    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • CadFatherC
      CadFather
      ๐Ÿ˜„
      • FrederikF
        Frederik
        Thank you so much for the icons and cursors, Max..!! ๐Ÿ˜„
        They sure look GREAT..!! ๐Ÿ‘
        Cheers
        Kim Frederik
        • K
          kwistenbiebel
          Hi Fredo,
          Maybe an idea for a next on-surface-tool: ' paint-on-surface'
          Just like the new Cinema4D plugin:
          see movie: http://www.dns-plugins.de/video/pos_1_overview.mov
          Although, when I think about it...maybe this would be a feature to add to the existing 'component spray' ruby...
          • CadFatherC
            CadFather
            are you sure you installed the 24 pixels ones? (TOS_IconsCursors_24)
              Very design icons! it's like a dream ๐Ÿ˜‰ ๐Ÿ˜Ž
              Seems there is something with large buttons on the toolbars ๐Ÿ˜ฎ
              Seems jpg compress ??? Maybe I miss something ๐Ÿ˜’
              they are fine on the screen work ๐Ÿ‘
              Little buttons icones works fine ๐Ÿ˜‰
              [Edit]it was me ! I had not install Large cone file ๐Ÿ˜ณ
                Yes I have missed that ๐Ÿ˜ณ
                see my previous edited post ๐Ÿ˜„
                But i have always a problem
                what must be the organisation of folders TOS_IconsCursors_24 and TOS_IconsCursors_16 inside the Plugins folder?
                because I have the same problem now for the little button ๐Ÿ˜’
                I must miss again something ๐Ÿ˜‰
                • CadFatherC
                  CadFather
                  large toolbars use 24 pixel icons, small 16 pixels.
                  but TOS does not load them automatically, so if you want small toolbars put the 16 in the folder - if large the 24
                  a quick way is to zip both set of icons in the TOS folder - when you want to change them just "unzip here" and overwrite all files (i use winrar).
                    Ok all is clear now, I full understand my problem ๐Ÿ‘
                    • fredo6F
                      CadFather,
                      First of all, thanks for your hard and impressive work on the icons and cursors. I am glad to see that this is appreciated by users.
                      The TOS script actually makes provision of big and small icons. The naming convention is to append **'_24'**or **'_16'**to the icon filename for big and small icons, respectively.
                      It is only because I am lazy that I did publish only one set (and in 32x32 by the way).
                      The attached archive contains your two sets of icons and cursors merged into one set, with the proper naming convention. All .png files should just be extracted and dropped in the folder TOS_Dir_13
                      Again, thanks very much
                      Just extract and drop in TOS_Dir_13 folder
                      • CadFatherC
                        CadFather
                        Master Fredo... Thanks and hats off - ๐Ÿ˜Ž
                        works just like sketchup 8 - if only i was half as lazy as you! ๐Ÿ˜„
                          Some more easy and confortable now ๐Ÿ˜Ž
                          • CadFatherC
                            CadFather
                            Hi Fredo, i don't think this same 16/24 system applies to bezier as well - had a look at the scripts but cannot locate/attempt how to make the switch automatic..any pointers would be great..
                            • F
                              fixzigma
                              Thankss
                              • fredo6F
                                No, Bezierspline is an old script now, but I plan to refresh it at some point in time.
                                This being said, it would be relatively simple to make just the modification about icons. Let me think about it.
                                • CadFatherC
                                  CadFather
                                  ..it would be great to have _16, _24 naming convention like TOS - but all in your own time of course ๐Ÿ˜‰
                                  • fredo6F
                                    CadFather,
                                    For easier access to your set of icons and cursors, I edited the first message of this thread and attached the archive file.
                                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212&st=0&sk=t&sd=a#p76625
                                    Fred
                                    • F
                                      FkY
                                      Hello all, it's my first message here...
                                      Thanks to Fredo6 for this awesome plugin, it's very useful.
                                      I've just seen a little bug in the arc display. When you move an arc created with this plugin, the center point (displayed by a cross) doesn't move.
                                      It would be nice to have the tangent constraint when you create an arc after an other or a line to have a continuity.
                                      FkY_
                                      PS : sorry for my "garbage english", I do my best but...
                                      • fredo6F
                                        Not really a bug actually. the script just create a construction point for the arc center for convenience (as it should maybe in native Sketchup!). But the construction point is not really part of the arc and does not keep any connection with it afterward.
                                        Yes, that would be nice. On a Surface, it is however a little bit tricky, though probably feasible.
                                        • CadFatherC
                                          CadFather
                                          CadFather,
                                          Fred
                                          oh..i'm honoured to have my name next to it! ๐Ÿ˜„
                                          • Z
                                            zhuangsuph
                                            Thank youThank youThank you
                                            • 31
                                            • 32
                                            • 5 / 32
