    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • W
      watkins
      Dear Fredo,
      Thank you for the explanation. I use Sketchup for mechanical design and so I almost always draw on flat surfaces, hence my interest in using your tools for both plain and construction lines.
      Kind regards,
      Bob
      • fredo6F
        @watkins said:
        Dear Fredo,
        Kind regards,
        Bob
        Bob (and Daniel)
        That's simply a bug, thanks for signaling (actually the script was generating a face for the shape, even in construction line).
        This is fixed and I updated the Zip file in the main message of this thread.
        • fredo6F
          It has already been said by Gaieus, the Freehand On Surface tool does not close the path. You think you can fix this? Or am I missing an option?
          Freehand does not close automatically and does not have inference on by default, but if you keep Shift depressedwhen approaching a remarkable point, the inference is activated (on existing point, and on points of the curve drawn).
          Also CTRL depressed allow you to pause the input of points when you move the cursor.
          • fredo6F
            @cadfather said:
            goooodness me Fredo.. how many cursors in this plugin! 😲 (could they impact on loading speed?)
            anyway, at 1am - with divorce proceedings well under way - i have finished icons and cursor - both for small and large toolbar (16, 24) [plus an extra set] - again just place them in your "...\Plugins\TOS_Dir_13" folder, overwriting all files".
            @Plot-Paris, thanks, glad they can be of use πŸ˜„
            CadFather,
            The cursors are very good and well designed. Nice work
            For the icons, could you make them a little 'bigger', meaning using more of the surface of the toolbar button. On my small-screen computer (15'), it is hard to distinguish the shapes and visually see the differences between buttons.
            Thanks a lot. I promise not to touch the naming convention for these icons and cursors in future versions (but I may have to add new ones !).
            • plot-parisP
              plot-paris
              πŸ˜• something like a "Scale on surface"? πŸ˜†
              • CadFatherC
                CadFather
                Fredo, i made these yesterday too but didn't post them as they need more work to get the lines bolder. 24 pixels only - i'm planing, more work on them.
                also i personally wouldn't mind having an .exe installer (it would take care of previous installs and minimize probs (just an idea)
                RED FLAT 24.rar
                • erikBE
                  erikB
                  Fredo, many thanks again fot this update.
                  erikB
                  • jujuJ
                    juju
                    Fredo, thanks for the update and improvements.
                    CadFather, thanks for the red flat 24 icons, I prefer them.
                    • W
                      wq418
                      i like it!
                      thank you
                      • CadFatherC
                        CadFather
                        i upated my icons for TOS - not the best but thought i shared them - basically just place them inside the TOS icons folder overwriting the existing one (you have the originals anyway)
                        i hope to work more on the cursors and on the small ones as they are not too clear
                        EDIT: MORE ICONS IN THE POSTS BELOW..
                        Large Buttons Toolbar
                        Small Buttons Toolbar
                          dolphus
                          Thank you very much for the latest update, I am just missing the original buttone the only buttons i have are for the circle, circle 3 points and arc what am i doing wrong?
                            JGA
                            Fredo,
                            Thanks for the tools, they are great, & to CadFather for the icons to match!
                            Regards,
                            JGA
                            • T
                              tald311
                              This script is AMAZING. Coen showed it to me at 3D base camp and he has made fun of my reaction since. This latest update has pushed the ability to use SketchUp into a new direction.
                              I have one request, unless it can already be done, sommeone please let me know - the ability to offset lines once they are drawn. Ther reason: I want to lay out a trail or walk on a surface. I can use the line on surface and the arc on surface - once I draw the first one, I want to create an offset to make them parallel.
                              THANK YOU AGAIN
                              Simply amazing
                              Daniel Tal
                                This tool can't make the trick?
                                Just close your lines, make the offset, erase lines that you don't want πŸ˜‰
                                • T
                                  tald311
                                  Unfortunlaty it does not. That will offset the surfaces and not the line. Keep in mind, I am not complaining about the ruby at all either.
                                    Yes it's not automatic, but it's not a big deal after the Offset of contour!
                                    Explode curve and you have all offset you want πŸ˜„
                                    And after free to you to weld any part of curves you want πŸ˜‰
                                      remus
                                      Not really sure what your getting at daniel, as a surface is always defined by its edges so to offset the surface you need to offset the bounding edge.
                                      • boofredlayB
                                        boofredlay
                                        Thanks again for the updated script!
                                        I just now got around to installing it.
                                          stanmarsh
                                          @CadFather
                                          thanks for the icons, i really like it, its very refined! πŸ‘
                                          btw, the offset cursor icons are missing.
                                          • CadFatherC
                                            CadFather
                                            Hi, i think this is going to be the final release (for now)
                                            TOS Cursors updated (smaller pencil).
                                            TOS Icons updated:
                                            small icons
                                            large icons
