    [Plugin] Remove group materials, leave geometry material
    88 Posts 27 Posters 71.2k Views 27 Watching
      Jackson
      Matthieu,
      You are the man! If you can produce a ruby script which removes group materials and applies them to the default geometry you will save me about 3 day's work on this model alone! I'm trying to update my portfolio so this would be of enormous benefit to me as I've got lots to do and very little time to do it.
      http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/Malm1.jpg
      Jackson
        Matt666
        To Free Agent, can you share an example with Vray line material, please ?
        Thank you !
        Frenglish at its best !
        My scripts
          Jackson
          Matthieu,
          Free Agent means SUs own materials on lines, there's no separate VRay materials- it just creates/links it's own materials from those of SU. A standard skp model will contain the line materials Free Agent is describing.
          Free Agent,
          When SU imports dwgs and adds materials to lines (i.e. layer materials from Autocad) just delete those materials either by right-clicking on them in SU's material editor or (if there's lots of them) by opening the imported dwg group, switch to wireframe view, select all, paint with the default SU material and then purge the file. This will also delete all unnecessary VfSU materials.
          Jackson
            Matt666
            Ok, but I will wait for Free agent answer to do smt πŸ˜„ !
            I've updated post of the script with demanded improvments... I did'nt really test it... πŸŽ‰
            My scripts
              Jackson
              Matthieu,
              I just ran it on this fairly simple model, but unfortunately it has applied the wrong materials to the groups, see before and after image below. I thought it might be applying materials from higher up the group heirarchy, but that doesn't seem to be the case. Any idea what's going wrong? I can send you the skp file if you like.
              http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/HouseRemoveCGMaterialsTest.jpg
              Jackson
                Matt666
                Can you send me the skp, please?
                Thank you !
                Sorry, I don't have a lot of time to test... 😞
                My scripts
                  Jackson
                  Here's the Rapidshare link:
                  http://rapidshare.com/files/160279614/House_TEST.skp.html
                  LOL, definitely no need to apologise!
                  Jackson
                    Matt666
                    Hi Jackson !
                    I don't forget your demand !!
                    I have no time to do smt now, and I have a problem of "Hierarchy" in your drawing example... So it's quite difficult !
                    But I think I will show smt in a few days..
                    See you soon !
                    My scripts
                      Jackson
                      Matthieu,
                      No worries, your original "Remove CG Materials" script has already saved me about 20 hour's work so I'm pretty happy already!
                      Best regards,
                      Jackson
                      Jackson
                        Matt666
                        We loosed some posts here 😞
                        So, script's post has been updated... Not tested enough, but I'm a few confident ! πŸ˜„
                        Now all Comp/Groups materials are transfered to geometry if you want.
                        My scripts
                          Jackson
                          Seems to work perfectly Matthieu! I just ran it with the test file I sent you and it reassigned all the materials in just a few seconds. This is such a valuable little tool for "VRay for SU" users, I will spread the good word (and your name) over at the ASGvis forums.
                          Many many thanks for creating this little gem, MERCI BEAUCOUP!
                          Jackson
                          Jackson
                            Matt666
                            πŸ˜„
                            You're welcome, Jackson ! Glad to help you !
                            My scripts
                            • plot-parisP
                              plot-paris
                              thanks so much, Matthieu! 😍
                              only one minor thing still: while all the materials are applied to faces and the material of the outer group is changed to default, nested groups still keep their assigned material. that is not very important, because the face's textures are the dominant ones. but to be perfectly accurate, it would be great if the plugin could assign the default material to nested groups too.
                              one positive side effect I experienced is, that your plugin coloures front and back faces. that is really good!
                                Matt666
                                Hi plot-paris !
                                ok, that's been updated !
                                Thank you for testing !
                                My scripts
                                • plot-parisP
                                  plot-paris
                                  damn, you are fast! now the plugin is flawless. fantastic! thank you so much!!!
                                  • V
                                    vinchvinchvinch
                                    Hi!
                                    Matt, you are already a legend in ASGvis forum!
                                    Thank you man!
                                    πŸ‘
                                      Jackson
                                      LOL, you guys are a two-man developer and beta team!
                                      Great work, I'll link this thread over at ASGvis.
                                      Jackson
                                        @jackson said:
                                        Matthieu,
                                        somewhat off topic, but: where did you get hold of the ground texture?
                                        • W
                                          watkins
                                          Could someone explain exactly what this script does, and what are the benefits? It would help the technically challenged, like myself.
                                          Kind regards,
                                          Bob
                                            It makes sure that no materials are applied to groups and components. It will either remove the materials of groups and components or transfer them to the geometry.
                                            For users of V-Ray for SketchUp it has the benefit of faster parsing time and more reliable outcome as VfSU struggles to get correct data for groups and components with materials applied to them.
                                            • 1 / 5
