    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.7m Views 202 Watching
    • CadFatherC Offline
      CadFather
      thanks Stanmarsh, files updated.
      @ Fredo.. to make the toolbars easier to manage.. (you may already know)
      i know Didier has a way of changing the icons from small to large (projections/layer manager) according to the toolbars setting in SU. unfortunately the script is scrambled so i can't see the relevant code. would be good to have all big and small icons in the TOS folder (and not worry about it anymore).
        CadFather
        thanks Stan, your comment makes glad two weeks of work to achieve it! ๐Ÿ˜‰
        • W Offline
          watkins
          Dear CadFather,
          Your icons are clear and crisp, and a pleasure to use. Thank you for all your efforts.
          Kind regards,
          Bob
            CadFather
            ๐Ÿ˜„
            • FrederikF Offline
              Frederik
              Thank you so much for the icons and cursors, Max..!! ๐Ÿ˜„
              They sure look GREAT..!! ๐Ÿ‘
              Cheers
              Kim Frederik
                kwistenbiebel
                Hi Fredo,
                Maybe an idea for a next on-surface-tool: ' paint-on-surface'
                Just like the new Cinema4D plugin:
                see movie: http://www.dns-plugins.de/video/pos_1_overview.mov
                Although, when I think about it...maybe this would be a feature to add to the existing 'component spray' ruby...
                  CadFather
                  are you sure you installed the 24 pixels ones? (TOS_IconsCursors_24)
                    Very design icons! it's like a dream ๐Ÿ˜‰ ๐Ÿ˜Ž
                    Seems there is something with large buttons on the toolbars ๐Ÿ˜ฎ
                    Seems jpg compress ??? Maybe I miss something ๐Ÿ˜’
                    they are fine on the screen work ๐Ÿ‘
                    Little buttons icones works fine ๐Ÿ˜‰
                    [Edit]it was me ! I had not install Large cone file ๐Ÿ˜ณ
                      Yes I have missed that ๐Ÿ˜ณ
                      see my previous edited post ๐Ÿ˜„
                      But i have always a problem
                      what must be the organisation of folders TOS_IconsCursors_24 and TOS_IconsCursors_16 inside the Plugins folder?
                      because I have the same problem now for the little button ๐Ÿ˜’
                      I must miss again something ๐Ÿ˜‰
                        CadFather
                        large toolbars use 24 pixel icons, small 16 pixels.
                        but TOS does not load them automatically, so if you want small toolbars put the 16 in the folder - if large the 24
                        a quick way is to zip both set of icons in the TOS folder - when you want to change them just "unzip here" and overwrite all files (i use winrar).
                          Ok all is clear now, I full understand my problem ๐Ÿ‘
                          • fredo6F Offline
                            CadFather,
                            First of all, thanks for your hard and impressive work on the icons and cursors. I am glad to see that this is appreciated by users.
                            The TOS script actually makes provision of big and small icons. The naming convention is to append **'_24'**or **'_16'**to the icon filename for big and small icons, respectively.
                            It is only because I am lazy that I did publish only one set (and in 32x32 by the way).
                            The attached archive contains your two sets of icons and cursors merged into one set, with the proper naming convention. All .png files should just be extracted and dropped in the folder TOS_Dir_13
                            Again, thanks very much
                            Just extract and drop in TOS_Dir_13 folder
                              CadFather
                              Master Fredo... Thanks and hats off - ๐Ÿ˜Ž
                              works just like sketchup 8 - if only i was half as lazy as you! ๐Ÿ˜„
                                Some more easy and confortable now ๐Ÿ˜Ž
                                  CadFather
                                  Hi Fredo, i don't think this same 16/24 system applies to bezier as well - had a look at the scripts but cannot locate/attempt how to make the switch automatic..any pointers would be great..
                                  • F Offline
                                    fixzigma
                                    Thankss
                                    • fredo6F Offline
                                      No, Bezierspline is an old script now, but I plan to refresh it at some point in time.
                                      This being said, it would be relatively simple to make just the modification about icons. Let me think about it.
                                        CadFather
                                        ..it would be great to have _16, _24 naming convention like TOS - but all in your own time of course ๐Ÿ˜‰
                                        • fredo6F Offline
                                          CadFather,
                                          For easier access to your set of icons and cursors, I edited the first message of this thread and attached the archive file.
                                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212&st=0&sk=t&sd=a#p76625
                                          Fred
                                          • F Offline
                                            FkY
                                            Hello all, it's my first message here...
                                            Thanks to Fredo6 for this awesome plugin, it's very useful.
                                            I've just seen a little bug in the arc display. When you move an arc created with this plugin, the center point (displayed by a cross) doesn't move.
                                            It would be nice to have the tangent constraint when you create an arc after an other or a line to have a continuity.
                                            FkY_
                                            PS : sorry for my "garbage english", I do my best but...
                                            • 31
                                            • 32
                                            • 5 / 32
