    [Plugin] UVTools v0.1
    180 Posts 71 Posters 128.4k Views 71 Watching
    • W Offline
      watkins
      Dear Alan,
      Could you give a little tut to show how you map the texture onto the sphere using the various tool? I cannot quite see how it all hangs together.
      Thanks,
      Bob
      • Alan FraserA Offline
        Alan Fraser
        It's fairly straightforward, Bob.
        I imported the sphere from Shapes and exploded it.
        I then applied Subdivide and Smooth with 2 iterations (it maps reasonably well with just 1, but 2 is better)
        I then resized the sphere to exactly 10' diameter...it's a tad larger than that by default.
        I imported the image and exploded it, then edited its height in the Material Editor to match the sphere's diameter.
        I then applied the image, from the Material browser to the sphere.
        I then right-clicked the sphere and chose UV Tools > Spherical from the context menu....and Bingo!
        That's all there is to it.
        3D Figures
        • W Offline
          Whaat
          Resizing the image before using the plugin is an unecessary step. The plugin will always map the image the full height of the sphere and wrap it exactly once around the sphere.
            Alan Fraser
            Thanks Dale. I should have figured that with no adjustment controls, it would be set to fit. I've only just taken a look now at the code.
            3D Figures
            • W Offline
              watkins
              Dear Alan,
              Many thanks for the detailed explanation. As I wrote somewhere else, I tend not to texture my models, being content with the default shades, and so I haven't built up any skill in this area.
              Thanks again, and thanks to Dale for another useful script. The model of the globe is really very impressive. I must have a go at Mars.
              Kind regards,
              Bob
                Alan Fraser
                Bob,
                You'll find some decent planet maps here.
                http://planetpixelemporium.com/planets.html
                The individual planets are linked at the bottom of the page.
                The maps are distorted because in order to fit a sphere the entire top and bottom edges need to come to a single point at either pole, so you'll appreciate that things get progressively stretched as you move away from the equator.
                You don't need to start from scratch. You can merely open the Earth globe skp, go to the Material browser...In Model, select the Earth texture then in edit mode replace the earth.jpg with one of the planetary ones you download from the above site. It will map automatically.
                3D Figures
                • FrederikF Offline
                  Frederik
                  Thanks for both the tut' and the link to the planet texture maps, Alan..!! 😄
                  Much appreciated..!! 👍
                  Cheers
                  Kim Frederik
                  • W Offline
                    watkins
                    Dear Alan,
                    Many thanks for taking the time to post the link. I will have a go at that when I have a moment. I would also to create a background/sky dome simulation of Mars too. The reason for that is we have a couple of projects which involve instruments for Martian atmosphere monitoring, and it would be rather nice to see the lander in a Martian setting. Alternatively, I could get on with some real work.
                    Kind regards,
                    Bob
                    • RichardR Offline
                      Richard
                      i had a play with the plguin and found if i reduced the texture scale just a bit the mapping at the poles tended to clear.
                      Also exported to Maxwell with no issues!!!
                      Whaat again you do some absolutely amazing stuff mate!
                      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                      • F Offline
                        Fletch
                        Thank you, Whaat! 😍
                        Fletch
                        Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                          silver_shadow
                          hi there. 💭
                          Is it not possible to re write the plugin to see the mapping box,a way to scale the box or edit and maybe include a box mapping too. Similar to what max is doing.But from me to you...congrats..its super so far.
                          • majidM Offline
                            majid
                            i tried the ruby , but there is a problem when exporting to Kerkythea ..... it converts the shape to lots of faces whit lots of textures!!!!!!!!!!!!!! would be it reviewed to solve this problem?
                            yours majid
                            • FrederikF Offline
                              Frederik
                              Majid,
                              Whaat have already provided an answer to this... 😉
                              @whaat said:
                              This seems to be an issue with non-triangular faces. If you can somehow triangulate the geometry prior to exporting, then the UVs should still be correct.
                              My 'Polyreducer' script triangulates all of the faces of a mesh. However, it will also reduce some polys. (The minimum is 10%). Once I triangulated your spheres, I reapplied the spherical mapping and then exported to Indigo. It worked perfect! I expect it to work with other rendering engines as well.
                              Another script that will triangulate faces is my 'SubD and Smooth' script (but it's not free)
                              Below is made using the SubD and Smooth script and exported using SU2KT... 😄
                              Works like a charm...!! 😍
                              Cheers
                              Kim Frederik
                              • N Offline
                                nektares
                                indeed, just 5 mins using it and i got this result, works great
                                and its so easy to use! congratulations.
                                http://i249.photobucket.com/albums/gg239/nektares/uvmaps.jpg
                                  topmanblue
                                  😍 😍 thank you!!! good!!!
                                    Just catching up with all the news here...
                                    Great plugin, thanks a lot!
                                    I discovered however that if you want to UV map something on a reversed face, it gives a bugsplat. No worry about this at all though - at least it will teach everyone the lesson; "always orient your faces correctly"! 😉
                                      kwistenbiebel
                                      I would love to be able to UV-map textures like in this example, to go around (smooth)corners:
                                      (Do mind that a displacement map was added.)
                                      'wrap around' mapping?:
                                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/demoscene_stone-01_1-1.jpg
                                      • W Offline
                                        watkins
                                        That lead flashing must have been rather tricky to fit!!
                                        • W Offline
                                          Whaat
                                          You can already do this to a limited degree in SU by positioning a texture using the right-click context menu. Then, sample that texture with the ink-dropper prior to painting on an adjacent face. The UV mapping will then be continuous around the edge.
                                          The sample image you posted can already be done in SU. I am sure of it. I will try to recreate a similar scene using displacement mapping with only SU and Indigo to test my theory.
                                            kwistenbiebel
                                            Oh cool!
                                            You weren't referring to the projected method are you?
                                            ...but to the method to texture a cilinder, right? (as in the video tuorials that once were on the official SU site).
                                            • 4 / 9
