    Naming Layers [Architectural use generally...]
    24 Posts 12 Posters 5.2k Views 12 Watching
    • Wo3DanW Offline
      Wo3Dan
      @utiler said:
      It is interesting that this thread has been viewed 126 times and yet only two responents; obviously not as important as i thought it would be.....
      Andrew,
      Yet this thread is very important. There was a thread about layers where people also discussed their workflow concerning layers and layer names.
      I know I had a small contribution in there but even a search does not bring me any further, yet?!?
      I guess it has to do with transformation of all that was posted in the past. In due time it will be there again I hope.
      In the mean time I will follow this discussion closely, thanks.
      P: wo3dan
      • Didier BurD Offline
        Didier Bur
        Hi all,
        Don't know if it will be of any interest here, but I will add my 2 cts to the "layers structure concern" providing soon a new release of my layer manager, GSU6 free and pro compatible: I have add filters to display or hide layers, typing wildcards in a dialog box, just like Autocad layers filters. 💭
        DB
        • aadbuildA Offline
          aadbuild
          Hi Andrew, I have just inadvertantly come across this thread and I like the idea of numbering. I am a builder and our estimating comes from sketchup and also our sheduling as well. I would like to number all stages of the job uniformly between our estimating and sheduling & designing. Could you relink the above attachment so that I can have a look at the way you are doing it? Thanks mate..
          Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
          https://www.plusspec.com
            tatami
            Hello all,
            I developed this system (and continues to be a work in progress) in order to standardize the models within our studio. It had been very confusing and slow to pass models around between staff and each model having its own personal layering system which had to be figured out. Its important to keep the layer box "name" carrot active to keep the layers in this order. The system allows the user to pull off floor levels from the top down and buildings are developed with a "pancake" method. This is the basic framework and model-specific layers can be added as needed:
            .0 site plan (we use this as a CAD import or sketch overlay layer)
            .1 site model (flat or sandbox grade)
            .2 site construction (existing buildings, walls, etc)
            .4 site entourage (people, etc)
            .4.1 site trees (high poly trees on their own layer so they can be turned off)
            .4.2 site cars
            .4.X (additional points can be added as necessary)
            0.0 basement plan (we use this as a CAD import or sketch overlay layer)
            0.1 basement plate (the floor plate)
            0.2 basement mass (walls, partitions, windows, doors)
            0.4 basement entourage
            0.4.1 basement furniture
            1.0 first fl plan
            1.1 first fl plate
            1.2 first fl mass
            1.4 first fl entourage
            1.4.1 first fl furniture
            2.0 second fl plan
            2.1 second fl plate (or for single story buildings this could be the roof)
            etc, etc
            9.0 notes
            9.1 dimensions
            We also use prefix modifiers before the layer number to group certain items.
            E Existing
            D Demolition
            for example: D1.2 first fl mass demolition
            I think this operates similar to the system described in your post. Its interesting to compare how other models are organized. Thanks for the post!
              chuck
              Attached is a layer guide that is used by most of my clients
              layerstd-2.pdf
              Life is to important to take seriously
              • W Offline
                watkins
                Dear Didier,
                I look forward to seeing your new layer management script. Up until now I have tended to draw everything on Layer 0, but my models are getting larger and more difficult to handle, so I will have to get to grips with layers.
                I have a vague memory of you discussing your own layer management scheme, but that was some time ago.
                Kind regards,
                Bob
                  I don't know about Mac but it downloaded fine in Windows. However the ile seems to be completely "empty" - I don't mean there's no geometry (Andrew said tha: "dummy file") but no layers other than the default Layer 0.
                  Does anyone else experience this?
                    bertu
                    Maybe I'm the only MacIntosher who has problems to download >utilers< layers sets.skp file.
                    Or are there any others ? Is there any help ?
                    It's my first and until now the only downloaded skp-file making difficulties by opening.
                    Bert
                      bertu
                      Thanks Gaieus …
                      … for checking utilers layers_setup.skp file. It seems that I missed nothing in being unable to open it – probably just a vapor file.
                      At the moment my Mac and my brain are working OK so I don't need further advice on using layers or opening files. I was just curious to see how others organize there workflow.
                      Bert
                      • JClementsJ Offline
                        JClements
                        A script such as rename_layers might be useful to some of you. You can open the .rb with a text editor which details how you can input certain parameters
                        rename_layers.rb
                        • EdsonE Offline
                          Edson
                          @bertu said:
                          Bert
                          bert,
                          the problem does not seem to have anything to do with mac issues. the file was uploaded in the old server we used before the new board installed. it is just not there any longer to be downloaded.
                          http://www.mahfuz.arq.br
                          • EdsonE Offline
                            Edson
                            @watkins said:
                            Dear Didier,
                            Kind regards,
                            Bob
                            bob, it has been out for some time and it is quite useful. you can get here.
                            • W Offline
                              watkins
                              Dear Edson,
                              I must remember to look at the date of a post. Thanks.
                              Regards,
                              Bob
                              • EdsonE Offline
                                Edson
                                @watkins said:
                                Dear Edson,
                                Regards,
                                Bob
                                no problem. i do that from time to time.
                                • utilerU Offline
                                  utiler
                                  Here go guys.....
                                  Sorry I haven't received updates for this thread for some reason.
                                  Layer sets.skp
                                  Just Curious...
                                    Thanks Andrew,
                                    I have the layers (and scenes) now.
                                      bertu
                                      Hi all,
                                      thanks for your explications and addition; it's OK now.
                                      A special thankyou goes to utiler! Please excuse me for the expression vaporfile, I'm sorry!
                                      Bert
