    [Req] Texture Corrector.... PLEASE
    40 Posts 10 Posters 13.7k Views 10 Watching
    • free agentF
      free agent
      hey thanx for the quick response
      the most ive work with rubie before is opening the consol wondering: "what the hell is that for" then closing the thing...
      so i opened my model, isolated a leaf, pasted ur code in there... now what?
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
        RickW
        I'll have to do some digging on this.
        RickW
        www.smustard.com
        • free agentF
          free agent
          thanx ๐Ÿ˜„ cant wait for this one ๐ŸŽ‰
          • free agentF
            free agent
            is this difficult rubie to make?
            as a matter of interest Vray's SR1 clipmaps dont translate to reverse face of geometry that has transparency assigned to it... so this rubie will be more considerable more handy than just something some guy wants... xfrog, evermotion, and onyx trees all use transparency maps on leaves (not as many with the evermotion stuff but thats too hi-poly anyway)
            peace
              I'm interested in this ruby as well. And there's an army of people over at the AsgVIS forum that need this utility.
                I'd even be willing to pay for this ruby.
                  SketchUp does some weird stuff when it comes to backfaces. If you have a face where you apply a transparent texture on the front it automatically mirrors on the back if the backface has the default material. If you stretch and distort the texture on the front it updates the back. But if you apply a backface material, and you break that link. After removing the backface material to default, SU doesn't reset the mapping co-ordinates. Not until you make a change to the front side again, then it synchronizes again.
                  So maybe an alternate method would be for the script to reset the backface material to default and "touch" the front material forcing SU to update the backface.
                    silver_shadow
                    I would also see this rubie happen. A lot of times i get a tree fro mxfrog and the textures of the face is correct on the one side but all messed up on the other side. It makes it difficult to present to clients if you dont want to render it (because rendering fix the problem) and present it in raw sketchup.
                    • free agentF
                      free agent
                      is this a difficult script to write???
                      • free agentF
                        free agent
                        seriously NOTHING????!!!!!
                        • T
                          tomasz
                          It can be done for a flat object as a leave. I will have to do this exercise for FrontFace ruby, so will try to cook something simultaneously. ๐Ÿ˜„
                          Tomasz
                            Excellent!
                              40Th
                              @rickw said:
                              With one or more faces selected, try this in the ruby console:
                              Sketchup.active_model.selection.each{|e| e.back_material=e.material if e.typename=="Face"}
                              I suggest you start with 1 or 2 faces to see if it works as expected, since I don't have one of your models to test. If that works for you, let me know and I'll "put some skin on the bones". ๐Ÿ˜„
                              How do i use this script? And does this script solves this issue? ๐Ÿ˜’
                                RickW
                                Unfortunately, it doesn't solve the problem. There's a lot more complexity to it than I first thought. That's why there isn't a solution posted yet...
                                RickW
                                www.smustard.com
                                  davide.skp
                                  Rick, this is essential plugin!!!
                                  because every 3d trees sw produce geometry like free agent say...
                                    Any news on this?
                                    Will pay money for it.
                                    • free agentF
                                      free agent
                                      bump... ๐Ÿ˜›
                                        I tried having a go at this myself. But I can't work out how the API's related to textures work. I'm thinking this isn't the best challenge for a first ruby...
                                        • B
                                          BillW
                                          I dont know if this is of any use - a ruby I call via the ruby console with load "<filename>"
                                          after selecting the faces I want to work on.
                                          What it does is set the front face (of selected faces) to have the same material and texture mapping as the back face. It worked for me with a particular problem I had in which an imported image I exploded and did a pushpull - the top face didnt show the texture map - it was on the other side ie back face.
                                          Reapplying the material didn't do the trick as the image had been scaled on import. For your situation
                                          the code will need to changed ie
                                          get_back_UVQ to get_front_UVQ
                                          ent.material = ent.back_material to ent.back_material = ent.material
                                          model = Sketchup.active_model
                                          tw = Sketchup.create_texture_writer
                                          model.selection.each { | ent |
                                            case ent.typename
                                              when "Face" then
                                          # sets front material and mapping as back material
                                                uvHelp = ent.get_UVHelper(true, true, tw)
                                                pt_array = []
                                                numint = (ent.outer_loop.vertices.length / 4).floor
                                                vert = ent.outer_loop.vertices[numint-1]
                                                uvq = uvHelp.get_back_UVQ(vert.position)
                                                pt_array.push(vert.position,uvq)
                                                vert = ent.outer_loop.vertices[(numint*2) - 1]
                                                vert = ent.outer_loop.vertices[(numint*3) - 1]
                                                vert = ent.outer_loop.vertices[(numint*4) - 1]
                                               ent.position_material ent.material,  pt_array , true # Set front coords
                                            !!! Bill!
                                            That's excellent! ๐Ÿ˜
                                            That's just what I needed. Do you mind if I publish a ruby with your code in it? There's a bunch of V-Ray users that sorely need this in order to be able to use X-Frog trees for rendering vegetation in models.
