    Messing around with animation....
    23 Posts 14 Posters 3.6k Views 14 Watching
    • MALAISEM
      MALAISE
      Hi Whaat
      Not bad the effect. Quite close to reality movements. Effectively, smoothed tour
      avoids the "robot feeling" when the path is'nt straight.
      Good job 👍
      Question: did you improve the UVTool plugin?
      I rode only few replies. Doing a shorttutorial, I've notice the use of the same picture to texture 2 different cylinders may crash SU. Only re- importing it solved the problem.
      MALAISE
      • Mike LuceyM
        Mike Lucey
        Dale, This is a badly needed improvement. Glad to learn that you
        are thinking about a 'Stand Alone' PI 👍
        • K
          kwistenbiebel
          👍 👍 Way to go Whaat.
          I am really glad you're on to this.
          The difference in cam motion between the 2 videos is very noticeable.
          It seems that you incorporated some kind of speed curve, slowing down towards a key frame ('scene') and speeding up towards the middle section between keyframes. Its really refreshing to see we will be able to get rid of the too linear default SU animation paths.
          Could this be the start of a 'reality cam' animation plugin? Including a speed graph editor etc..
          It is cool that you try to avoid to have a bezier curve as animation path, but on the other hand it would be very nice if a plugin would exist that converts a classic scene tab animation into an editable curve with moveable control points and a graph editor to make speed variations in between keyframes (='scenes').
          That would be the ultimate animation workflow: setup a classic scene tab animation, auto-convert it to a bezier and finally change its path and speed using the control points and graph editor.
          For object animation, this editable bezier + graph editor could be used as well.
          I feel not worthy to make a request like this as you already provided so much nice plugins to this community....but maybe a full plugin like that could be a commercial one?
          Anyway, the smooth animator you just showed is awesome and I can't wait to try it out .
          So thumbs up for WhaatsUp 😄 👍
          • W
            Whaat
            There is definitely potential to expand this plugin into a full featured animation package. However, there is no chance I will be taking it to that level any time soon. Maybe someday...
            That's an interesting idea to create an editable camera path using classic scene tabs as a starting point. I am sure it can be done. 😄
            • P
              Phil Rader AIA
              Thanks I'll look forward to the release.
              http://www.philrader.com
              • spenceS
                spence
                Dale,
                Nice work. The animation in sketchup needs something new and I really like what you have going here. look forward to being able to use it.
                Spence
                • T
                  tomasz
                  Hi Whaat, nice idea and it looks good.
                  Will it be an 'open source' script?
                  If answer == no, would you make internal methods known and public?
                  Tomasz
                  • P
                    princedragoncok
                    Wow, amazing! Looking forward to the day this plugin is released! 👍 👍 👍
                    • W
                      Whaat
                      Tomasz
                      This is the core of what I have so far. The smoothstep function is a well known function that I found using an internet search. I am using the Animation class in the Sketchup API. I thought this was a completely useless class until now... 😄 I just never understood how to use it before.
                      def nextFrame(view)
                      @frame+=1
                      @t+=@time_step
                      return false if @current_page_index==@pages.count
                      if @t.to_f>=@current_page_end   		#move to the next page if we are at the end of the transition time
                      	@current_page_index+=1
                      	@current_page=@pages[@current_page_index]
                      	@current_page_start=@current_page_end
                      	@current_page_trans=@current_page.transition_time
                      	@current_page_trans=@def_trans_time if @current_page_trans==-1.0
                      	@current_page_end=@current_page_start+@current_page_trans
                      smoothed_time=smooth(@current_page_start,@current_page_end,@t)*(@current_page_end-@current_page_start)+@current_page_start
                      @pages.show_frame_at(smoothed_time)
                      @filename=File.join(File.dirname(@filename),"test#{@frame}.jpg")
                      view.write_image(@filename,320,240,true) unless @t>@pages.slideshow_time
                      view.show_frame()
                      def smooth(min,max,input)
                      r=(input.to_f-min.to_f)/(max.to_f-min.to_f)
                      return r*r*(3.0-2.0*r)
                        redot
                        This looks great whaat. I'm a big fan of skindigo and look forward to rendering animations.
                        • K
                          kwistenbiebel
                          Hi Whaat.
                          Any progress on this plugin?
                          Just asking as this feature is useful to a lot of people (including me 😉) .
                          • W
                            Whaat
                            Hi Whaat.
                            hi,
                            the plugin has been 'almost done' for a couple of weeks now. I haven't been working on it much. It just needs a bit of 'clean-up' and testing before I can release it. This is what the plugin can do (just so there are no false expectations):
                            • View a SketchUp slideshow using smooth transitions between scenes
                            • Export a SketchUp slideshow (as a sequence of still images) using smooth transitions between scenes
                            The plugin cannot be used to export a smoothed animation to a render engine. Sorry!
                            • K
                              kwistenbiebel
                              Bummer for the render engine support but promising anyway. 👍
                              • FletchF
                                Fletch
                                I would use it for SU alone if it were avail.! please be encouraged to finish a beta for us.
                                I show many animations to clients these days inside good 'ole SU6. Clients love it. Would be great if it were smoothed out just like you showed.
                                Fletch
                                • C
                                  chango70
                                  How would it affect long transitions? like 16 sec?
                                  • T
                                    tomasz
                                    😄 I have been using Animation Class for exporting Face Me components. Thanks for the code. This plug-in will be vary handy. I add intermediate cameras to smooth a path but it is very time consuming and not precise method.
                                    Thanks for sharing and sorry for such a delayed response 😳
                                    Tomasz
                                    • K
                                      kwistenbiebel
                                      Hi Whaat,
                                      I saw your youtube video where you rendered a Sketchyphyics scene as an animation using a render engine (Skindigo).
                                      Is there a chance you make it into a ruby? (sketchyphysics-to-scene-tab-animation)
                                      • CadFatherC
                                        CadFather
                                        Whaat and Fredo and Didier and TIG and All the ruby confraternity.. this way we will never see the day of SU 7! or perhaps it'll be straight to SU 8.. 🤓
                                          remus
                                          Sketchyphysics renders you say? have you got a link? im intrigued.
                                          • K
                                            kwistenbiebel
                                            Sure, here you go.
                                            Proof of concept by Whaat:
                                            http://www.youtube.com/watch?v=R-Mi2urpMns
                                            [flash=425,344:28sc35yy]http://www.youtube.com/v/R-Mi2urpMns&hl=en&fs=1[/flash:28sc35yy]
                                            Whaat seems to have object animation going for Indigo (though not released yet in the Skindigo plugin) and Fryrender (version 'One') already has object animation capability. I currently just don't know how to use it on SP, as SP doesn't produce a default scene tab animation to start with.
                                            I am really excited about being able to convert Sketchyphysics action into default Sketchup animations and use render engines on it.
                                            As a note: Vray won't be able to benefit from it as it hasn't got object animation capability for now.
                                            I posted the wish for it on their forum though.
