    [Plugin] Window Tools: Revised, 4 tools, incl. icons.
    26 Posts 15 Posters 36.8k Views 15 Watching
    • ton baetenT Offline
      ton baeten
      tomot,
      Thank for your efforts. Nice to see that you integrated the 3 previous plugins into one.
      A simple question: I already installed your 3 plugins.
      Should I delete them before installing your new overall 'Windows Tool'.
      I think that might be wise, but you don't mention that all.
      Please fill me in.
      greetings,
      Ton
        tomot
        Can you post an image of what the plug is capable?
        yes see: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12758
        my plugins
        tomot
          tomot
          tomot,
          Please fill me in.
          It does not matter when you un-install them before or after,
          and thanks for the reminder
          my plugins
          tomot
            Thx and bravo for the plug! 😎
              tomot
              Here is what prompted my adventure into Ruby and Windows Tools.
              At that time I had created the simple glazing tool, only for my own use.
              Attached is a picture of my design of a Residence for a Client,
              that I photo shopped into the landscape.
              This House is currently now under construction.
              my plugins
              tomot
                kobus
                great plugin, thanks !
                you should be interested in the future. you will spend the rest of your life there
                  seasdes
                  Thank you for the plugin Tomot. I do not seem to be able to get it to work as I am anticipating.
                  Is it supposed to cut a double wall?
                  Do you have an idiots guide as how to use it.
                  Seasdes
                  Using Sketchup Pro 2019
                    tomot
                    Seasdes
                    please check my post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12072
                    No, It does not cut double walls. It uses the same principles that are used in construction everyday, you need determine where your wall openings are first, before you install the window.
                    my plugins
                    tomot
                      tomot
                      One should not assume that the Glass Tool or Mullion Tool is capable of defining
                      a rectangular opening only. The opening can be any configuration.
                      As long as the size of the 3 point rectangle is large enough to cover the entire
                      irregular opening. The same holds true for the Mullions. Just make sure those tools
                      are setback sufficiently from the face.
                      my plugins
                      tomot
                        rv1974
                        Hi Tomot!
                        Can you switch to "cut window" gluing components not groups as the result?
                        There's Didier Bur's ruby to cut thick wall. Even more you could
                        unite 2 scripts.
                          tomot
                          @rv1974 said:
                          Hi Tomot!
                          unite 2 scripts.
                          I'm sorry I don't understand your comments.
                          and can you be more specific: what are the exact names
                          of the scripts you are taking about?
                          my plugins
                          tomot
                            rcossoli
                            Tanks!!!, I find it very useful, I'm going to try
                            THREEDIMENSIONSWEB dot COM
                              rv1974
                              @tomot said:
                              @rv1974 said:
                              Hi Tomot!
                              unite 2 scripts.
                              Hi!
                              Your tools produce groups not components. Correct?
                              Components instead of groups are better idea IMHO.
                              Components with "cut opening" and "glue to any plane" (to cut a single plane-wall) would be the best. (See components-architecture-
                              windows for instance).
                                tomot
                                You have 5 choices available to you:
                                use existing components,
                                make your own components,
                                use Windowizer,
                                use Window Tools,
                                design your own Ruby.
                                In addition once you have made a window with Window Tools, you simply select all the groups right click and make your own component. You can quickly make any number of different windows, and save each as a component.
                                But, if you prefer to use only a "single wall plane" then simply use Windowizer.
                                The reason why I made Window Tools is explained here.
                                404 Not Found
                                (www.sketchucation.com)
                                I have been in Residential design and construction for 39 years, during that time, I have never considered designing a 3d envelope using single planes for my Clients.
                                my plugins
                                tomot
                                  cyan.archnet
                                  Hats off to you for this plugin!, thanks!!
                                    agrazdi
                                    Are you planning to extend it to draw doors ?
                                    agrazdi
                                      tomot
                                      agrazdi
                                      Yes, I'm working on this project, however I'm still unclear
                                      as to how many types of doors, should be included.
                                      probably: single, double, and sliding.
                                      at present I have only single door with right and left hand option.
                                      my plugins
                                      tomot
                                      • honoluludesktopH Offline
                                        honoluludesktop
                                        How about adding a pair of bifolds.
                                        • H Offline
                                          herodes
                                          I am pretty sure you have visited this,... but just in case http://en.wikipedia.org/wiki/Door
                                          %(#BFBFBF)[http://arhitektonas.blogspot.com
                                          I know me,... I am that guy...
                                            pommes
                                            hi,is your plugin ok for mac users too?Thanks.
