    Doing dashed lines
    18 Posts 6 Posters 4.2k Views 6 Watching
      Latetzki
      I have little problem and i need solution quickly, please. I hided roof from my model and now i should mark it as dashed lines, so how do that? Not whole roof, just boundaries. Help!
      Sorry if i use some weird words.
        remus
        If i understand you correctly, i reckon you want to unhide the roof and apply a dashed exture to it. You could quite easily make one yourself, or im sure there must be a few available on the internet somewhere.
        • E Offline
          ehaflett
          Smustard has a dashed lines ruby that works pretty well.
            Latetzki
            I mean just boundaries. Not whole roof.
              remus
              OK, youll want to go with eric's solution then, and get the dashed line ruby form smustard.
                Latetzki
                20$?? Is there any (other) free one? 😐
                Sorry, doublepost. Can't delete this.
                  remus
                  You might have some luck with the tools on surface by fred06. I think if you press ctrl while using any of the tools they produce a dashed line rather than a normal line.
                  • W Offline
                    watkins
                    Dear All,
                    You can change lines to construction lines by using Rick Wilson's xlines.rb, and kind young Rick has made it free.
                    Smustard(TM) - the Companion to Sketchup(TM) - Plugins and Scripts
                    List of Smustard plugins and ruby scripts for Sketchup
                    (www.smustard.com)
                    Kind regards,
                    Bob
                      Latetzki
                      @watkins said:
                      Dear All,
                      (www.smustard.com)
                      Kind regards,
                      Bob
                      I put .rb file to plugins directory? And how i enable it in SU?
                        remus
                        Just restart SU and the plugin should be listed under the 'plugins' menu or the 'tools' menu.
                          Latetzki
                          It's not there 😞
                            remus
                            Try selecting the lines you want to change and then right clicking them. There might be an option there.
                            • W Offline
                              watkins
                              Dear James,
                              Jim Foltz has a construction line pencil tool on his website. I use it frequently for adding local construction lines.
                              Kind regards,
                              Bob
                              • W Offline
                                watkins
                                Dear James,
                                I have asked Jim if he would look at making a circle construction line tool. If I need such I draw a circle, delete the face (if drawing on a group/component)and then use xline to turn the circle into construction lines. The only problem with that is the circle segments are all disconnected and cannot be reconnected.
                                The ideal would be a connected and editable circle of construction lines, preferably with a construction point at the centre, and grouped on creation so that it can be easily moved around.
                                Kind regards,
                                Bob
                                • Wo3DanW Offline
                                  Wo3Dan
                                  James, Bob,
                                  In the image (cube) you provided I can see the option 'Convert to Xlines'.
                                  Are they construction lines i.e. short guides with the same properties as guides?
                                  Are they going to be deleted with the 'Delete Guides' option in the 'Edit' menu? Can you snap to them while drawing?
                                  I use the cline.ruby and don't see the option 'Convert to Xlines' in the right click context menu. So this must be another ruby. It there a button to select a [guide line pencil] to start drawing these lines like in cline.rb?
                                  t.i.a. for replying,
                                  Wo3Dan
                                  • W Offline
                                    watkins
                                    Dear Wo3Dan
                                    You will need to go to http://www.smustard.com and download Rick Wilson's xline.rb script.
                                    Yes, unfortunately, the construction lines are deleted along with native SU construction lines. If after converting to a cline the cline crosses a normal line then you can snap to the intersection. If the cline has a floating end (on a face but not connected to another line entity) then you cannot snap to the end. If you need to do this then place a cpoint at the end of the line before using the xline script.
                                    I hope this is clear.
                                    Kind regards,
                                    Bob
                                    • W Offline
                                      watkins
                                      Dear James,
                                      No problem!
                                      Of course, we should both be out enjoying the sunshine, shouldn't we.
                                      Regards,
                                      Bob
                                      • plot-parisP Offline
                                        plot-paris
                                        or celebrating the Queen's birthday! 😉
