    Faces area in a group ?
    15 Posts 7 Posters 2.7k Views 7 Watching
      Matt666
      Salut Didier !
      Si tu exploses le groupe, calcules l'aire totale, et recompose le group ?
      And if you explode group, calculate total area of the faces, and re-create group ?
      Petit truc pour afficher l'aire totale des face du groupe :
      Smt to show the total area of all the faces in a group :
      def face_area
      	model = Sketchup.active_model
      	n = model.active_entities.count
      	cn = 0
      	sel = []
      	group = model.selection[0]
      	group.explode.each do |e|
      		if e.typename == "Face"
      			cn += e.area
      	UI.messagebox("\nAire totale des faces du groupe ; " + cn.to_s + "unités")
      	while(n < model.active_entities.count)
      		sel.push(model.active_entities[n])
      		n += 1
      	model.selection.add(model.active_entities.add_group(sel))
      Frenglish at its best !
      My scripts
        I'd perhaps be best to copy the group inside another group, then explode it and get the areas and then delete the parent group. That way no coincident geometry will be erased and the original is not changed ?
          Matt666
          Hi TIG!
          This is the second time you corrected me on this error! 😆 🤣
          My scripts
          • Didier BurD
            Didier Bur
            TIG, you are my ☀
            Merci mate/Matt
            DB
              Matt666
              De rien mon initiateur de Ruby 😉
              My scripts
              • T
                todd burch
                Personally, I'd call that a bug in the #area method if it is not taking the scaling factor into consideration.
                • Didier BurD
                  Didier Bur
                  Hi Todd,
                  You know, groups are almost like component instances, they are stored in the model like "internal definitions" and a group is like an unique occurence of its definition, with or without a transformation applied. This is where the 'group' object in SU is wrong defined IMHO.
                  It's a shame we can't apply a transformation to a face, this will solve quickly the problem. I've written Face::transform myself, but for some unknown reason it sometimes raises an error "points are not coplanar" when applying the method to the edges of the face. Go figure...
                  PS: great presentation at 3DBC, but perhaps you need a little bit more training with the compo spray ?
                  DB
                  • Didier BurD
                    Didier Bur
                    @AdamB: just let me call you the ruby wizard Voilà, c'est touT !
                    DB
                    • AdamBA
                      AdamB
                      (FWIW I'd say face.area giving objects space area is the correct behaviour.)
                      But people, this is all the wrong approach. You don't want to be building geometry, you just want to run through each face in the object and scale the area by the transformation. The trick is to project the scaling into the face's basis frame.
                      So the code in my book is:
                      def objectsurfacearea(container, xform)
                      	total = 0
                      	for ent in container.entities
                      		next unless ent.kind_of? Sketchup;;Face
                      		# get face basis frame
                      		normal = ent.normal
                      		binormal = Geom;;Vector3d.new(normal.y,normal.z,normal.x)
                      		tangent = (normal * binormal).normalize
                      		areascale = (xform * binormal).length * (xform * tangent).length
                      		total += ent.area * areascale
                      	return total
                      So you'd do:
                      objectsurfacearea(mygroup, mygroup.transformation)
                      or
                      objectsurfacearea(myinstance.definition, myinstance.transformation)
                      Voila! C'est tous.
                      Adam
                      • AdamBA
                        AdamB
                        @didier bur said:
                        Voilà, c'est touT !
                        Enfin! Apres vingt ans avec une epouse Francais, plus ca change avec mon Franglais..
                        • Didier BurD
                          Didier Bur
                          une epouse FrancaisE
                          En effet, en effet... 🤣
                          DB
                            Sweet! Just what I needed. 😄
                            How does it handle nested scaled groups/components? Do y ou have to add up the total transformation?
                            • K
                              kat
                              Hey thanks a lot AdamB for your super professional approach!
                              Finally found what I was looking for, now my code works fantasticly.
                              I did some additional reading about the Frennet-Serret/TNB frame but I don't really understand everything.
                              If I get it wel, the normal(N) is perpendicular to the face, the tangent(T)'touches' the face and de binormal(B) is perpendicular to both normal and tangent. But then how do you know on which side of the face formed by N and T, is B? I don't get the
                              multiplication. Isn't B supposed to be the cross product of N and T?
                              And why is gives
                              you the scale factor?
                              Could you give me some extra matematical information about this?
                              I would like to understand why this code works,
                              thanks, kat
                              • AdamBA
                                AdamB
                                @kat said:
                                I don't get the
                                Makes no odds. Binormal and tangent both lie in the plane.
                                @kat said:
                                And why is gives
                                I'm taking the unit vectors in the plane of the face and transforming them by the Group transform which may scale them. Getting the length in the binormal and tangent direction allows me to figure out how much to scale the area of the face accounting for the transform.
                                Adam
