    [Plugin] Toggle Units
    159 Posts 47 Posters 163.5k Views 47 Watching
    • CadFatherC
      CadFather
      i see, cool 'unity toolbar' stuff though... 😄 👍
      • EdsonE
        Edson
        @matt666 said:
        Here is the script.
        Two versions :
        • Juste one icon, which toggle unity drawing. It changes only at the start of Su, according to current unit.
        • Five icons
        i tried to install the 1 icon version but it did not work. instead i got this message:
        Error Loading File toggle_units.rb
        can't convert nil into String
        what is the correct installation method? the rb file goes in the pligins folder, but what do i do with the icons? do i put them there directly or inside a folder?
        thanks.
        http://www.mahfuz.arq.br
        • EdsonE
          Edson
          i managed to install the 5 icon version but it did not work. there is no change in the VCB and when i click the model info window i still have the unit the file was set up to when the file was opened.
            Matt666
            Hi edson !
            Puts all the package in plugins. Without any folder.
            It works here !
            Frenglish at its best !
            My scripts
            • C
              cornel
              Matt,
              Beside those 'Decimals'
              can you include 'Architectural' format?!
              Cornel
                Matt666
                I have edited the script post with your improvment !
                My scripts
                  Matt666
                  Edson, do you still have same problems?
                  My scripts
                  • EdsonE
                    Edson
                    sorry, matt, but it just does not work for me on mac. no changes of unit no matter what icon one clicks on.
                    installing the 1 icon version still brings the message quoted above. by the way, what is this one supposed to do? what is the unit it changes to?
                      Matt666
                      Can you try with this script, please ?
                      Work on Mac ?? Unzip all in the plugin folder.
                      My scripts
                      • V
                        Vichingo
                        I am having some difficulties with the qua;ity of the Icons. For some reason they will not clean up, and they look very distored. Anybody want to desing some slick buttons to dress up this otherwise great plug
                        • EdsonE
                          Edson
                          sure. no changes, ie, nothing happened. i have attached a screen grab for you to see that the error message is still showing and the toolbar shows a blank square (it does not change if i click on it).
                          should you need me to test future changes on mac, just let me know.toggleunits.png
                          • CadFatherC
                            CadFather
                            ..phew - didn't know i was going to give you so much work Matt!
                            i can draw some icons later today - can i suggest one further change to the scripts: if we have the icons in png formats they are much better quality..Thanks
                              Matt666
                              No problem CadFather 😉
                              Edson : Thank you !
                              Have you unzipped ain the plugin folder, and keep icons in the folder "toggle_units_icons" ?
                              If yes, Can you open ruby console, type this line please :
                              Sketchup.find_support_file("tuin.gif", "Plugins/toggle_units_icons")
                              and show me what it returns ?
                              Thank you !
                              My scripts
                              • EdsonE
                                Edson
                                it returns this:
                                /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/toggle_units_icons/tuin.gif
                                cheers.
                                • CadFatherC
                                  CadFather
                                  some icons - not great, will work more..
                                  16 GIF.rar
                                  24 GIF.rar
                                  • C
                                    cornel
                                    Many thanks, Matt!
                                    For me it’s a considerable tool – I work very often w/ different unit formats on the same dwgs.
                                    Best regards,
                                    Cornel
                                    • Didier BurD
                                      Didier Bur
                                      Matt,
                                      STP remplace "unity" par "unit" dans le script. Unity veut dire à peu près "unification". 😉
                                      DB
                                        Matt666
                                        @CadFather, Thank you ! Could you post them in png format, please ?
                                        😳 🤣 Vive mon anglais désastreux !
                                        You're welcome Cornel !! 😉
                                        My scripts
                                        • CadFatherC
                                          CadFather
                                          ..they do need touching up, but here they are
                                          16&24 PNG.rar
                                            Matt666
                                            The 9 icons script has been updated with new icons on the script post. Please try it Edson !
                                            Thank you CadFather !!
                                            My scripts
                                            • 1 / 8
