    [Plugin] SceneExporter
    56 Posts 16 Posters 40.4k Views 16 Watching
    • FletchF Offline
      Fletch
      Sorry for my dumb question, it will be obvious I haven't tried the plug. yet.
      I use the "Automated 2D Output" ruby to export to CAD.
      The problem is that it doesn't read all the info about the scene when it exports... it just reads the camera. So if each scene I'm trying to export to CAD format has hidden geometry, hidden layers, and an active section cut (like one would do when exporting the four interior elevations for a room) it will only export the first of the cams correctly, and after that I get junk.
      So... in short, can THIS "Scene Exporter" read/remember everything each scene has checked or unchecked and export that view accurately to 2D CAD format?
      Fletch
      • jujuJ Offline
        juju
        I think Rick will most definitely the most qualified to answer your questions. But as far as I understand the plugin works with the scenes you've set up and the way you've set them up. Basically it automates the export process so you don't have to manually export images generated from from scenes. You can tell it which scenes to export and which not to. Works like a charm, had mine running late last night...
          RickW
          haynesc: If you have shadows turned on, try exporting with prompts at each scene. That will give SU time to generate the shadows for the scenes - something it might not do adequately if you have a complex model.
          fletch: This plugin uses the scene settings to export image files. Unfortunately, it doesn't do CAD export. I could mod Didier's script to handle scene settings, or perhaps he could be persuaded to mod it himself 😉 IIRC, it was written before we had a pages.active_page= method available, so we had to do some gymnastics to get things to happen correctly. Now, a quick mod would fix the issues you're having.
          RickW
          [www.smustard.com](http://www.smustard.com)
            chango70
            Just bought it. Used it in my office today. What a time saver! Thanks Rick!
            • FletchF Offline
              Fletch
              thanks for the reply - so what formats besides .jpg will it export?
              Fletch
                RickW
                Fletch: from the plugin's page:
                The default format is .jpg, but .bmp, .png, and .tif formats are also available.
                Those are the available types in SU ruby. I'm looking into how to tie into the 3d exporters.
                chango70: thanks, and glad it helped! 😄
                RickW
                • FletchF Offline
                  Fletch
                  bought 'pro' version today... just used it.
                  wish it has one tiny thing... a way to specify the output folder. Didier's 2d output ruby has this... so I'm sure you can figure out a way. 😉
                  like it for what it does! no complaints so far. haven't tested it on anything 'heavy duty' yet.
                  thanks for your work on it. it's something SU has needed for a very long time.... should have been built-in functionality long ago...
                  Fletch
                    RickW
                    Since you asked nicely, I'll get one put in. Will post when it's ready.
                    RickW
                    • FletchF Offline
                      Fletch
                      Thanks Rick!
                      since you're there - One more thing!
                      If you have a lot of scenes... you can't access the buttons! 😞
                      hmmm... maybe not a major prob. I closed and re-opened the dialog, now I get the scroll bar on the right to access the buttons.... but I still would prefer multiple columns to see as many as possible in one screen without scrolling - wouldn't you?
                      Fletch
                        RickW
                        The inactive scrollbars on the intial launch of the webDialog is a known SU bug. You can also right-click and select "refresh" to get the scrollbar to activate. I suppose I could shrink the text and/or make the rows shorter...
                        RickW
                        • FletchF Offline
                          Fletch
                          multiple columns of scene names is not possible? you have multiple columns of buttons...
                          Fletch
                          • W Offline
                            wrecknball
                            Looks like an awesome time saver.
                            Any chance this will work on my mac?
                              RickW
                              Fletch: multiple columns is possible. I was just concerned about long scene names.
                              wrecknball: it should work on Mac (no reason to suspect otherwise).
                              RickW
                              • W Offline
                                wrecknball
                                Thanks Rick.
                                I purchased it as the non pro version worked great.
                                • FletchF Offline
                                  Fletch
                                  thanks, Rick,
                                  any way you could wrap the PageExim capability into your Scene Exporter Pro? The 2 rubies seem so close in name (scene exporter) that it's logical to combine them, and confusing to have them seperate.
                                  I would love to be able to select a few diff. scenes from a file, and export only them... then use the same dialog to import them. Or, if possible, right-click a scene tab, choose 'Import from SketchUp model'... and get a similar dialog listing all the scenes in another SketchUp model, allow me to pick some of those scenes and import them into my current model.
                                  I know that's something everyone in my office has asked me about at some time or another. I am currently recommending to them that they purchase Scene Exporter Pro - I use it every day!!!! With some development it could be very powerful! (I'd love your other Scene Organizer wrapped in with it too, as I mentioned before)
                                  Fletch
                                    RickW
                                    Fletch,
                                    The eventual goal is to wrap everything together. It's just that time isn't on my side right now... 😄
                                    RickW
                                    • FletchF Offline
                                      Fletch
                                      http://www.kerkythea.net/phpBB2/images/smiles/kt_eh.gif
                                      So, Rick, any ETA on exporting to a specific folder? (or is that a PITA because of Mac and Windows differences?)
                                      Fletch
                                        RickW
                                        Next week, hopefully. OT at work continues...
                                        RickW
                                        • FletchF Offline
                                          Fletch
                                          Rick, I have to say I use this exporter all the time - it's pays for itself from the day you start using it.
                                          Are people not buying it? If not? why not? Is it because they don't understand the power it has, or because there's something out there that can do the job?
                                          Something simple like exporting the images to a specified file doesn't seem like it would be difficult to do for a smart guy like yourself. 🤓
                                          also, my other wishes still stand... please re-read my posts above - this plugin needs to be able to actually export the entire scene setups for any selected scene for import/load into another file. Also, it needs multiple columns for scene names... and my other wishes.
                                          please! 😄
                                          Fletch
                                          • H Offline
                                            Howard leslie
                                            Rick,
                                            Like Fletch, I use this plug-in quite a lot - very useful.
                                            A request I have....
                                            If you have time, could you have a think about creating a Scene Exporter that exports out (2d) CAD (ie dwg / dxf) data ???
                                            Either a new Exporter, or possibly an Enhancement to the existing exporter - Scene Exporter Pro V2 ???
                                            This would be a huge timesaver.
                                            An exporter working in a similar manner to your existing Scene Exporter would be perfect - ie working through all selected scenes in order and generating the CAD filenames as a combination of the SU filename + the Scene Name (same as you have at present).
                                            Regards
                                            Howard L'
                                            • 2 / 3
