    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Window Tools: Revised, 4 tools, incl. icons.
    26 Posts 15 Posters 31.9k Views 15 Watching
      tomot
      When I started out several weeks ago with the posting of my Simple Glazing Tool plugin, I had no idea at that time, it would have developed 3 other window related plugin. I then felt it was a bit greedy to have these plugins each occupy valuable space in the Plugins menu, which in my particular case is running off the monitor at the moment. Hence I PM'ed Jim Foltz and asked him if he would show me how to assemble these rubies into one menu, with 4 sub-menus. I'm happy and grateful to Jim for providing the new Window Tools plugin menu. And showing me how to Write my methods in a way that they are re-usable, for future projects.
      The installation is as follows:
      1. Unzip WindowTools.zip into the following directory:
        C:\Program Files\Google\Google SketchUp 6\Plugins
      If your using Vista it will be the following directory:
      C:\Program Files (x86)\Google\Google SketchUp 6\Plugins
      The new WindowTools folder, should also be placed in the those respective directories.
      1. Open SU: Under the Plugins menu there will now be a new menu item: Window Tools
        Click Window Tools, to open a submenu, showing 4 window tool titles,
        Glass, Frame, Trim, Mullions.
      2. Goto: View>Toolbars>Window Tools, if you want to have run Window Tools directly
        from the new 4 tool icon bar.
      3. Changing the default glass color:
        Open any Ruby script in Notepad, or a dedicated script editor.
        Look for the following 2 lines: in draw_frame.rb and draw_glass.rb
      base.material=Sketchup;;Color.new(163,204,204) #change RGB Color number here
      base.material.alpha = 0.6  #change opacity number here
      Open the Material Dialog set the color picker to RGB and choose & insert
      your new glass color numbers. Do a Save As, using the same file name and .rb extension.
      1. Revisons:
        Single Glass is now the default.
        Glass now has a vertical and horizontal offset, so it can also be used
        in railings, where one may want a space between adjoining elements.
        Trim has been removed from Glass and Frame, Hence Trim can be added readily also to the
        interior of a window opening.
      I hope you like the new changes and find these tools useful.
      WindowTools.zip
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        Can you post an image of what the plug is capable?
        • ton baetenT Offline
          ton baeten
          tomot,
          Thank for your efforts. Nice to see that you integrated the 3 previous plugins into one.
          A simple question: I already installed your 3 plugins.
          Should I delete them before installing your new overall 'Windows Tool'.
          I think that might be wise, but you don't mention that all.
          Please fill me in.
          greetings,
          Ton
            tomot
            yes see: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12758
            tomot
              tomot
              tomot,
              Please fill me in.
              It does not matter when you un-install them before or after,
              and thanks for the reminder
              tomot
                Thx and bravo for the plug! ๐Ÿ˜Ž
                  tomot
                  Here is what prompted my adventure into Ruby and Windows Tools.
                  At that time I had created the simple glazing tool, only for my own use.
                  Attached is a picture of my design of a Residence for a Client,
                  that I photo shopped into the landscape.
                  This House is currently now under construction.
                  tomot
                    kobus
                    great plugin, thanks !
                    you should be interested in the future. you will spend the rest of your life there
                      seasdes
                      Thank you for the plugin Tomot. I do not seem to be able to get it to work as I am anticipating.
                      Is it supposed to cut a double wall?
                      Do you have an idiots guide as how to use it.
                      Seasdes
                      Using Sketchup Pro 2019
                        tomot
                        Seasdes
                        please check my post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12072
                        No, It does not cut double walls. It uses the same principles that are used in construction everyday, you need determine where your wall openings are first, before you install the window.
                        tomot
                          tomot
                          One should not assume that the Glass Tool or Mullion Tool is capable of defining
                          a rectangular opening only. The opening can be any configuration.
                          As long as the size of the 3 point rectangle is large enough to cover the entire
                          irregular opening. The same holds true for the Mullions. Just make sure those tools
                          are setback sufficiently from the face.
                          tomot
                            rv1974
                            Hi Tomot!
                            Can you switch to "cut window" gluing components not groups as the result?
                            There's Didier Bur's ruby to cut thick wall. Even more you could
                            unite 2 scripts.
                              tomot
                              @rv1974 said:
                              Hi Tomot!
                              unite 2 scripts.
                              I'm sorry I don't understand your comments.
                              and can you be more specific: what are the exact names
                              of the scripts you are taking about?
                              tomot
                                rcossoli
                                Tanks!!!, I find it very useful, I'm going to try
                                THREEDIMENSIONSWEB dot COM
                                  rv1974
                                  @tomot said:
                                  @rv1974 said:
                                  Hi Tomot!
                                  unite 2 scripts.
                                  Hi!
                                  Your tools produce groups not components. Correct?
                                  Components instead of groups are better idea IMHO.
                                  Components with "cut opening" and "glue to any plane" (to cut a single plane-wall) would be the best. (See components-architecture-
                                  windows for instance).
                                    tomot
                                    You have 5 choices available to you:
                                    use existing components,
                                    make your own components,
                                    use Windowizer,
                                    use Window Tools,
                                    design your own Ruby.
                                    In addition once you have made a window with Window Tools, you simply select all the groups right click and make your own component. You can quickly make any number of different windows, and save each as a component.
                                    But, if you prefer to use only a "single wall plane" then simply use Windowizer.
                                    The reason why I made Window Tools is explained here.
                                    301 Moved Permanently
                                    (www.sketchucation.com)
                                    I have been in Residential design and construction for 39 years, during that time, I have never considered designing a 3d envelope using single planes for my Clients.
                                    tomot
                                      cyan.archnet
                                      Hats off to you for this plugin!, thanks!!
                                        agrazdi
                                        Are you planning to extend it to draw doors ?
                                        agrazdi
                                          tomot
                                          agrazdi
                                          Yes, I'm working on this project, however I'm still unclear
                                          as to how many types of doors, should be included.
                                          probably: single, double, and sliding.
                                          at present I have only single door with right and left hand option.
                                          tomot
                                          • honoluludesktopH Offline
                                            honoluludesktop
                                            How about adding a pair of bifolds.
