    Church remodel...
    23 Posts 9 Posters 1.9k Views 9 Watching
      johnsenior1973
      If I was on the spending committee of the church I'd be voting to save the money and leave things as they are, rather than remodeling. If you did a Sketchup model of the church as it is now, there would be practically no difference between that and the remodel picture.
      You list the camera, is that a disclaimer for not being able to get the picture in focus?
      Good Sketchup work and style though.
      • StinkieS Offline
        Stinkie
        Nice work. Got a render as well?
        You should add a disclaimer to your posts. "Contains vitriol."
          bubbalove
          John, the company I'm doing this for took all the pictures and imageshack imported the camera info when I uploaded.
          Stinkie, I'll probably do one shortly so I will post when it is finished...
          Durant, I don't know what will happen with the doors... I know I can't use them as I live in a apartment...
          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
            Durant Hapke
            Big Bag BubbaLove,
            That's a lot of clean you have, bring that.
            I would take home the old doors when they pull them, and put them up in your crash crib.
            Little widows are Jack bird cool.
            I dig that action.
            Killer.
            I like the word "Vitriol" -- like acid baby -- not sure I found such in J1973's action response...
            The universe of Churches, and Church goers is a bit of a wild deal -- supernatural as normal.
            Getting some groovy changes is fun -- even if small -- if you are into it.
            I'm sure paint will be involved, so it might look cleaner, but I feel the vibe of "do it."
            Free your mind and Jack bird couple up with the universe.
            Durant "wires go both in and out" Hapke
              bubbalove
              Here is the render... I still need to work on a few things such as the carpet, ceiling, and wall paint! Everything seems to want to turn red because of the carpet and pews and I can't quite get my head around that yet! This is also the first time using IES lights and they definitely look better than the normal spot or pointlights from Kerkythea! Now I just have to try and find more...
              http://img371.imageshack.us/img371/8179/kerkyrendersmallcn8.jpg
              By bubbalove at 2008-10-23
              • DanielD Offline
                Daniel
                Nice looking rendering, David, although I agree the pink glow from the carpet aint too pretty (but then, I detest the color pink). I have one design crit: the casing around the 6-panel doors looks too thin, IMHO. What are the dark squares over said doors?
                My avatar is an anachronism.
                • soloS Offline
                  David, if you change the carpet from a color to a texture it should remove the pink tint in render.
                    bubbalove
                    They are supposed to be speaker screens but I messed up and made them too dark... they were supposed to be the color of the walls... whoooopsies! It's funny you say that about the door casing... as I made it extra thick so the chair rail would die right into to it... maybe its the perspective?
                      bubbalove
                      It is a texture Pete, I also added a bump map to it... I know it is definitely my material settings but I just don't know what to do... anyone with experience in Kerky maybe can help! I will post it in the Kerky boards as well and see if I can get something outta them...
                      • soloS Offline
                        I am not versed in KT, but if there is a way of toning down the Irradiance then you may be able to overcome this.
                        Or a quick color correction in PS should help for a quick fix.
                        http://img293.imageshack.us/img293/1079/kerkyrendersmallcn8ed3.jpg
                          bubbalove
                          Ahh... alright, bout to give it a shot...
                          • DanielD Offline
                            Daniel
                            David, I think the thickness of the casing is fine, but for traditional doors such as those the casing should be wider.
                              bubbalove
                              Ohhh... I'm trying to fix the 'pink' problem right now but I will fix that... client didn't catch that one...
                                bubbalove
                                Well here is the updated render... still got some 'pink' issues but it's not as bad... anyone?
                                http://img133.imageshack.us/img133/6025/kerkyrender2xe2.jpg
                                Pete, I'm not all that good with PS. I changed the hue/saturation for the ceiling on this one... is it any better?
                                • soloS Offline
                                  Definately a lot better, I use paintshop pro (not a PS fanboy), I adjusted the back lighting and flashfill.
                                  http://img528.imageshack.us/img528/135/kerkyrender2xe2ou3.jpg
                                    DzineTech
                                    Like Solo, I aint a KT user but colour bleeding is also an issue with Vray. The workaround is to precalculate the lighting solution with the floor being a white material and you simply switch textures back when it comes to final render and you load the precalculated solution. Not sure if you can do this with KT though πŸ˜•
                                      bubbalove
                                      That looks great Pete! But I would like to be able to do a render and not have to adjust it a whole bunch in photoshop... thanks for your help though...
                                      • DanielD Offline
                                        Daniel
                                        Looking better, David.
