    [Plugin] SceneExporter
    56 Posts 16 Posters 42.1k Views 16 Watching
      RickW
      SceneExporterPro is now available.
      RickW
      www.smustard.com
      • jujuJ Offline
        juju
        And you have a purchase! Thanks for making life easier.
        • jujuJ Offline
          juju
          Why do I get this message?
          Error Loading File sceneExporterPro.rb
          No such file to load -- smustard-app-observer.rb
          • N Offline
            N Lindenthal
            Is ruby mighty to ask SU, which preferences are collected in scenes?
            This would be an other way to export scenes.
            I ask this to turn it opposite. I would like to tell SU by ruby script, how to show, what a scene could show.
              RickW
              Juju,
              Sorry about that. I have repackaged the plugin with the missing file included, so you should be good to go.
              Thanks...
              RickW
              www.smustard.com
              • jujuJ Offline
                juju
                Thanks for the prompt support. Good to go after re-downloading and re-installing the script.
                  Matt666
                  Hi Rick !
                  Thank you for this incredible script !
                  Just a problem... 😄 Exporting image hasn't same witdh that the screen image !
                  The screen : You can see all the drawing. It's a bar 😉
                  http://images4.hiboox.com/images/3008/a66378da21932cd15010826d732e8e30.jpg
                  The parameters (perhaps i have a problem with them!)
                  http://images4.hiboox.com/images/3008/30237b0b97fe95375bdf58b639f0b5b6.jpg
                  The image :
                  http://images4.hiboox.com/images/3008/2c5ce0067dd3bc663c013adcdd5602af.jpg
                  You will see that exported image is croped...
                  I have a 16:10 screen.
                  Have you seen that before ? Can you do smt please ? Or I'm condamned to zoom out all scenes before exporting ?
                  However that's a very good script!
                  Thank you !! 😍
                  Frenglish at its best !
                  My scripts
                  • daikuD Offline
                    daiku
                    Hi Rick. Thanks for the tweak to the free version, but I went ahead and spent the $10 for the pro version. But I'm running into an issue where it resets the image quality back to 100% after every export, even if I "save to model". Also, none of the settings seem to get saved to the model. I reduced the image size to 1024. Then I saved to model. Then close and re-open the model, and the settings revert back to default. I'm running 64-bit vista.
                    Clark Bremer
                    http://www.northernlightstimberframing.com
                      RickW
                      Matt: I have not seen that issue. I will investigate further. Is the current view you show accessed directly from a scene tab, or was it manually set after clicking on a scene tab?
                      Clark: settings saved to the model need to be activated - did you use the "Restore from model" button to do this? I went back and forth on whether saved settings should be used automatically, and decided not. If there's a consensus, I'll change it. I'll look into the image quality setting issue. I suspect a javascript-ruby translation problem.
                      RickW
                      www.smustard.com
                        Matt666
                        Hi Rick !
                        Directly from a scene tab...
                        Thank you !
                        My scripts
                          RickW
                          Okay, I found and fixed the settings issue. Any word on using saved settings as default (I guess it makes sense).
                          RickW
                          www.smustard.com
                          • daikuD Offline
                            daiku
                            Thanks Rick. That's exactly what happend. I expected that if I saved to the model, then it would automatically use those settings next time. So if you change the behavior, I guess you won't need the "restore from model" button at all. CB.
                            Clark Bremer
                              RickW
                              It might still be useful - say you try some different settings, then decide you don't like them - just "Restore from Model" and you don't have to try to re-create them. 😄
                              RickW
                              www.smustard.com
                                RickW
                                Looks like Matt's problem was caused by SketchUp reporting the screen size prior to the toolbars loading, skewing the settings and causing the clipping issue. I've fixed that to check the screen size prior to the first run and then every time the dialog is refreshed, so if you change your SU window size, refresh the dialog (start it again from the menu bar) and you'll have accurate screen size settings.
                                I've also updated it to use the saved settings by default.
                                RickW
                                www.smustard.com
                                • H Offline
                                  haynesc
                                  hi i bought the pro version but its not working for me ....
                                  all i get are the scene names as files in the folder but they have 0kb as file size and i get no image ...
                                  whats up !?
                                  • jujuJ Offline
                                    juju
                                    It takes a little time (not much though), the plugin will tell you when it's done.
                                    • H Offline
                                      haynesc
                                      i got the message saying "12 scenes have been exported" ... but when i looked at the files all i got back was files with 0 file size
                                      • FletchF Offline
                                        Fletch
                                        Sorry for my dumb question, it will be obvious I haven't tried the plug. yet.
                                        I use the "Automated 2D Output" ruby to export to CAD.
                                        The problem is that it doesn't read all the info about the scene when it exports... it just reads the camera. So if each scene I'm trying to export to CAD format has hidden geometry, hidden layers, and an active section cut (like one would do when exporting the four interior elevations for a room) it will only export the first of the cams correctly, and after that I get junk.
                                        So... in short, can THIS "Scene Exporter" read/remember everything each scene has checked or unchecked and export that view accurately to 2D CAD format?
                                        Fletch
                                        • jujuJ Offline
                                          juju
                                          I think Rick will most definitely the most qualified to answer your questions. But as far as I understand the plugin works with the scenes you've set up and the way you've set them up. Basically it automates the export process so you don't have to manually export images generated from from scenes. You can tell it which scenes to export and which not to. Works like a charm, had mine running late last night...
                                            RickW
                                            haynesc: If you have shadows turned on, try exporting with prompts at each scene. That will give SU time to generate the shadows for the scenes - something it might not do adequately if you have a complex model.
                                            fletch: This plugin uses the scene settings to export image files. Unfortunately, it doesn't do CAD export. I could mod Didier's script to handle scene settings, or perhaps he could be persuaded to mod it himself 😉 IIRC, it was written before we had a pages.active_page= method available, so we had to do some gymnastics to get things to happen correctly. Now, a quick mod would fix the issues you're having.
                                            RickW
                                            www.smustard.com
                                            • 2 / 3
