πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Toggle Units
159 Posts 47 Posters 116.4k Views 47 Watching
    Matt666
    • EDIT1: Add a folder in the zip, after Edson issue .
    • EDIT2: Another version, with all drawing unity type : Decimal, architectural, etc... 9 icons
    • EDIT3: Updated with CadFather icons... And a try to make it compatible with mac.
    • EDIT4: Request by Ken , two icons added. They increase or decrease drawing precision.
    • EDIT5: Last update with cool icons from Mister CadFather! And another icon that displays unit on dimensions entities.
    • EDIT6 [by TIG]: 20110129 - added v7.1/8 friendly version
    • EDIT7 [by TIG]: 20100129 - updated version to correct icon paths
    • EDIT8: 20110912 - New tool added: Toolbar manager.
    • EDIT9: 20110915 - Mac bug fixed and add tool in extensions window. Thanks to driven!** EDIT10: 20140302 - Bug on new SU version. Thanks to jiminy-billy-bob.
    Hi all. First of all I would like to thank Thomthom for his help with javascript, and TIG for his advice in ruby.
    Here is a script that change drawing units quickly.
    You can manage toolbar with "Toolbar Manager", by clicking in Plugins->Toggle units->Toolbar manager
    You should be able to choose icons you want to display in the toolbar. Thank you to kyyu for giving me the idea.
    PS: WOW, 1178 downloads, thank you! ^^
    Please get the latest version from the PluginStore [now v2014 compliant]http://sketchucation.com/pluginstore?pln=Matt_Toggle_Units
    Frenglish at its best !
    My scripts
      Matt666
      Hi !
      also, the units redraw only when i click on the screen or (press the esc key) - is that to do with screen refresh? if so is there any way to make it refresh automatically?
      The post containing scripts has been updated with your improvment.
      one question.. how can i assign a keyboard shortcut to one of them? or is it not possible?
      The only solution (I think) is to create a menu "units" in the menu plugins, and to add a shortcut to it... I've added another script which add a menu "unities" in the menu plugins.
      My scripts
        CadFather
        Thank you Mr brain! ekwave.gif just Perfect!
          Matt666
          Thank you...
          http://www.smileys-fr.com/smileys/forum/10.gif
          My scripts
            CadFather
            Matt, just one more thing (last one!) - i opened your script and i think it is meant to change the toolbar icon when i change the units, is that true?
              Matt666
              I tried to do that, but I don't know how... For the moment, Icon changes only at the start of SU...
              My scripts
                CadFather
                i see, cool 'unity toolbar' stuff though... πŸ˜„ πŸ‘
                • E Offline
                  Edson
                  @matt666 said:
                  Here is the script.
                  Two versions :
                  • Juste one icon, which toggle unity drawing. It changes only at the start of Su, according to current unit.
                  • Five icons
                  i tried to install the 1 icon version but it did not work. instead i got this message:
                  Error Loading File toggle_units.rb
                  can't convert nil into String
                  what is the correct installation method? the rb file goes in the pligins folder, but what do i do with the icons? do i put them there directly or inside a folder?
                  thanks.
                  http://www.mahfuz.arq.br
                  • E Offline
                    Edson
                    i managed to install the 5 icon version but it did not work. there is no change in the VCB and when i click the model info window i still have the unit the file was set up to when the file was opened.
                      Matt666
                      Hi edson !
                      Puts all the package in plugins. Without any folder.
                      It works here !
                      My scripts
                        cornel
                        Matt,
                        Beside those 'Decimals'
                        can you include 'Architectural' format?!
                        Cornel
                          Matt666
                          I have edited the script post with your improvment !
                          πŸ˜‰
                          My scripts
                            Matt666
                            Edson, do you still have same problems?
                            My scripts
                            • E Offline
                              Edson
                              sorry, matt, but it just does not work for me on mac. no changes of unit no matter what icon one clicks on.
                              installing the 1 icon version still brings the message quoted above. by the way, what is this one supposed to do? what is the unit it changes to?
                                Matt666
                                Can you try with this script, please ?
                                Work on Mac ?? Unzip all in the plugin folder.
                                My scripts
                                • V Offline
                                  Vichingo
                                  I am having some difficulties with the qua;ity of the Icons. For some reason they will not clean up, and they look very distored. Anybody want to desing some slick buttons to dress up this otherwise great plug
                                  • E Offline
                                    Edson
                                    sure. no changes, ie, nothing happened. i have attached a screen grab for you to see that the error message is still showing and the toolbar shows a blank square (it does not change if i click on it).
                                    should you need me to test future changes on mac, just let me know.toggleunits.png
                                      CadFather
                                      ..phew - didn't know i was going to give you so much work Matt!
                                      i can draw some icons later today - can i suggest one further change to the scripts: if we have the icons in png formats they are much better quality..Thanks
                                        Matt666
                                        No problem CadFather πŸ˜‰
                                        Edson : Thank you !
                                        Have you unzipped ain the plugin folder, and keep icons in the folder "toggle_units_icons" ?
                                        If yes, Can you open ruby console, type this line please :
                                        Sketchup.find_support_file("tuin.gif", "Plugins/toggle_units_icons")
                                        and show me what it returns ?
                                        Thank you !
                                        My scripts
                                        • E Offline
                                          Edson
                                          it returns this:
                                          /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/toggle_units_icons/tuin.gif
                                          cheers.
                                          • 1 / 8
                                          1 / 8
