    [Plugin] SCF TOOLBARS
    49 Posts 32 Posters 67.0k Views 32 Watching
    • CadFatherC Offline
      CadFather
      i have completed the toolbars - here they are - let me know if there are any bugs (but don't be in a hurry!) 😉
      PLEASE SEE UPDATE BELOW
      there are 4 in all:
      standard: replaces the main toolbars with a one stop favourites - it extends to about 1100pixels (so you will miss a couple if you use 1024x768). this may not suit everyone but there are some new things: import export images, copy and paste in place buttons (duplicate).
      select: you can figure this out yourself but of interest is the first - invert selection, it will select all if nothing is selected or viceversa deselect
      archiland: fixed some errors and added more windows from Tomot (there is some strange behaviour in the way the windows are drawn (direction); it works but you will see what i mean.
      draw: as the name says, some useful objects and many fun shapes
      again i included all needed scripts, some of which you may have already - and more importantly again.. this would not be possible without the generosity and sheer genius of the ruby masters! 🤓
      Cheers for now! (i need a holiday now!) ☀
        brechtix
        Hurray! [Applause]
        • dazzaD Offline
          dazza
          Awesome, thanks I really appreciate it!
          All people have the right to stupidity but some abuse the privilege.
          • kenK Offline
            ken
            WOW, all these toolbars. Thanks a million. Just a question. Would it be possible that scripts that are used in a toolbar, be move to a separate directory, so one could remove the scripts from the plugins directory, making the pluging menu smaller.
            Or have I missed something and they can be moved to another directory.
            Again, thank for your toolbars.
            Ken
            • MALAISEM Offline
              MALAISE
              Just amazing, great indeed !
              MALAISE 😄 👍
                CadFather
                Thanks guys! 😄
                Ken - actually most of the scripts are already inside the main scf toolbars files
                (there's a lot of them).
                if you haven't done so already, you can try by backing up the plugins folder, deleting the contents and pasting only the SCFT.
                then you can just bring back your favourite scripts from the back up..
                • by the way, fixed small bug with show layers button and a bit of cleanup
                i also want to 'special' thank Matt and Didier - no frenchy, no scripts! 😉
                2012-08-25 - SCF Toolbars.zip has been removed for causing problems in SketchUp and other plugins. (Jim)
                • kenK Offline
                  ken
                  CadFather
                  I have all the scripts. I just wanted to move the scripts out from the plugin folders so they wouldn’t load when I start Sketchup. This way my plugin menu will be much smaller. Right now my plugin menu goes off the bottom of the screen. So all I was hoping to do is have the scripts where the plugin menu does not read and load the scripts during start up. And still have the toolbar access the scripts.
                  Thanks for all the work. Don't want to seem like someone who does not appreciate all your work.
                  Again thanks
                  Ken
                  @cadfather said:
                  Thanks guys! 😄
                    tomasz
                    Thank you for such a nice compilation!
                    Tomasz
                      mxabucknell
                      Will all of these plugins work on a mac?
                      Just checking, I'm running an XP desktop, but I definitely want to upload these onto my macbook su at some stage...
                      Thanks a load, these are great, whatever.
                      I need to figure out how to make something a graphic buttonny thing... is it particularly hard, cause if I could make graphic versions of my favouite plugins...
                      nah, I'm getting too far ahead.
                      I would be sure to post them on here if I ever got the free time though
                      why 255 characters as a limit? SMF sets 300 by default...
                      and there's no counter to tell me how many I have left... :disappointed:
                        mxabucknell
                        How do you mean?
                        Sorry, I think I've had too much ginger beer, but I don't quite understand what you mean.
                        Sorry again XD
                          thoscon
                          First of all...THANKS!
                          Second of all......pardon my ignorance, but how are these installed?
                            mxabucknell
                            Thas ok, took me ages to work out how to do it-
                            Basically, find the directory of Google Sketchup, which will probably be on tthe C drive on a PC, andon a mac... just search for it..
                            and then you extract the zip into that folder
                              REGIS
                              HD/Library/Application support/Google sketchup/sketchup.
                              Here you can find the plugins folder on a mac.
                                CadFather
                                ..have the scripts where the plugin menu does not read and load the scripts during start up. And still have the toolbar access the scripts.
                                Ken, if you have Jim's rubytoolbar.rb you can place the no-start scripts in a folder inside 'plugins' - then quickly call them up when needed through it.
                                here's my shortened version:
                                sorry i can't help with macs but Thanks everyone - glad you enjoy them!
                                Rubytoolbar.zip
                                  thoscon
                                  THANKS AGAIN! THIS IS FANTASTIC! I'M VERY APPRECIATIVE OF ALL YOUR HARD WORK! 👍
                                  • utilerU Offline
                                    utiler
                                    Hey Max, great work!!!!
                                    A challenge though.... can you work out how to LOCK TOOLBARS!!!!!!!!!!!!
                                    Cheers Mate.
                                    Just Curious...
                                      purplewind
                                      loading file error cd_architect.rb
                                      (eval):4851: D:/Program Files/Google/Google SketchUp 6/Plugins/sketchup.rb:99: undefined method get_i18n_datfile_info' for Sketchup:Module loading error Sketchup.rb undefined method get_i18n_datfile_info' for Sketchup:Module
                                      Could anybody tell me why? Thanks in advance
                                      http://www.sketchupbar.com
                                        CadFather
                                        Cheers Mate.
                                        there is a way Andrew: snap all the gremlins into position on the top row - you will see how easy they behave, then you move the long 'standard' toolbar to the top row and the previous will move a row down. repeat these steps until you have 'sorted' all the rows.
                                        i also do this : http://www.sketchucation.com/forums/scf/download/file.php?id=11937
                                        Purplewind, have tried emptying the folder and only having the SCFT? then if it works you know there is a conflict.
                                          stanmarsh
                                          Thank you CadFather!
                                            BUDLA
                                            CadFather!
                                            SKETCHUP_TOOLBARS_SETTINGS
                                            Very good! 👍 Working in Vista too!
                                            BUDLA
                                            • 1 / 3
