    Thanks for such a useful tut. It really explains perspective rules . 👍 👍
                                    I'm translating it in French
                                    MALAISE 😄
                                      GUNAWAN W
                                      @dcauldwell said:
                                      Here is an example
                                      David
                                      So david,
                                      where is your models?
                                      it's seems like photograph for me 😄
                                        dcauldwell
                                        G
                                        Here is the rendered model. It is then merged in with the photograph in PS.
                                        The mirror ball in the foreground was to check out the HDR sky, to see if it was positioned correctly.
                                        Cheers David
                                        http://img381.imageshack.us/img381/5998/004oz1.png
                                        Sketchup 2017
                                        (vray 2.00)
                                        • marked001M Offline
                                          marked001
                                          the other problem with photomatch for me, is that is creates a 2 point perspective or some odd setup.. which isnt supported by Maxwell... so its useless... my workaround is to use photomatch..tape a piece of trace to the screen.. trace over a few key edges... and then use that to create my own scene... 😉 haha..
                                          http://www.revision21vis.com
                                          instagram: revi21on
                                            dcauldwell
                                            . . . and if you make a mistake, do you use correction fluid on the screen? I'd love to see you working on a sketch!
                                            I think SU actually creates a 3 point perspective, but because most photos are taken at eye level they look like 2 point.
                                            David
                                            Sketchup 2017
                                            (vray 2.00)
