    Church remodel...
    23 Posts 9 Posters 2.5k Views 9 Watching
    • B
      bubbalove
      I am including this picture to give everyone an idea of what's happenin...
      Before
      http://img397.imageshack.us/img397/9529/092608091id1.jpg
      By bubbalove, shot with KODAK Z730 ZOOM DIGITAL CAMERA at 2008-10-21
      After
      http://img397.imageshack.us/img397/4989/fadededgesmallwa8.jpg
      By bubbalove at 2008-10-21
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • marked001M
        marked001
        nice simple image... new pews? (is that how you spell 'pew'?)
        http://www.revision21vis.com
        instagram: revi21on
        • B
          bubbalove
          No same pews... they're just going to be refinished...
            daarboven
            if this is "find the difference" i'd guess the altar was altered....nice clean style,btw.
            • B
              bubbalove
              Thanks daarboven, they're are a ton of styles floating around on this site as well as FormFonts...
                johnsenior1973
                If I was on the spending committee of the church I'd be voting to save the money and leave things as they are, rather than remodeling. If you did a Sketchup model of the church as it is now, there would be practically no difference between that and the remodel picture.
                You list the camera, is that a disclaimer for not being able to get the picture in focus?
                Good Sketchup work and style though.
                • StinkieS
                  Stinkie
                  Nice work. Got a render as well?
                  You should add a disclaimer to your posts. "Contains vitriol."
                  • B
                    bubbalove
                    John, the company I'm doing this for took all the pictures and imageshack imported the camera info when I uploaded.
                    Stinkie, I'll probably do one shortly so I will post when it is finished...
                    Durant, I don't know what will happen with the doors... I know I can't use them as I live in a apartment...
                      Durant Hapke
                      Big Bag BubbaLove,
                      That's a lot of clean you have, bring that.
                      I would take home the old doors when they pull them, and put them up in your crash crib.
                      Little widows are Jack bird cool.
                      I dig that action.
                      Killer.
                      I like the word "Vitriol" -- like acid baby -- not sure I found such in J1973's action response...
                      The universe of Churches, and Church goers is a bit of a wild deal -- supernatural as normal.
                      Getting some groovy changes is fun -- even if small -- if you are into it.
                      I'm sure paint will be involved, so it might look cleaner, but I feel the vibe of "do it."
                      Free your mind and Jack bird couple up with the universe.
                      Durant "wires go both in and out" Hapke
                      • B
                        bubbalove
                        Here is the render... I still need to work on a few things such as the carpet, ceiling, and wall paint! Everything seems to want to turn red because of the carpet and pews and I can't quite get my head around that yet! This is also the first time using IES lights and they definitely look better than the normal spot or pointlights from Kerkythea! Now I just have to try and find more...
                        http://img371.imageshack.us/img371/8179/kerkyrendersmallcn8.jpg
                        By bubbalove at 2008-10-23
                        • DanielD
                          Daniel
                          Nice looking rendering, David, although I agree the pink glow from the carpet aint too pretty (but then, I detest the color pink). I have one design crit: the casing around the 6-panel doors looks too thin, IMHO. What are the dark squares over said doors?
                          My avatar is an anachronism.
                          • soloS
                            David, if you change the carpet from a color to a texture it should remove the pink tint in render.
                            • B
                              bubbalove
                              They are supposed to be speaker screens but I messed up and made them too dark... they were supposed to be the color of the walls... whoooopsies! It's funny you say that about the door casing... as I made it extra thick so the chair rail would die right into to it... maybe its the perspective?
                              • B
                                bubbalove
                                It is a texture Pete, I also added a bump map to it... I know it is definitely my material settings but I just don't know what to do... anyone with experience in Kerky maybe can help! I will post it in the Kerky boards as well and see if I can get something outta them...
                                • soloS
                                  I am not versed in KT, but if there is a way of toning down the Irradiance then you may be able to overcome this.
                                  Or a quick color correction in PS should help for a quick fix.
                                  http://img293.imageshack.us/img293/1079/kerkyrendersmallcn8ed3.jpg
                                  • B
                                    bubbalove
                                    Ahh... alright, bout to give it a shot...
                                    • DanielD
                                      Daniel
                                      David, I think the thickness of the casing is fine, but for traditional doors such as those the casing should be wider.
                                      • B
                                        bubbalove
                                        Ohhh... I'm trying to fix the 'pink' problem right now but I will fix that... client didn't catch that one...
                                        • B
                                          bubbalove
                                          Well here is the updated render... still got some 'pink' issues but it's not as bad... anyone?
                                          http://img133.imageshack.us/img133/6025/kerkyrender2xe2.jpg
                                          Pete, I'm not all that good with PS. I changed the hue/saturation for the ceiling on this one... is it any better?
                                          • soloS
                                            Definately a lot better, I use paintshop pro (not a PS fanboy), I adjusted the back lighting and flashfill.
                                            http://img528.imageshack.us/img528/135/kerkyrender2xe2ou3.jpg
