    Faces area in a group ?
    15 Posts 7 Posters 2.2k Views 7 Watching
    • Didier BurD Offline
      Didier Bur
      Has anyone ever figured out how to calculate the total area of all the faces that are in a group and this group has been scaled/rotated/moved, etc ?
      If you do that:
      def faces_area(faces)
      a = 0.0
      faces.each do |f|
        a+=f.area
      a
      You'll get the area of the faces BEFORE the group was scaled.
      So I tried that (assuming that faces is an array of faces of group.entities):
      def faces_area(faces,group_transfo)
      a = 0.0
      faces.each do |f|
        fv=[]
        f.vertices.each do |v|
          fv.push(v.position.transform(group_transfo))
        new_face=Sketchup.active_model.entities.add_face fv
        a+=new_face.area
        new_face.erase!
      a
      But I got the "Points are not coplanar syndrom".
      Any hint anyone ?
      DB
        Matt666
        Salut Didier !
        Si tu exploses le groupe, calcules l'aire totale, et recompose le group ?
        And if you explode group, calculate total area of the faces, and re-create group ?
        Petit truc pour afficher l'aire totale des face du groupe :
        Smt to show the total area of all the faces in a group :
        def face_area
        	model = Sketchup.active_model
        	n = model.active_entities.count
        	cn = 0
        	sel = []
        	group = model.selection[0]
        	group.explode.each do |e|
        		if e.typename == "Face"
        			cn += e.area
        	UI.messagebox("\nAire totale des faces du groupe ; " + cn.to_s + "unités")
        	while(n < model.active_entities.count)
        		sel.push(model.active_entities[n])
        		n += 1
        	model.selection.add(model.active_entities.add_group(sel))
        Frenglish at its best !
        My scripts
        • TIGT Online
          I'd perhaps be best to copy the group inside another group, then explode it and get the areas and then delete the parent group. That way no coincident geometry will be erased and the original is not changed ?
            Matt666
            Hi TIG!
            This is the second time you corrected me on this error! 😆 🤣
            My scripts
              Didier Bur
              TIG, you are my ☀
              Merci mate/Matt
              DB
                Matt666
                De rien mon initiateur de Ruby 😉
                My scripts
                  todd burch
                  Personally, I'd call that a bug in the #area method if it is not taking the scaling factor into consideration.
                    Didier Bur
                    Hi Todd,
                    You know, groups are almost like component instances, they are stored in the model like "internal definitions" and a group is like an unique occurence of its definition, with or without a transformation applied. This is where the 'group' object in SU is wrong defined IMHO.
                    It's a shame we can't apply a transformation to a face, this will solve quickly the problem. I've written Face::transform myself, but for some unknown reason it sometimes raises an error "points are not coplanar" when applying the method to the edges of the face. Go figure...
                    PS: great presentation at 3DBC, but perhaps you need a little bit more training with the compo spray ?
                    DB
                      Didier Bur
                      @AdamB: just let me call you the ruby wizard Voilà, c'est touT !
                      DB
                      • AdamBA Offline
                        AdamB
                        (FWIW I'd say face.area giving objects space area is the correct behaviour.)
                        But people, this is all the wrong approach. You don't want to be building geometry, you just want to run through each face in the object and scale the area by the transformation. The trick is to project the scaling into the face's basis frame.
                        So the code in my book is:
                        def objectsurfacearea(container, xform)
                        	total = 0
                        	for ent in container.entities
                        		next unless ent.kind_of? Sketchup;;Face
                        		# get face basis frame
                        		normal = ent.normal
                        		binormal = Geom;;Vector3d.new(normal.y,normal.z,normal.x)
                        		tangent = (normal * binormal).normalize
                        		areascale = (xform * binormal).length * (xform * tangent).length
                        		total += ent.area * areascale
                        	return total
                        So you'd do:
                        objectsurfacearea(mygroup, mygroup.transformation)
                        or
                        objectsurfacearea(myinstance.definition, myinstance.transformation)
                        Voila! C'est tous.
                        Adam
                        • AdamBA Offline
                          AdamB
                          @didier bur said:
                          Voilà, c'est touT !
                          Enfin! Apres vingt ans avec une epouse Francais, plus ca change avec mon Franglais..
                            Didier Bur
                            une epouse FrancaisE
                            En effet, en effet... 🤣
                            DB
                              Sweet! Just what I needed. 😄
                              How does it handle nested scaled groups/components? Do y ou have to add up the total transformation?
                                kat
                                Hey thanks a lot AdamB for your super professional approach!
                                Finally found what I was looking for, now my code works fantasticly.
                                I did some additional reading about the Frennet-Serret/TNB frame but I don't really understand everything.
                                If I get it wel, the normal(N) is perpendicular to the face, the tangent(T)'touches' the face and de binormal(B) is perpendicular to both normal and tangent. But then how do you know on which side of the face formed by N and T, is B? I don't get the
                                multiplication. Isn't B supposed to be the cross product of N and T?
                                And why is gives
                                you the scale factor?
                                Could you give me some extra matematical information about this?
                                I would like to understand why this code works,
                                thanks, kat
                                • AdamBA Offline
                                  AdamB
                                  @kat said:
                                  I don't get the
                                  Makes no odds. Binormal and tangent both lie in the plane.
                                  @kat said:
                                  And why is gives
                                  I'm taking the unit vectors in the plane of the face and transforming them by the Group transform which may scale them. Getting the length in the binormal and tangent direction allows me to figure out how much to scale the area of the face accounting for the transform.
                                  Adam
