    Faces area in a group ?
    15 Posts 7 Posters 2.7k Views 7 Watching
      Matt666
      De rien mon initiateur de Ruby 😉
      Frenglish at its best !
      My scripts
      • T
        todd burch
        Personally, I'd call that a bug in the #area method if it is not taking the scaling factor into consideration.
        • Didier BurD
          Didier Bur
          Hi Todd,
          You know, groups are almost like component instances, they are stored in the model like "internal definitions" and a group is like an unique occurence of its definition, with or without a transformation applied. This is where the 'group' object in SU is wrong defined IMHO.
          It's a shame we can't apply a transformation to a face, this will solve quickly the problem. I've written Face::transform myself, but for some unknown reason it sometimes raises an error "points are not coplanar" when applying the method to the edges of the face. Go figure...
          PS: great presentation at 3DBC, but perhaps you need a little bit more training with the compo spray ?
          DB
          • Didier BurD
            Didier Bur
            @AdamB: just let me call you the ruby wizard Voilà, c'est touT !
            DB
            • AdamBA
              AdamB
              (FWIW I'd say face.area giving objects space area is the correct behaviour.)
              But people, this is all the wrong approach. You don't want to be building geometry, you just want to run through each face in the object and scale the area by the transformation. The trick is to project the scaling into the face's basis frame.
              So the code in my book is:
              def objectsurfacearea(container, xform)
              	total = 0
              	for ent in container.entities
              		next unless ent.kind_of? Sketchup;;Face
              		# get face basis frame
              		normal = ent.normal
              		binormal = Geom;;Vector3d.new(normal.y,normal.z,normal.x)
              		tangent = (normal * binormal).normalize
              		areascale = (xform * binormal).length * (xform * tangent).length
              		total += ent.area * areascale
              	return total
              So you'd do:
              objectsurfacearea(mygroup, mygroup.transformation)
              or
              objectsurfacearea(myinstance.definition, myinstance.transformation)
              Voila! C'est tous.
              Adam
              • AdamBA
                AdamB
                @didier bur said:
                Voilà, c'est touT !
                Enfin! Apres vingt ans avec une epouse Francais, plus ca change avec mon Franglais..
                • Didier BurD
                  Didier Bur
                  une epouse FrancaisE
                  En effet, en effet... 🤣
                  DB
                    Sweet! Just what I needed. 😄
                    How does it handle nested scaled groups/components? Do y ou have to add up the total transformation?
                    • K
                      kat
                      Hey thanks a lot AdamB for your super professional approach!
                      Finally found what I was looking for, now my code works fantasticly.
                      I did some additional reading about the Frennet-Serret/TNB frame but I don't really understand everything.
                      If I get it wel, the normal(N) is perpendicular to the face, the tangent(T)'touches' the face and de binormal(B) is perpendicular to both normal and tangent. But then how do you know on which side of the face formed by N and T, is B? I don't get the
                      multiplication. Isn't B supposed to be the cross product of N and T?
                      And why is gives
                      you the scale factor?
                      Could you give me some extra matematical information about this?
                      I would like to understand why this code works,
                      thanks, kat
                      • AdamBA
                        AdamB
                        @kat said:
                        I don't get the
                        Makes no odds. Binormal and tangent both lie in the plane.
                        @kat said:
                        And why is gives
                        I'm taking the unit vectors in the plane of the face and transforming them by the Group transform which may scale them. Getting the length in the binormal and tangent direction allows me to figure out how much to scale the area of the face accounting for the transform.
                        Adam
