    [Plugin] Xref Manager v5.0
    35 Posts 15 Posters 24.9k Views 15 Watching
      cdubea
      @cdubea said:
      TIG,
      Any chance of getting the Xref Manager tweaked to show only the top level components in the Xref Manager dialog bog?
      Thanks,
      chris
      Due to multiple issues, I've gotten to the point where this tool is no longer useful to me.
      These are (in no particular order)
      1. Inability to effectively deal with multiply nested parts. This is due to the fact that ALL xref'd components of ALL components are listed in the manager. This causes multiple rebuilding to be required and WILL go into an infinite loop requiring Sketchup to be shut down.
      2. Issues with sub component names not being updated. A part that I renamed the components did not update properly. Some component names changed, some didn't.
      3. Had issues with component names have #1... being added to them.
      Any chance of getting some of these things rectified?
      Please?
      chris
        dammerel
        i get this error
        Error Loading File XrefManager.rb
        undefined method `add_submenu' for nil:NilClass
        Andrew
        • plot-parisP Offline
          plot-paris
          same error message for me...
            Try v5.1 that fixes this... see below or here:
            301 Moved Permanently
            (www.sketchucation.com)
              perk
              When I try to click on the link I get a message saying "you are not authorised to read this forum"
              • jujuJ Offline
                juju
                +1, get the tools out and fix it.
                  Jim
                  Ok, links are fixed.
                  • jujuJ Offline
                    juju
                    Great response time, thanks!
                      perk
                      Thanks Jim
                      its working now
                      • david_hD Offline
                        david_h
                        So does this work as XREF in autocad that it reduces model size and hence adds to speed cuz the model is referenced and not attached or bound, (inserted) into the mother model?
                          So does this work as XREF in AutoCAD that it reduces model size and hence adds to speed cuz the model is referenced and not attached or bound, (inserted) into the mother model?
                          No. You'll have all of the files inserted into the model. It only keeps track of external file changes and allows up to reload them as you want...
                          • david_hD Offline
                            david_h
                            Oh well . ..c'est la vie
                              alz
                              Quick basic question --
                              What is the advantage of the XRef plugin over using the native "Reload" feature on a component?
                                It batch processes any 'xrefs' and it also tells you which ones need reloading etc...
                                  alz
                                  Gotcha -- so it's a way to tell me when I load a scene that some items have been modified. Without this, I'd have to know which ones had been changed, and then find them individually in the scene to update.
                                    Mra
                                    Thanks for the plugin Tig!
                                    • EdsonE Offline
                                      Edson
                                      @tig said:
                                      The v6 new Import methods could also mean that in the future importing DWG/DXFs is easier, more reliable and works on Macs - BUT that's NOT in this release - watch this space...
                                      http://www.mahfuz.arq.br
                                        @edson said:
                                        Xref Manager is long overdue an update BUT the list IS looooong........ 😞
                                        • 2 / 2
