    [Plugin] SceneExporter
    56 Posts 16 Posters 42.1k Views 16 Watching
    • N Offline
      N Lindenthal
      Is ruby mighty to ask SU, which preferences are collected in scenes?
      This would be an other way to export scenes.
      I ask this to turn it opposite. I would like to tell SU by ruby script, how to show, what a scene could show.
        RickW
        Juju,
        Sorry about that. I have repackaged the plugin with the missing file included, so you should be good to go.
        Thanks...
        RickW
        www.smustard.com
        • jujuJ Offline
          juju
          Thanks for the prompt support. Good to go after re-downloading and re-installing the script.
            Matt666
            Hi Rick !
            Thank you for this incredible script !
            Just a problem... 😄 Exporting image hasn't same witdh that the screen image !
            The screen : You can see all the drawing. It's a bar 😉
            http://images4.hiboox.com/images/3008/a66378da21932cd15010826d732e8e30.jpg
            The parameters (perhaps i have a problem with them!)
            http://images4.hiboox.com/images/3008/30237b0b97fe95375bdf58b639f0b5b6.jpg
            The image :
            http://images4.hiboox.com/images/3008/2c5ce0067dd3bc663c013adcdd5602af.jpg
            You will see that exported image is croped...
            I have a 16:10 screen.
            Have you seen that before ? Can you do smt please ? Or I'm condamned to zoom out all scenes before exporting ?
            However that's a very good script!
            Thank you !! 😍
            Frenglish at its best !
            My scripts
            • daikuD Offline
              daiku
              Hi Rick. Thanks for the tweak to the free version, but I went ahead and spent the $10 for the pro version. But I'm running into an issue where it resets the image quality back to 100% after every export, even if I "save to model". Also, none of the settings seem to get saved to the model. I reduced the image size to 1024. Then I saved to model. Then close and re-open the model, and the settings revert back to default. I'm running 64-bit vista.
              Clark Bremer
              http://www.northernlightstimberframing.com
                RickW
                Matt: I have not seen that issue. I will investigate further. Is the current view you show accessed directly from a scene tab, or was it manually set after clicking on a scene tab?
                Clark: settings saved to the model need to be activated - did you use the "Restore from model" button to do this? I went back and forth on whether saved settings should be used automatically, and decided not. If there's a consensus, I'll change it. I'll look into the image quality setting issue. I suspect a javascript-ruby translation problem.
                RickW
                www.smustard.com
                  Matt666
                  Hi Rick !
                  Directly from a scene tab...
                  Thank you !
                  My scripts
                    RickW
                    Okay, I found and fixed the settings issue. Any word on using saved settings as default (I guess it makes sense).
                    RickW
                    www.smustard.com
                    • daikuD Offline
                      daiku
                      Thanks Rick. That's exactly what happend. I expected that if I saved to the model, then it would automatically use those settings next time. So if you change the behavior, I guess you won't need the "restore from model" button at all. CB.
                      Clark Bremer
                        RickW
                        It might still be useful - say you try some different settings, then decide you don't like them - just "Restore from Model" and you don't have to try to re-create them. 😄
                        RickW
                        www.smustard.com
                          RickW
                          Looks like Matt's problem was caused by SketchUp reporting the screen size prior to the toolbars loading, skewing the settings and causing the clipping issue. I've fixed that to check the screen size prior to the first run and then every time the dialog is refreshed, so if you change your SU window size, refresh the dialog (start it again from the menu bar) and you'll have accurate screen size settings.
                          I've also updated it to use the saved settings by default.
                          RickW
                          www.smustard.com
                          • H Offline
                            haynesc
                            hi i bought the pro version but its not working for me ....
                            all i get are the scene names as files in the folder but they have 0kb as file size and i get no image ...
                            whats up !?
                            • jujuJ Offline
                              juju
                              It takes a little time (not much though), the plugin will tell you when it's done.
                              • H Offline
                                haynesc
                                i got the message saying "12 scenes have been exported" ... but when i looked at the files all i got back was files with 0 file size
                                • FletchF Offline
                                  Fletch
                                  Sorry for my dumb question, it will be obvious I haven't tried the plug. yet.
                                  I use the "Automated 2D Output" ruby to export to CAD.
                                  The problem is that it doesn't read all the info about the scene when it exports... it just reads the camera. So if each scene I'm trying to export to CAD format has hidden geometry, hidden layers, and an active section cut (like one would do when exporting the four interior elevations for a room) it will only export the first of the cams correctly, and after that I get junk.
                                  So... in short, can THIS "Scene Exporter" read/remember everything each scene has checked or unchecked and export that view accurately to 2D CAD format?
                                  Fletch
                                  • jujuJ Offline
                                    juju
                                    I think Rick will most definitely the most qualified to answer your questions. But as far as I understand the plugin works with the scenes you've set up and the way you've set them up. Basically it automates the export process so you don't have to manually export images generated from from scenes. You can tell it which scenes to export and which not to. Works like a charm, had mine running late last night...
                                      RickW
                                      haynesc: If you have shadows turned on, try exporting with prompts at each scene. That will give SU time to generate the shadows for the scenes - something it might not do adequately if you have a complex model.
                                      fletch: This plugin uses the scene settings to export image files. Unfortunately, it doesn't do CAD export. I could mod Didier's script to handle scene settings, or perhaps he could be persuaded to mod it himself 😉 IIRC, it was written before we had a pages.active_page= method available, so we had to do some gymnastics to get things to happen correctly. Now, a quick mod would fix the issues you're having.
                                      RickW
                                      www.smustard.com
                                        chango70
                                        Just bought it. Used it in my office today. What a time saver! Thanks Rick!
                                        • FletchF Offline
                                          Fletch
                                          thanks for the reply - so what formats besides .jpg will it export?
                                          Fletch
                                            RickW
                                            Fletch: from the plugin's page:
                                            The default format is .jpg, but .bmp, .png, and .tif formats are also available.
                                            Those are the available types in SU ruby. I'm looking into how to tie into the 3d exporters.
                                            chango70: thanks, and glad it helped! 😄
                                            RickW
                                            www.smustard.com
                                            • 2 / 3
