    Silvershadow's eye candy 1: The river runs thru it
    125 Posts 62 Posters 76.4k Views 62 Watching
      silver_shadow
      %(#BF0000)[Ok ay guys, here you go..how to bake the roof.
      Keep in mind, you need sketchy FFD rubie
      http://i185.photobucket.com/albums/x165/hondsekont/ffd1.jpg
      http://i185.photobucket.com/albums/x165/hondsekont/ffd2.jpg
      http://i185.photobucket.com/albums/x165/hondsekont/ffd3.jpg
      http://i185.photobucket.com/albums/x165/hondsekont/ffd4.jpg
      • H
        HFM
        Nice tutorials! And a very nice model 👍
        try to texture that! 😲 😛
          silver_shadow
          %(#BF0000)[hee hee im am going to texture it...just need to make time for it since im doing this in evenings in my free time.. but till then here are some tips and tricks i spilled a while ago how to dirtmap models.
          Unknown Forum
          (www.websitetoolbox.com)
          http://i185.photobucket.com/albums/x165/hondsekont/Estoril10Jun0754.jpg
          http://i185.photobucket.com/albums/x165/hondsekont/finishedproduct.jpg
          this model is way more difficult and could be more fun than any model i have textured before.. so i will keep you guys posted when i have something more to put on the table on this thing again. ☀]
          • C
            cheffey
            Wow, a treasure trove of greatness 😲
            Cannot wait to see more! Keep up the great work.
            silvershadow, have you posted this over on the google groups?
            I think it would be good to have it on their site.
            BROS RŌMAN BRÄUN
              mateo soletic
              Amazing work, thanks for sharing tips and the tutorials.
              Cheers,
              Mateo
              Concept Illustrations
              • marked001M
                marked001
                wow..this is great.. a cartoony look out of sketchup is not easy! i'm in awe.. keep going..please 😄
                http://www.revision21vis.com
                instagram: revi21on
                • P
                  princedragoncok
                  Really really excellent, thank you very much 👍
                  • G
                    Glenn at home
                    WOW! Truly blown away! There is a new standard to strive for with SU!
                    • P
                      Phil Rader AIA
                      EYE CANDY indeed....but most of us have a sweet tooth so keep giving us sweet morsels to look at.
                      http://www.philrader.com
                        JuanV.Soler
                        @silver_shadow said:
                        Today i want to share the power of sketchup itself, to encourage those who thinks sketchup is just a tool that can only build block models and nothing more.
                        thankyou.
                        i think you have the synthetic path for some new tools for the version 7
                        so I wont buy it if those mixes of rubies are not fusionated in smart tools that lead to your results.¡
                        • urgenU
                          urgen
                          ...Fine work, fine mood... ☀ 😄 let,s continue to create the similar further ... Many thanks! 👍
                          --pupil forever...------
                          • G
                            GreyHead
                            After I rendered the cobbles I remembered TIGs Matrix Proximity script. It allows you to create an array of components with some variation in size, placement and rotation. It adds an extra level of 'difference' if you need it.
                            Bob
                            PS For some reason about half of the cobbles turned over on dropping so I had to make both sides rounded.
                            • T
                              tomislavm
                              This is one of the best I have ewer seen of sketchup,original and fascinating!
                                dylan
                                Thanks for the info on TIGs script Bob, that is a new one to me 👍
                                http://dmdarchitecture.co.uk/
                                • soloS
                                  I cannot seem to locate it but I once remember talk about a 'Greeble' script, my thinking was that this too could be a solution.
                                  However Silver you certainly used SP in a very creative way.
                                  • L
                                    lapx
                                    I think it's part of the projection.rb ruby script. 😎
                                      silver_shadow
                                      GreyHead"]After I rendered the cobbles I remembered TIGs Matrix Proximity script. It allows you to create an array of components with some variation in size, placement and rotation.
                                      thanx a lot, will have a look at this 😄 looks really cool
                                      • T
                                        twharvey
                                        :idea: ....comments are welcome... 💭
                                        Hi Silver,
                                        I followed your directions above and, after some fooling around, was able to duplicate your cobbles paved on a contoured surface. I did notice a couple of things to keep in mind for future projects: 1. The amplitude of the curved surface can't be very big (difference between high and low points) or the cobbles fall off. 2. The distance between the substrate and the cobbles must be minimized or the cobbles bounce when they hit and end up all over the place.
                                        Thanks for the tut,
                                        Tom
                                        Tom
                                          silver_shadow
                                          yea i know. try this too
                                          copy your site to a new drawing. rotate it to be not so steep.
                                          Maybe you can try boxing it in also so nothing gets spilled. Try to divide the areas to controll groups and if it works, just remove the dividers afterwards. (just a thought 💭 )
                                            Jim
                                            It's not well documemented, but protrude can offset, protrude, and taper faces. Leave the second column blank unless you want a random number btween the range.
                                            This model was produced using these inputs:
                                            protrude.skp
                                            • 2 / 7
