    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • CadFatherC Offline
      CadFather
      For the icons, could you make them a little 'bigger', meaning using more of the surface of the toolbar button. On my small-screen computer (15'), it is hard to distinguish the shapes and visually see the differences between buttons.
      Thanks a lot. I promise not to touch the naming convention for these icons and cursors in future versions (but I may have to add new ones !).
      Fredo, i made these yesterday too but didn't post them as they need more work to get the lines bolder. 24 pixels only - i'm planing, more work on them.
      also i personally wouldn't mind having an .exe installer (it would take care of previous installs and minimize probs (just an idea)
      RED FLAT 24.rar
      • erikBE Offline
        erikB
        Fredo, many thanks again fot this update.
        erikB
        • jujuJ Offline
          juju
          Fredo, thanks for the update and improvements.
          CadFather, thanks for the red flat 24 icons, I prefer them.
          • W Offline
            wq418
            i like it!
            thank you
              CadFather
              i upated my icons for TOS - not the best but thought i shared them - basically just place them inside the TOS icons folder overwriting the existing one (you have the originals anyway)
              i hope to work more on the cursors and on the small ones as they are not too clear
              EDIT: MORE ICONS IN THE POSTS BELOW..
              Large Buttons Toolbar
              Small Buttons Toolbar
                dolphus
                Thank you very much for the latest update, I am just missing the original buttone the only buttons i have are for the circle, circle 3 points and arc what am i doing wrong?
                  JGA
                  Fredo,
                  Thanks for the tools, they are great, & to CadFather for the icons to match!
                  Regards,
                  JGA
                    tald311
                    This script is AMAZING. Coen showed it to me at 3D base camp and he has made fun of my reaction since. This latest update has pushed the ability to use SketchUp into a new direction.
                    I have one request, unless it can already be done, sommeone please let me know - the ability to offset lines once they are drawn. Ther reason: I want to lay out a trail or walk on a surface. I can use the line on surface and the arc on surface - once I draw the first one, I want to create an offset to make them parallel.
                    THANK YOU AGAIN
                    Simply amazing
                    Daniel Tal
                      This tool can't make the trick?
                      Just close your lines, make the offset, erase lines that you don't want πŸ˜‰
                        tald311
                        Unfortunlaty it does not. That will offset the surfaces and not the line. Keep in mind, I am not complaining about the ruby at all either.
                          Yes it's not automatic, but it's not a big deal after the Offset of contour!
                          Explode curve and you have all offset you want πŸ˜„
                          And after free to you to weld any part of curves you want πŸ˜‰
                            remus
                            Not really sure what your getting at daniel, as a surface is always defined by its edges so to offset the surface you need to offset the bounding edge.
                            • boofredlayB Offline
                              boofredlay
                              Thanks again for the updated script!
                              I just now got around to installing it.
                                stanmarsh
                                @CadFather
                                thanks for the icons, i really like it, its very refined! πŸ‘
                                btw, the offset cursor icons are missing.
                                  CadFather
                                  Hi, i think this is going to be the final release (for now)
                                  TOS Cursors updated (smaller pencil).
                                  TOS Icons updated:
                                  small icons
                                  large icons
                                    stanmarsh
                                    icons are pretty! πŸŽ‰
                                      CadFather
                                      thanks Stanmarsh, files updated.
                                      @ Fredo.. to make the toolbars easier to manage.. (you may already know)
                                      i know Didier has a way of changing the icons from small to large (projections/layer manager) according to the toolbars setting in SU. unfortunately the script is scrambled so i can't see the relevant code. would be good to have all big and small icons in the TOS folder (and not worry about it anymore).
                                        CadFather
                                        thanks Stan, your comment makes glad two weeks of work to achieve it! πŸ˜‰
                                        • W Offline
                                          watkins
                                          Dear CadFather,
                                          Your icons are clear and crisp, and a pleasure to use. Thank you for all your efforts.
                                          Kind regards,
                                          Bob
                                            CadFather
                                            πŸ˜„
                                            • 31
                                            • 32
                                            • 4 / 32
