    šŸ›£ļø Road Profile Builder | Generate roads, curbs and pavements easily Download
    AutoCAD
    22 Posts 13 Posters 3.2k Views 13 Watching
      SolarInnovations
      I am trying to produce our ISO's in sketchup and then transfer them into AutoCAD as a 2D graphic, I can successfully export the file and open it and the file is fully functional, but the drawing does not have the correct dimensions. I have the correct scale in the options dialog box when I'm exporting, but the sizes are off. I have tried to do this with a front view and that produced the correct dimensions, so it seems that Sketchup only takes an image of the 3D model to send into AutoCAD. I am wondering if anyone knows if it is possible to bring an ISO from sketchup into AutoCAD with the correct dimensions?
      James
      • DavidBoulderD Offline
        DavidBoulder
        I haven't used this feature much so not sure why it wouldn't scale correctly. Of course for an ISO not all dimensions would be correct. For example on a square surface, measuring along the axis (edges of square) would be correct, but measuring diagonally wont' be.
        At any rate, if you want to can just scale the file in AutoCad.
        I'm assuming of course that you have perspective turned off.
        David Goldwasser
        OpenStudio Developer
        National Renewable Energy Laboratory
          Archi Rag
          make sure it is set on paralell projection (in camera menu) when u export the image, then select the iso view (in view>standard views menu)
          check that the units in the properties dialogue is set to the correct ones (millimeters / inches)
          otherwise it should work
            SolarInnovations
            I have done all of the above, parallel projection, standard view-iso, and the dimensions - i tried both arch 2D and arch 3D and there was no difference. I don't understand why it's not working correctly either. any other suggestions?
              Archi Rag
              post the file?
                toan76
                Of course, dimensions simply cannot be true in an ISO, you need AXON instead. But SketchUp (and all 3D programs I know) doesn't support AXON.
                  dammerel
                  when importing in acad make sure the units are set the match the sketchup file
                  andrew
                    caronte01
                    In isometric, you should get real dimensions. Lines on the x, y and z direction should be to scale(1:1). There“s probably a bug in 2d iso export that will export isometrics at .8 ish of the correct scale. I“ve also had it. The solution has been to scale with reference in acad the exported dwg.
                    S
                      toan76
                      See the attached. Or just try by yourself: draw a cube in ACAD, switch to an ISO view, print out at 1:1 scale, measure it on paper. Think about this case: a circle in ISO view is an ellipse. How can the dimensions of an ellipse are the same as those of a circle?
                      S
                        SolarInnovations
                        i understand that an iso isn't going to have true dimensions, but at the present moment we draw our iso's in autocad with true dimensions, which are later referenced in the detail drawings. We are trying to see if sketchup would be a more beneficial program to use in drawing our iso's, the only problem is that we would still need to be able to reference the iso for true dimensions when drawing the details. I didn't know if there was a way to auto scale the sketchup drawing so it would be the correct scale when you place the 2D into AutoCAD. thank you all for your responses. any other ideas are still welcome.
                        • Chris FullmerC Offline
                          If you just want to autoscale it, play with the .dwg export settings. You can specify a scale there. So you would be able to scale it thereif desired.
                            anipint87
                            I imported my plan (autocad file .dwg) using sketchup to make 3d model. but why is it like that?! for example, in an autocad file the measurement of my door at my plan is 1.00 meter but when i use import in sketchup it and measured it, it turned into 0.30 meters... why is it like that? did i miss something?
                            • jujuJ Offline
                              juju
                              Were the export and import units set the same? The difference between the measurements you mention seem to be roughly the same ratio as meter to foot.
                              A quick and easy way to scale it to the correct size is to:
                              • First check to see that the units are set the same.
                              • Measure something you know the exact measurement of (eg. your door of 1000mm).
                              • Once you've finished the measurement (i.e. second click) punch in the correct measurement on the keyboard.
                              • SU will prompt you to make sure you want to scale, you obviously say yes.
                              • Things should be to the correct scale now.
                                anipint87
                                the setting of unit in my autocad was in meters and also in sketchup before I imported the file. my friend also encounter the same problem as I did. As I've said on my last post on autocad it is 1.00meters (I've also plot it on a paper and scaled) but when I imported it, and measured it, it was 0.30m which is written on the lower right of sketchp... maybe I'm just not yet aware on how properly import it. thanks
                                  Could you upload the cad file here? or is it private work stuff?
                                    Yes, it definitely sounds like a unit mess-up (from metre to foot).
                                      caronte01
                                      Hi guys.
                                      I“ve had this before, and, as described elsewhere, i“ts not a units issue. It“s easy to test by exporting a plan or an elevation, and then an iso. Plans come to scale, so do elevations, it“s only isos that come out scaled. They are scaled at .86, i believe.
                                        I think that is something else. ISO come in scaled differently because the camera is not looking straight at any axis, but looking instead equally skewed at all 3 axis. so they come in uniformly scaled down by +/- .86. He has said that his is having a scaling issue just from a CAD import into SU, and its a scale factor close to the .3 range. Seems more like a scaling meter/foot or unit/foot. Perhaps he is in engineering feet, thinking he is in meters, since that works on a decimal system?
                                        • VLADIMIRZMV Offline
                                          VLADIMIRZM
                                          ISO means equal, then all parallel lines to any axis must be drawing with real dimension and should not be scaled . the lines that aren't parallel to any axis hasn't a real dimension. In this way an ellipse (an especial ellipse called ISOCIRCLE) is graphically equal (yes it is) to a cicle see image.
                                          i'm a technical drawing teacher and i've been had this problem since skecth 4, i think is a bug inside exporter. isn't an issue of units, believe me i've tried everything šŸ˜‰
                                            Ah, i think there is confusion (certainly on my part) because this thread was changed about 12 posts in. The first question indeed is about ISO. someone came after with a question that sounds more like a unit setup question though. So yes, the ISO stuff (the original question)is not about units, but about the ISO. The second question seems to be about units. And it would still be nice if he could upload his file for us to look at.
