    Church remodel...
    23 Posts 9 Posters 2.5k Views 9 Watching
    • B
      bubbalove
      They are supposed to be speaker screens but I messed up and made them too dark... they were supposed to be the color of the walls... whoooopsies! It's funny you say that about the door casing... as I made it extra thick so the chair rail would die right into to it... maybe its the perspective?
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • B
        bubbalove
        It is a texture Pete, I also added a bump map to it... I know it is definitely my material settings but I just don't know what to do... anyone with experience in Kerky maybe can help! I will post it in the Kerky boards as well and see if I can get something outta them...
        • soloS
          I am not versed in KT, but if there is a way of toning down the Irradiance then you may be able to overcome this.
          Or a quick color correction in PS should help for a quick fix.
          http://img293.imageshack.us/img293/1079/kerkyrendersmallcn8ed3.jpg
          • B
            bubbalove
            Ahh... alright, bout to give it a shot...
            • DanielD
              Daniel
              David, I think the thickness of the casing is fine, but for traditional doors such as those the casing should be wider.
              My avatar is an anachronism.
              • B
                bubbalove
                Ohhh... I'm trying to fix the 'pink' problem right now but I will fix that... client didn't catch that one...
                • B
                  bubbalove
                  Well here is the updated render... still got some 'pink' issues but it's not as bad... anyone?
                  http://img133.imageshack.us/img133/6025/kerkyrender2xe2.jpg
                  By bubbalove at 2008-10-23
                  Pete, I'm not all that good with PS. I changed the hue/saturation for the ceiling on this one... is it any better?
                  • soloS
                    Definately a lot better, I use paintshop pro (not a PS fanboy), I adjusted the back lighting and flashfill.
                    http://img528.imageshack.us/img528/135/kerkyrender2xe2ou3.jpg
                      DzineTech
                      Like Solo, I aint a KT user but colour bleeding is also an issue with Vray. The workaround is to precalculate the lighting solution with the floor being a white material and you simply switch textures back when it comes to final render and you load the precalculated solution. Not sure if you can do this with KT though πŸ˜•
                      • B
                        bubbalove
                        That looks great Pete! But I would like to be able to do a render and not have to adjust it a whole bunch in photoshop... thanks for your help though...
                        • DanielD
                          Daniel
                          Looking better, David.
                          • 2 / 2
