    Driving Dimensions
    extensions
    70 Posts 21 Posters 31.6k Views 21 Watching
    • BurkhardB Offline
      Burkhard
      Thanks Dmitry for sharing it. Will give feedback by time.
      And welcome to SCF
      http://www.ia-plus.de
        Hi Dmitry and welcome!
        Thanks for the feedback and for this plugin! 👍
        • MALAISEM Offline
          MALAISE
          Really usefull, I sketch models and then I can scale them with accuracy.
          Thanks a lot Dmitry 👍 👍
          And a good morning to all Friends
          MALAISE
            What? Good morning at half past ten? 😲
            I was up and working at 5:30 already! 😒
            • MALAISEM Offline
              MALAISE
              @Gaius
              At this moment, somewhere on the planet, the sun is just rising 🤣
              MALAISE 😄
                But you are in the same time zone as me 😒
                  ktkoh
                  I must be a little slow. I downloaded driving dim and it shows up in tools but I can't figure out how to create driving dim. I need some help to get started.
                  Keith
                  • F Offline
                    fefillo
                    Here's a little mini tutorial I just made. Hopefully it will explain the basics of the tool.
                    Start playing with that and then go on and try moving faces around and then clicking the "Recalculate Model with Driving Dimensions" button to see your model adjust itself to match your changes and the "Driving Dimensions" you previously set.
                    BTW, this tool is great! 😍
                    Now... if we could get some angles too, then I wouldn't be missing much from my SolidWorks days. 😉
                    • Fefo
                      sepo
                      video tut
                      http://drivingdimensions.com/SketchUp/videos.php
                        Dmitry Ushakov
                        Keith
                        You can use Help/Driving Dimensions Help from the top menu to access the online help on this plugin.
                        Here is the direct link to the help page: http://drivingdimensions.com/SketchUp/help.php
                        It's great!
                        Sincerely yours,
                        Dmitry Ushakov
                        Director of Product Management
                        LEDAS Ltd.
                        http://www.DrivingDimensions.com - parametric plugins for SketchUp and Rhino
                          dtrarch
                          Dmitry
                          Very interesting concept and thank you for a free look at the plugin.
                          Some feedback for your use.
                          Big bug-splat when deleting a DD dimention.
                          Some unpredictable distortion when more than one DD edit of edges of same face.
                          Perhaps an option for multiple edge selection or ?? for retention of the geometry form.
                          In any case a view and file that I hope will be helpfull
                          Regards
                          dtr Architect
                            dtrarch
                            Dmitry
                            Here is the file
                            dtr
                            DRIVING DIMEN DISTORTION.skp
                              Dmitry Ushakov
                              Thanx for this model, dtr!
                              Currently we collect cases with unexpected solutions to work on them and improve the natural behavior of our solver.
                              So I'd like to know what solution did you expect here?
                              Sincerely yours,
                              Dmitry Ushakov
                              LEDAS Ltd.
                                dtrarch
                                Dmitry
                                I would have expected that the upper segment that was edited would affect the related face and the object would stay in place not rotate and distort/displace.
                                Also the distortion did not occur on an adjacent face that was edited in a similar way.
                                As this is segment driven how would groups and components be parametric without opening same ?
                                A convert to SU mode dimensions & back to DD would be very useful too.
                                2d for layout seems best use for the beta iteration.
                                Just some thoughts.
                                dtr
                                • I Offline
                                  ilay7k
                                  Дмитрий спасибо!
                                  Увидел про вас на блоге Джима Фолтца.
                                  Thank you!
                                    Dmitry Ushakov
                                    dtr,
                                    Thank you for these explanations - we'll definitely take them into account to improve the behavior.
                                    We have some ideas to deal with grouped entities and plan to implement them in the next releases. E.g. point-to-point distance and other driving dimension could be used to position the group w.r.t. other entities. We can also scale the group to satisfy the dimensions. If you have in mind a particular parametric scenario with a group, please share it with us.
                                    It was our first thought when we started the development of this plugin. Unfortunately the built-in SU dimensions are not accessible at Ruby API level.
                                    I don't see what you mean. Could you please describe this in more details?
                                    Thank you very much for these ideas of functional enhancement!
                                    Sincerely yours,
                                    Dmitry Ushakov
                                    LEDAS Ltd.
                                      Dmitry Ushakov
                                      @ilay7k said:
                                      Дмитрий спасибо!
                                      И Вам спасибо за интерес!
                                      А Джим действительно нас первый заметил. И сделал это несколько раньше, чем нам того хотелось 😄
                                      Thank you!
                                      Sincerely yours,
                                      Dmitry Ushakov
                                      LEDAS Ltd.
                                        dtrarch
                                        Dmitry
                                        2d lines can be used to generate 3d walls and as reference for plan development too.
                                        (Also one can convert lines to construction lines and vice-versa with existing scripts for grid and reference use.)
                                        Parametric line adjustment when developing design schemes is very useful.
                                        A constraint to retain the angle at corners would be helpful in this regard.
                                        (a lock corner/angle/geometry function perhaps)
                                        dtr
                                          linea
                                          Thanks. Great ruby.
                                            Dmitry Ushakov
                                            Hello everybody!
                                            We have recently released the second preliminary version (Driving Dimensions 0.2) of our free plugin.
                                            New:
                                            • Support of SketchUp 7 (backward compatibility with SketchUp 6)
                                            • Driving distances (between two vertices, two parallel edges, between a vertex and an edge)
                                            • Driving planar angles (between adjacent edges sharing a common face)
                                            Improved:
                                            • Setting and changing only one circle/arc radius for a cylindrical surface now does not make a conic
                                            • Robustness on large models
                                            You are welcome to use it!
                                            For detailed description, new video and the plugin itself please visit http://www.DrivingDimensions.com
                                            Sincerely yours,
                                            Dmitry Ushakov
                                            LEDAS Ltd.
                                            • 1 / 4
