    Render Poll
    extensions
    60 Posts 26 Posters 14.3k Views 26 Watching
      rcossoli
      very good idea, I am beginning, this is ... Kerkythea 2008 Echo
      http://img183.imageshack.us/img183/1750/casagolf3achicadahi4.th.jpg
      http://img381.imageshack.us/img381/3199/casagolfinterior3qx0.th.jpg
      http://img381.imageshack.us/images/thpix.gif
      THREEDIMENSIONSWEB dot COM
      • G
        geh4evr
        Okay, How about we use a scene off the 3DWarehouse, and then try to render it with our favorite programs. All with the same camera angles.
          rcossoli
          very good idea, which some propose algiun moderator 3D model warehouse and choose the camera position and each makes a renderer with the program you use, very good idea πŸ‘ πŸ‘ πŸ‘
          these are images that I modeled for a house designed by me and my largely
            remus
            If we're going to do this id suggest someone defines all the major materials in the scene, as well as making some bumps and displacement maps, that would hopefully remove a lot of the approximation in the render, and hopefully make for a better comparison of the rendering engines themselves.
            It might also be an idea to have a preferable render method (mlt, bidir-pt etc.) again so that the comparison is as objective as possible.
            • G
              geh4evr
              So for example specify that "that table" is wood and so on?
              But that won't be possible in programs like Hypershot. It's only got one option.
                remus
                I was thinking more along the lines of providing a wood texture and some bumps to go with it.
                Where it isnt possible to change the render method, just leave it, but if you can it makes sense to get everyone using the same render method, so that the results are as similar as possible.
                  rcossoli
                  I think it would be better qeu well, you have certain rules common to all programs that are to be respected so that the comparison is more objective, take the Decision, shall I adjust to the resolutions, greetings πŸ˜‰
                  • soloS
                    I have to say I disagree with the above way of comparing render engines.
                    Firstly what is a good rendering? is it a good rendering software?
                    Hell no, rendering is an art not a process, it's very easy to create a crappy render with a high end software or a fantastic one with an entry level one.
                    Rendering is an interpretation of a model, using all the tools and skills available to you.
                    You could have an awesome model and great textures, but if your camera angles are boring or too adventurous you could ruin a render, as well as if your choice and tweaking of textures are below par so will your final render.
                    A low end render app in the right hands could be way better than a top end engine in mediocre hands. What is the point to a sterile render test?
                    My point ... you cannot test a render app against another like this as rendering involves a skill and an understanding of modeling, texturing, light setups, atmospheres, layouts, camera, etc.
                      rcossoli
                      solo i find it very valuable your opinion, I do not think this is a comparison to decies which is better and which is worse, only to vaer the differences between various programs to see how they behave interpreting the same scene, only a comparison innocent
                        remus
                        I was waiting for that solo πŸ˜›
                        • soloS
                          πŸ˜‰
                          The thing is ... some render apps are built for speed, others are for accuracy, whilst others geared towards studio based results (Hypershot) or terrain and exteriors (Vue). I do not believe there is a render app out there that is master of all, so a comparison would be limited to a certain stereotypical look, which IMO is stale and boring.
                          • P
                            Psyco_BoB
                            I don't agree with that solo.
                            I only know 3 rendering engines related to sketchup, so for me it will be quite interesting to see the capability of the other engines I don't know. That is why it should be the same exact model with the same viewpoint (and preferably the same materials). The Idea is not to make identical renderings, it's to show the different capabilities of the engines.
                            I did not mean for my request to turn into a philosophical debate. I just wanted to compare pretty pictures. πŸ˜„
                              redot
                              I vote Indigo 'cos of its ease of use and value for money.
                              • L
                                linea
                                I haven't voted. My rendering knowledge is at best rudimentary but I agree with Solo, the software cannot be judged like that - unless you have access to all of it and a really thorough knowledge.
                                Speed and cost is actually my main criteria because I am not paid primarily to produce rendered images. I use Kt mainly but my renders are really basic compared to what gets posted here. My work tools/skills are what I've got, not what would be on my wishlist.
                                Having said that; rendering comparisons of the same scene; I can't see any reason not to try it.
                                • EdsonE
                                  Edson
                                  to speak of a best render engine is like referring to the best beer, the best football club, the most beautiful woman.
                                  i would say it is more a question of what renderer fits your workflow or the one you feel more confortable with. i know for a fact that vray, artlantis, kerkythea, vue, maxwell, and others are all great in their own way. the fact that i ended up choosing podium does not mean it is better that the others. it is the one that suits me, so it is the best FOR ME.
                                  http://www.mahfuz.arq.br
                                  • N
                                    nomeradona
                                    i love podium, vray and now loving hypershot. all of them they have their pros and cons. but i voted for them as the same level, because i used them based on my personal needs.
                                    • EarthMoverE
                                      EarthMover
                                      Besides functionality, it will always come down to taste and personal style. I don't think it's a horrible idea to have a simple scene rendered by different renderers and juxtaposing them so that someone a little undecided on what renderer fits their taste, could better discern where to spend their money. (Or if free is the better route)
                                      Coming from someone who's tried most GSU compatible render engines, Vue 6 is my favorite, with Vray and Kerky coming in 2nd and 3rd.
                                      Content Creator at Skapeup
                                        rcossoli
                                        maybe not the best idea was to put in the survey which was the best, maybe it would have been better putting which was the most popular and most widely used engine for SketchUp, and so much more to also serve people who want desidir by one.
                                        I agree that the good bad depends on the tastes of birds each, I think the herror would try to change the desision I respect everyone who uses the program for rendering, while this does not happen there should be no problems
                                        • N
                                          nomeradona
                                          a lot says Vue and its not even on the list.
                                          • BurkhardB
                                            Burkhard
                                            Fry Render included but Maxwell missed?
                                            Better was: What renderer do you use ( Choose max three of them )and give the pro and cons for it. So requirements or prices are even important then personal whishes.
                                            http://www.ia-plus.de
                                            • 1 / 3
