    Regular terrain
    30 Posts 12 Posters 7.4k Views 12 Watching
    • GaieusG
      Well, I scaled them 10x down on the z axis (BTW it distorted the whole "should be" terrain 10x as well) but the same result happened.
      • plot-parisP
        plot-paris
        Csaba, I am at a complete loss. just tried it with my tutorial model and got the same screwed up result like you do. 😲
        tried different things, like skaling or enhancing their length (a hundret times) did not work.
        anyway, I thought about your suggestion, TaffGoch, to use the "drop at intersection" ruby.
        and it is indeed a very elegant way to speed up the workflow considerably.
        here a short demo, how I used the script.
        regular_terrain2.skp
        • GaieusG
          Definitely a very elegand solution - and the funniest is that now it worked! 😲
          • plot-parisP
            plot-paris
            Csaba, just found the cause for the first model not working.
            when setting up the different scenes and therefore copying the geometry several times, I must have worked inaccurately, what resulted in the vertical lines not being entirely vertical.
            therefore SketchUp did not, like we assumend, ignore the lower endpoints, but included them into it's terrain calculations.
            problem solved - at last we have peace of mind! 😍
            • TaffGochT
              TaffGoch
              Jakob,
              Your 'drop' demo model works great. I hadn't foreseen the option that this technique provides -- giving you the power to change the degree of detail (spacing.) This can be a great way to reduce the polygon-count for a complex terrain; producing larger mesh triangles.
              Since the drop ruby finds intersections corresponding to lines AND planes, automatic interpolation is provided. A smaller grid spacing should, therefore, also produce useful results.
              Thanks for the demos!
              Taff
              "Information is not knowledge." -- Albert Einstein
              • GaieusG
                Thanks Jakob - I was already going nuts the other day 😲
                • W
                  watkins
                  Dear Gaieus and Jakob,
                  A revised/summary posting listing the do's and dont's with attached tutorial skippy's should now appear in the Tutorials section. Do you chaps have the time and energy to do this?
                  Kind regards,
                  Bob
                  • GaieusG
                    It's Jacob's idea with Taff's addition - I just chimed in and would not take any credits by creating a revised tutorial of it so please, Jakob, go ahead and post a refined version of it in the Tuts section!
                    πŸ˜‰
                    • plot-parisP
                      plot-paris
                      now, that the method has been refined, it is ready for the tutorial section πŸ˜„
                      I just tried to redo the tutorial. but my laptop is so old, that he crashes every other minute, when opening the file.
                      therefore, Gaieus, feel free to write the tutorial (if you have got the time).
                      [Edit] if you do, don't forget to include a link to the "drop" ruby into the description[]
                      I will only be able to do it on monday in the office; and my boss surely doesn't like it, when I spend too much time doing stuff for SCF instead of for the office πŸ˜‰
                      if you do, could you post the link to the tut in this thread? would be great.
                      cheers, Jakob
                      ps: this is an example why I like the SCF community so much. you have an idea, post it, and after a pleasant discussion a much faster and better way to solve the same problem is born!
                      • GaieusG
                        I'll see how lazy I am between my drinks during the week-end πŸ˜„
                        (I have the same problem with my boss in the office but fortunately he cannot see my monitor) πŸ˜‰
                        • plot-parisP
                          plot-paris
                          of course. there is no hurry for that tutorial, I think.
                          enjoy your drinking!
                          after months of cider and guinnes it will be Sambucca tonight for me (with big glasses, tissues and straw. I love hearing other people coughing while I keep the pleasantly burning vapours in my lungs until lack of oxygen forces me to breathe again 😍 )
                          by the way, my monitor is completely exposed. and in addition to that everyone tries to get a glipse of my screen every now and then, because I am doing all the SketchUp work. πŸ˜’
                          • Didier BurD
                            Didier Bur
                            Cool, clever, good πŸ‘
                            I don't really know, what this cleanup is good for
                            It sure helps a better terrain display whith smooth/soft faces (long and narrow triangles never display well).
                            My question is: don't we loose some information during the process ? I guess the new terrain is not exactly the same as the original (the greater the vertical faces spacing, the more you loose terrain details and distort it) ?
                            This may be a plugin idea: drop a virtual flat TIN over the current terrain, compute intersections and automatically get the "clean" regularly triangulated terrain.
                            What do you think ?
                            DB
                            • plot-parisP
                              plot-paris
                              that would be an awesome tool, because it really saves a lot of time and can help you to clean up your model considerably.
                              I would definitely love such a script!!! 😍
                              • jujuJ
                                juju
                                +1!
                                  dylan
                                  Nice idea Didier
                                  http://dmdarchitecture.co.uk/
                                  • soloS
                                    • P
                                      Panga
                                      Very nice approach for simplify a terrain mesh !!
                                      Thanks for sharing it. πŸ˜‰
                                      • GaieusG
                                        Ha! Yes, 14th of July!
                                        When I was in Paris and used the Metro and got off (up) at the Bastilles, I was looking around to see it when finally I realised that "ah these dudes destroyed it on occasion of one of their regular revolutions" (well, the first in the row) πŸ˜„
                                        Amazingly, I was a last year history student at that time. Such is life!
                                        BTW - English is quite keen on separating its Germanic and Romance layers of origin so I bet "LibertΓ©, Γ‰galitΓ©, FraternitΓ©" would read as "Liberty, Equality, Fraternity" - but then again; who am I to judge it? πŸ˜‰
                                        And the plugin seems to be a beauty again! πŸ‘
                                        • plot-parisP
                                          plot-paris
                                          oh dear, I am really looking forward to your plugin. the image looks very promising. πŸ˜•
                                          enjoy the 14th!
                                          • Didier BurD
                                            Didier Bur
                                            Algorithm is OK and plugin is half done. It needs a lot of tests and adjustments.
                                            National day today, so I'll get some rest...
                                            TRN dropped over terrain
                                            DB
