    Leopard hang fix
    80 Posts 53 Posters 33.0k Views 53 Watching
    • H Offline
      howdy
      didn't work for me. leopard still beach balling away. really too bad.
      • I Offline
        inio
        You may need to restart, or at lest log out, after installing it for it to take effect.
        • bigstickB Offline
          bigstick
          I too am getting OS X Leopard SU instability and lockups. Mainly due to using the pushpull tool - I think. The fact that people are still posting about this 5 months after you uploaded your fix, leads me to believe that the latest updates haven't fixed the issue. I'm going to try it and see if things improve, even though my issues don't seem to be the same.
          Thanks for the time you have spent on this inio!
          • I Offline
            inio
            Yeah, I'm a little surprised this issue hasn't been fixed yet. Three OS updates (four if you count the "Graphics Update") and one SketchUp update later :/.
            (BTW, confirmed to be needed with 10.5.3)
              PeterPritchard
              hiya
              currently using macbook pro running su pro 6 and 10.5.3
              mine hangs when just rotating simple models
              i assume your fix may help address this - is it a problem you've found
              peter
              • EdsonE Offline
                Edson
                i've read 10.5.4 fixed the problem.
                http://www.mahfuz.arq.br
                  primo
                  Still having the same problem here!
                  OSx 10.5.4 ans sketchup pro.
                  Sketchups hangs when rotating a model.
                  The patch was no help at all, so far, If I disable airport, the problem disapears, no clue what this is!!
                    primo
                    No clue as to why is Aiport the culprit, but I found this hint online and tried it, and seems to work!
                    Disabling airport for some minutes before opening SU solves the problem. After a while I can activate airport again, and continue working.
                    Tried to use little snitch to block SU, but not sure if it works or not.
                    Not sure but this problem seems to be mainly on old files, on those created on OS 10.4, new ones don't seem to be afected.
                    Anyone with simmilar issues?
                    • E Offline
                      ernest
                      Thanks....
                      I'm from Indonesia, very useful for me
                        rand_2304
                        thx.... it solve my problem
                          ddisham
                          I am looking for the thaw fix file to download. Where can i go to get it?
                            remus
                            Are you talking about the file referenced in the first post? or is this another file?
                              primo
                              I think I finaly solved the problem, just leave hardware acceleration ON but fast reponse OFF.
                              NO more problems for more than a week!
                              Thank you all.
                                goldcity
                                not work for me 10.5.4 slow open , slow close, lack at working, pls help...
                                  kollatt
                                  thank you so much for this. i have been absolutely depressed about not being able to use sketchup without vmware, as it is an important development tool for me. i'm glad i bothered to search around, and i'm very grateful for the member of the community who took the time to help with this serious problem. i have my favorite 3d app back! thaaaaank you!!!
                                    jato
                                    Thank you!! Now Sketchup is usable again!
                                    Running 10.5.4.
                                      Doon
                                      The fix sounds class! Is there anywhere i can still get it?
                                      • I Offline
                                        inio
                                        The attachment on the first post of this thread still works...
                                        • I Offline
                                          inio
                                          Much to my surprise, SketchUp 7 DOES NOT FIX THIS. This patch is still useful with SketchUp 7.
                                            thedudepks
                                            Thanks inio - your patch works great with version 7!
                                            • 2 / 4
