    Church remodel...
    23 Posts 9 Posters 2.5k Views 9 Watching
    • B
      bubbalove
      Here is the render... I still need to work on a few things such as the carpet, ceiling, and wall paint! Everything seems to want to turn red because of the carpet and pews and I can't quite get my head around that yet! This is also the first time using IES lights and they definitely look better than the normal spot or pointlights from Kerkythea! Now I just have to try and find more...
      http://img371.imageshack.us/img371/8179/kerkyrendersmallcn8.jpg
      By bubbalove at 2008-10-23
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • DanielD
        Daniel
        Nice looking rendering, David, although I agree the pink glow from the carpet aint too pretty (but then, I detest the color pink). I have one design crit: the casing around the 6-panel doors looks too thin, IMHO. What are the dark squares over said doors?
        My avatar is an anachronism.
        • soloS
          David, if you change the carpet from a color to a texture it should remove the pink tint in render.
          • B
            bubbalove
            They are supposed to be speaker screens but I messed up and made them too dark... they were supposed to be the color of the walls... whoooopsies! It's funny you say that about the door casing... as I made it extra thick so the chair rail would die right into to it... maybe its the perspective?
            • B
              bubbalove
              It is a texture Pete, I also added a bump map to it... I know it is definitely my material settings but I just don't know what to do... anyone with experience in Kerky maybe can help! I will post it in the Kerky boards as well and see if I can get something outta them...
              • soloS
                I am not versed in KT, but if there is a way of toning down the Irradiance then you may be able to overcome this.
                Or a quick color correction in PS should help for a quick fix.
                http://img293.imageshack.us/img293/1079/kerkyrendersmallcn8ed3.jpg
                • B
                  bubbalove
                  Ahh... alright, bout to give it a shot...
                  • DanielD
                    Daniel
                    David, I think the thickness of the casing is fine, but for traditional doors such as those the casing should be wider.
                    • B
                      bubbalove
                      Ohhh... I'm trying to fix the 'pink' problem right now but I will fix that... client didn't catch that one...
                      • B
                        bubbalove
                        Well here is the updated render... still got some 'pink' issues but it's not as bad... anyone?
                        http://img133.imageshack.us/img133/6025/kerkyrender2xe2.jpg
                        Pete, I'm not all that good with PS. I changed the hue/saturation for the ceiling on this one... is it any better?
                        • soloS
                          Definately a lot better, I use paintshop pro (not a PS fanboy), I adjusted the back lighting and flashfill.
                          http://img528.imageshack.us/img528/135/kerkyrender2xe2ou3.jpg
                            DzineTech
                            Like Solo, I aint a KT user but colour bleeding is also an issue with Vray. The workaround is to precalculate the lighting solution with the floor being a white material and you simply switch textures back when it comes to final render and you load the precalculated solution. Not sure if you can do this with KT though πŸ˜•
                            • B
                              bubbalove
                              That looks great Pete! But I would like to be able to do a render and not have to adjust it a whole bunch in photoshop... thanks for your help though...
                              • DanielD
                                Daniel
                                Looking better, David.
