    [Plugin] Remove group materials, leave geometry material
    88 Posts 27 Posters 62.2k Views 27 Watching
      My earlier 'GlobalMaterialChange' script works on a selection: so by using Didier's filter tools you could just have what you want selected [e.g. Groups] and 'change all' materials in that to <default>. It can 'mine' into a group or component to change things within it too...
      http://www.sketchucation.com/forums/scf/viewtopic.php?p=96863#p96863
      Or am I missing something ?
      • free agentF Offline
        free agent
        while on the subject of helping out vray, vray SR1 creates vray materials of all materials in the scene even the materials on lines (multi-coloured from CAD imports) could there also be a script to remove all materials from lines? that way vray wouldnt create any unnecessary materials
          Matt666
          Hi all!
          Sorry for the delay, I was in London last week...
          So:
          it would actually apply the group material to the default geometry itself
          Yes, it's possible. I will add a message box to the script.
          p.s. I have one suggestion for your script above, maybe it would be better if it was named "Remove_CG_Mat" as ""Delete_CG_Mat" sounds like it would delete/purge those materials from the actual skp file, which might make people a little reluctant to use it.
          Ok!
          Yes, it's possible. Vray uses attributes to record all object material. You just want to remove it.
          I just need for time to do that πŸ˜„
          Frenglish at its best !
          My scripts
            Jackson
            Matthieu,
            You are the man! If you can produce a ruby script which removes group materials and applies them to the default geometry you will save me about 3 day's work on this model alone! I'm trying to update my portfolio so this would be of enormous benefit to me as I've got lots to do and very little time to do it.
            http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/Malm1.jpg
            Jackson
              Matt666
              To Free Agent, can you share an example with Vray line material, please ?
              Thank you !
              My scripts
                Jackson
                Matthieu,
                Free Agent means SUs own materials on lines, there's no separate VRay materials- it just creates/links it's own materials from those of SU. A standard skp model will contain the line materials Free Agent is describing.
                Free Agent,
                When SU imports dwgs and adds materials to lines (i.e. layer materials from Autocad) just delete those materials either by right-clicking on them in SU's material editor or (if there's lots of them) by opening the imported dwg group, switch to wireframe view, select all, paint with the default SU material and then purge the file. This will also delete all unnecessary VfSU materials.
                Jackson
                  Matt666
                  Ok, but I will wait for Free agent answer to do smt πŸ˜„ !
                  I've updated post of the script with demanded improvments... I did'nt really test it... πŸŽ‰
                  My scripts
                    Jackson
                    Matthieu,
                    I just ran it on this fairly simple model, but unfortunately it has applied the wrong materials to the groups, see before and after image below. I thought it might be applying materials from higher up the group heirarchy, but that doesn't seem to be the case. Any idea what's going wrong? I can send you the skp file if you like.
                    http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/HouseRemoveCGMaterialsTest.jpg
                    Jackson
                      Matt666
                      Can you send me the skp, please?
                      Thank you !
                      Sorry, I don't have a lot of time to test... 😞
                      My scripts
                        Jackson
                        Here's the Rapidshare link:
                        404 Not Found
                        (rapidshare.com)
                        LOL, definitely no need to apologise!
                        Jackson
                          Matt666
                          Hi Jackson !
                          I don't forget your demand !!
                          I have no time to do smt now, and I have a problem of "Hierarchy" in your drawing example... So it's quite difficult !
                          But I think I will show smt in a few days..
                          See you soon !
                          My scripts
                            Jackson
                            Matthieu,
                            No worries, your original "Remove CG Materials" script has already saved me about 20 hour's work so I'm pretty happy already!
                            Best regards,
                            Jackson
                            Jackson
                              Matt666
                              We loosed some posts here 😞
                              So, script's post has been updated... Not tested enough, but I'm a few confident ! πŸ˜„
                              Now all Comp/Groups materials are transfered to geometry if you want.
                              My scripts
                                Jackson
                                Seems to work perfectly Matthieu! I just ran it with the test file I sent you and it reassigned all the materials in just a few seconds. This is such a valuable little tool for "VRay for SU" users, I will spread the good word (and your name) over at the ASGvis forums.
                                Many many thanks for creating this little gem, MERCI BEAUCOUP!
                                Jackson
                                Jackson
                                  Matt666
                                  πŸ˜„
                                  You're welcome, Jackson ! Glad to help you !
                                  My scripts
                                  • plot-parisP Offline
                                    plot-paris
                                    thanks so much, Matthieu! 😍
                                    only one minor thing still: while all the materials are applied to faces and the material of the outer group is changed to default, nested groups still keep their assigned material. that is not very important, because the face's textures are the dominant ones. but to be perfectly accurate, it would be great if the plugin could assign the default material to nested groups too.
                                    one positive side effect I experienced is, that your plugin coloures front and back faces. that is really good!
                                      Matt666
                                      Hi plot-paris !
                                      ok, that's been updated !
                                      Thank you for testing !
                                      My scripts
                                        plot-paris
                                        damn, you are fast! now the plugin is flawless. fantastic! thank you so much!!!
                                        • V Offline
                                          vinchvinchvinch
                                          Hi!
                                          Matt, you are already a legend in ASGvis forum!
                                          Thank you man!
                                          πŸ‘
                                            Jackson
                                            LOL, you guys are a two-man developer and beta team!
                                            Great work, I'll link this thread over at ASGvis.
                                            Jackson
                                            • 2 / 5
