    [Plugin] Window Tools: Revised, 4 tools, incl. icons.
    26 Posts 15 Posters 37.0k Views 15 Watching
      rv1974
      Hi Tomot!
      Can you switch to "cut window" gluing components not groups as the result?
      There's Didier Bur's ruby to cut thick wall. Even more you could
      unite 2 scripts.
      • T
        tomot
        @rv1974 said:
        Hi Tomot!
        unite 2 scripts.
        I'm sorry I don't understand your comments.
        and can you be more specific: what are the exact names
        of the scripts you are taking about?
        my plugins
        tomot
          rcossoli
          Tanks!!!, I find it very useful, I'm going to try
          THREEDIMENSIONSWEB dot COM
            rv1974
            @tomot said:
            @rv1974 said:
            Hi Tomot!
            unite 2 scripts.
            Hi!
            Your tools produce groups not components. Correct?
            Components instead of groups are better idea IMHO.
            Components with "cut opening" and "glue to any plane" (to cut a single plane-wall) would be the best. (See components-architecture-
            windows for instance).
            • T
              tomot
              You have 5 choices available to you:
              use existing components,
              make your own components,
              use Windowizer,
              use Window Tools,
              design your own Ruby.
              In addition once you have made a window with Window Tools, you simply select all the groups right click and make your own component. You can quickly make any number of different windows, and save each as a component.
              But, if you prefer to use only a "single wall plane" then simply use Windowizer.
              The reason why I made Window Tools is explained here.
              404 Not Found
              (www.sketchucation.com)
              I have been in Residential design and construction for 39 years, during that time, I have never considered designing a 3d envelope using single planes for my Clients.
              my plugins
              tomot
              • C
                cyan.archnet
                Hats off to you for this plugin!, thanks!!
                  agrazdi
                  Are you planning to extend it to draw doors ?
                  agrazdi
                  • T
                    tomot
                    agrazdi
                    Yes, I'm working on this project, however I'm still unclear
                    as to how many types of doors, should be included.
                    probably: single, double, and sliding.
                    at present I have only single door with right and left hand option.
                    my plugins
                    tomot
                    • honoluludesktopH
                      honoluludesktop
                      How about adding a pair of bifolds.
                      • H
                        herodes
                        I am pretty sure you have visited this,... but just in case http://en.wikipedia.org/wiki/Door
                        %(#BFBFBF)[http://arhitektonas.blogspot.com
                        I know me,... I am that guy...
                        • P
                          pommes
                          hi,is your plugin ok for mac users too?Thanks.
                          • T
                            tomot
                            I have no idea about that, perhaps someone that uses SU on the MAc will let us know.
                            my plugins
                            tomot
                            • EdsonE
                              Edson
                              I am not sure what is happening to me has to do with the fact that I am a mac user but none of your tools offer parameters for creating frames. to be sure, mullions will always be contained within a frame, right?
                              http://www.mahfuz.arq.br
                              • T
                                Truongtom
                                Thank you very much
                                • TandemT
                                  Tandem
                                  Thank you very much for a great plugin.
                                  • 2 / 2
